These particular Whirlpool models are a bit overdesigned, in my opinion!
Some have as many as 4 fuses and 3 thermal cutouts (TCOs) or thermostats, any one of which can render the oven "dead" if blown.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating
components.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
If you don't find your mini-manual,
or if you want to look at it before removing the controller, you can
download it here (just enter your full model
number with suffix from the tag in or on the oven).
You can find links to helpful exploded
view diagrams and part ordering help
here.
I recommend that you bookmark that
link to your favorites.
We're happy
to help you with free advice and we'd appreciate your thoughtful rating
of our answer.
Door catches.
Remove from any
power source, remove the cover of the cabinet. Slacken off the clamp
mechanism and ease the clamp over the guide to allow the door to
open. The door may be easily
adjusted by slackening off the screws that clamp the door
catch/actuators in place whilst holding the door closed and then
tightening the screws. The rear of the door may be adjusted by
slackening the lower door hinge screws and adjusting as required.
I
hope that helps.
The electric outlet is working, the Circuit Breaker is on, plugged in another appliance in same outlet and it worked, tried plugging the microwave to two different outlets on two different CBs, no power to microwave on wither outlets. Something wrong with microwave. is there a internal fuse or CB in this model ?
