Question about Toshiba 65HDX82 65" Rear Projection HDTV-Ready Television
Blue color issue
Sometimes during operation, sometimes when first powering on, the blue color seems to be out. I can detach the blue component video input feed, power off the set, reattach the blue component feed and power the set back on and then my colors are great. Sometimes it lasts for days, sometimes for a few hours. Any clues?
  • Anonymous Aug 18, 2008
    I believe we are having the exact same problem with our Toshiba 43" Cinema Series TV. The blue colour channel is now separated from the others and so the TV generates a blue shadow or ghost image.
    We'll try disconnecting and reconnecting all the cables. But I suspect it's the TV because the problem occurs with both the satellite input and the DVD input.
Yes, the cable has been replaced. I've narrowed the problem to the tv, as in my original post, if I detach and reattach the cable I can make it start working again. Almost like something needs resetting or something.
Posted on Feb 22, 2008
    President:
  • 4,402 Answers
Can you replace the cable see if problem stay's or go's
if it comes back check for loose connection around that board.
Posted on Feb 21, 2008
Dv7 230m laptop blue screens randomly, more often during gaming.
I had similar issue recently and had to replace my video/audio card. I think yours is frying up!
Jan 02, 2013 | Computers & Internet
My sony wega trinitron 21 inch TV was showing a single colour when it turn on.sometime it will be full red and sometimes green and sometimes blue.
Hello
The fault with your TV is with some loose contact inside it. Normally most Trinitron TVs shows this problem due to loose contact in the video output card. Video output card is pluged diretly to the picture tube base, and can be detachable. You can pull it out very carefully without damaging the pins of of the picture tube. Most of the components in this board will heat up during working. Repeated heating and cooling will make the solder joints of the most heated components to get loose contacted. Normally, these loose contacts are very difficult to detect because they will be microscopic. Just do as what we do for this type of fault.
Resolder most of the suspected solder terminals, with applying a little more solder, without making any solder bridge in between the solder terminals. This will solve the problem of your TV. OK.
Jun 23, 2011 | Sony FD Trinitron WEGA KV-36HS500 36" TV
I wanted to connect hp dv 4 1275 laptop with sanyo tv with hdmi and 3 rca .but its not working .tried everything din work.
You MUST install HDM IDrivers for your Video Card & MotherBoard. You can only use HDMI, OR Component, but NOT BOTH. Sometimes HDMI, requires an AUDIO OUT Cable, this is the Red & White, AV Stereo input.
OR you use COMPOSITE which is YELLOW, Video, now AUDIO, is Red & White.
COMPONENT, you use, Red, Blue, Green, (ALL VIDEO) PLUS you need the Stereo AV AUDIO too, Red & White.
HDMI, should supply BOTH, but as related sometimes you need the Audio red & White AV, inputs & Outputs.
ALL Cables go color to color.
h10025.www1.hp.com/ewfrf/wc/document?..
Resolving issues,with HDMI. above.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?lc=en&dlc=en&cc=us&os=2100&product=3860476
DRIVERS link above.
Apr 11, 2010 | Computers & Internet
Red pixels
They are are called dead pixels. A TFT monitor is built of millions of tiny lamps(LEDs) in matrixes of the tree colors, Red, Green and Blue, these have like any other electronics component a limited life span. When dead, sometimes they stop reacting to the color changing control signal and keep emitting only one color often red(IMO because the other two components are more stressed by the higher frequency). Unfortunately this phenomenon is irrepairable. :(
BR
Feb 28, 2010 | Televison & Video
Connected my monster cable component to my tv but no video worked last week tv is good could it be my playstation3 or the cable
Make sure you pluged the color coded cables up correctly, Green to green Blue to Blue and Red to Red. Sometimes in low lighting you can confuse the green cable with the Blue...
Oct 20, 2009 | Philips Magnavox 51MP392H Rear Projection...
Bright Blue and Green screens seem to blink.
Do not use component video. Test S video or 3 rca's red black and yellow(video) , see if they work! you need all 3 inputs on component video, sounds like you may have the colors mixed, check all color coding slowly. Sometimes the comp video out can be too strong, try using a splitter , reduces signal by 3 db, try 2 then 3 in line. This is only a test. keep in touch...
Please rate!
Mar 31, 2009 | Televison & Video
My husband moved the tv from one table to another, and now the color is all screwed up. Mostly purple and green. What's the problem? It's an Hitachi 42" plasma tv.
Usually this is caused by unproperly hooked up component video cables. Check the green, blue and red component video cables on the tv and on the device (cablebox) to hopefully solve the issue. Sometimes one just pulls loose also
Jan 10, 2009 | Hitachi 42HDS69 42 in. Plasma Television
NON- Hi Def channels loose thier blue? color....picture is all green
Some CATV hi-def receivers are known to have issues keeping up with the datastream. Symptoms from the picture going solid black to other unpredictable video have been seen. Ask your CATV provider if they can switch your brand to another manufacturer. If your cable box has component video jacks in addition to HDMI, try that too. Some boxes will output RGB perfectly but bomb out with HDMI.
May 03, 2008 | Sony KDF-E55A20 55 in. LCD Television
Dvd movie playback
Techies may be right- the only way to find out is to get a cool breeze around the unit- a fan say- whilst in operation.
Jun 07, 2007 | Panasonic SC-HT720 System
Sanyo DS32920 Blue Screen
My panasonic Tv pic suddenly turned into a blue color I can't see the pic any more just can hear the audio.....any solutions????
Mar 19, 2006 | Sanyo DS32920 32" TV
Toshiba 65HDX82 65" Rear Projection HDTV-Ready Television Logo
29 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
