Question about Samsung DynaFlat TX-P2764 27" TV
Tye Dye Picture Always!
My Samsung TX-P2764 TV looks like a Hippies T-shirt all the time.It shows a blue circle, a green circle, and a red circle, all at the same time no matter whats on.What's the deal?It's only 2 years old! I had to exchange the first one I had within the first week of purchase and this one barely made it 2 yrs.
  • 2,130 Answers
Is this an Analog TV with a picture tube? If so, it sounds like the screen is magnetized. Have you had any magnets (including speakers) near the screen?
Inside all analog TVs is what is called a degaussing coil. When you turn on the TV for the first time (cold), the degaussing coil is energized for a couple seconds to demagnetize the screen and then it goes off.
You can purchase an external degaussing coil and demagnetize the screen youself. A degaussing coil looks like a small hula-hoop about 6-8 inches in diameter with a AC line cord attached. I've even made these coils out of long lengths of enameled wire, electrical tape and a line cord.
Once itas plugged into the wall outlet, you hold it close to the screen (1/2' away) with the hoop facing the screen and move the hoop in a circular pattern, covering all areas of the screen and slowly move the hoop away from the screen while still moving in a circular patten until your about 2-3 feet from the screen.
If you did it right, the color splotches will be gone.
Let me know if I can be of further assistance to you or help you to locate one of these coils.
It's possible that the coil in your set is bad.
Good Luck!
- Jim
Posted on Feb 07, 2008
    SHARCNET-USA Feb 07, 2008
    If this is a LCD TV, perhaps one of our other experts can help you.
    - Jim
    LCD TV's do not require degaussing.
What is the 2nd connection on the side of the K2.5 for
Your pump will look similar to the attached picture:
Red circle shows the soap/detergent inlet/venturi.
Blue circle shows cold water inlet.
Purple circle shows your high pressure water outlet
Green circle shows safety valve, dumps water if the pressure inside the pump head is too great or or the water temp too high 7fccbf77-6a81-4a2d-a43d-3f88059f90be.jpg
Jun 24, 2014 | Karcher 2500 PSI Pressure Washer
Advent tv displays green
If you are saying no red: The model indicated here Recoton Advent Advent Q1435A TV is a 14 inch set.
first it may be cheaper to replace than repair--That said if no red look to the small circuit board at end of picture tube (it plugs onto the tube).
It will have either individual output transistors or a single IC.
What (if only one color missing) I would look at is the bottom side which faces to the rear---a circle of solder connections--possible one is broken--there will be one for each red, green, and blue--not always easy to see but if any of the solder connections look cracked or even broken loose-----
Mar 28, 2012 | Recoton Advent Advent Q1435A TV
When i turn my tv on the sound is great but the picture is very narrow.My tv is at least 8 yrs old.
something similar to this happened to my old T.V, with mine it started to go wrong colours, the screen started to fade, with it being 8 years old, you may just need a new one, they will eventually fully break, so its best to get a new T.V
Dec 09, 2010 | Samsung DynaFlat TX-P2764 27" TV
I lost my color on my tv
If the cable was an SVideo, it's possible you might have a broken pin. Losing one of the 4 pins would still give you a picture but it would be in Black and White. Check both ends of the cable and if one is missing, get another SVideo cable.
May 26, 2009 | Samsung DynaFlat TX-P2764 27" TV
Panasonic rear projection tv convergence problem
Check the regulator and convergences ICs....accordianman
Feb 26, 2008 | Televison & Video
TV won't turn on
I have the same problem.
Sep 09, 2007 | Samsung DynaFlat TX-P2764 27" TV
RCA CTC203 no red colour
Did you change the resistor by yourself? I am not sure if your TV has manual adjust on the back of the TV that you can adjust. Some times turning the TV Off and unplug it from the wall helps because it resets the TV. Check your Back ground color and see what is the dominating color. Blue, Green or Red. If this doesn't work please call a professional to look at it.
Jun 18, 2007 | RCA F27649 27" TV
My tv is picture is blue and green
Hi there my t.v has a similar problem, I turned it on and the colours arn't right, there the colours go out in three circles mainly mainly blue, green, red yellow, but depends whats showing on the t.v? Please help.
Apr 17, 2007 | Bush 5693D 24" TV
Green Picture
I guess it's missing blue. Even if you see the blue crt working it's not enough and focalised. replace the coolant in it and also check if you have some coolant leak on the crt pcb.
Apr 10, 2007 | Samsung HCN436W 43" Rear Projection...
Samsung DynaFlat TX-P2764 27" TV Logo
195 people viewed this question
Jerry Greenberg
Jerry Greenberg
