Question about Canon LaserClass 7000 Plain Paper Fax
Name and phone stamp
We want to re-program the name and phone # stamp that is sent out and also prints at the top of the paper on a comfirmation report. We bought the fax / copier used and have no owners manuel to instruct us on how to make the change.
    Scholar:
  • 159 Answers
You must change the data registration for the fax features. To do this you must locate the "Data registration" key under the one touch speed dial panel. Then press ^ key until Fax registration is displayed. Then press set button. You must scroll using the < > keys to get to the appropriate items you wish to change. It takes a fax technician a few seconds to do this but he's had years of experience. Be patient, you may have to re try until you get it right.
Posted on Feb 08, 2008
I have a sf-560r. When printing or copying or receiving fax, the machine prints a small line near the bottom of the paper with some numbers. The numbers change each time I print or copy or receiving fax,...
Do the series of numbers look like a date/time and page number stamp? If so, you need to turn off the Stamp RCV Name feature. This is part of the Advanced Fax features. To access this, press Menu until you see Advanced Fax on the top line of the LCD screen. Press Enter then use the left/right arrows until you see Stamp RCV Name. Press Enter again and use the left/right arrows to select Off. Press Enter to save the setting. Then press Stop/Clear to exit the menu system.
Samsung has the User Manual for the SF-560 here: http://www.samsung.com/levant/support/model/SF-560/XEU . The direct link to the manual in English is currently http://downloadcenter.samsung.com/content/UM/200906/20090617100814640/Guide_English.pdf . See pages 4.4 and 4.5 for the Advanced Fax menu information. These are pages 65 and 66 of the PDF.
I hope this helps. If the digits aren't the date/time/page number, I'm not sure what the footer text is.
Dec 28, 2017 | Office Equipment & Supplies
How to adjust paper size in Cosmi perfect PDF creator essentials?
With most PDF creators a virtual printer is created when you install the software. That is where you would adjust the paper size. When you print to your PDF printer, before you click print, click on the PDF print options, Page Setup, and the select the Paper tab. Choose the paper size that you would like the PDF to be formatted to. Click OK and the print to the PDF writer printer.
Additionally, Cosmi includes user manuals when you install their software. It can be found here:
1. Click Start
2. Select Programs (or All Programs)
3. Select the name of the program you just installed (you may have to Select Cosmi, then Select the program name)
4. From your program's sub-menu, you should see Manual or PDF Manual.
Mar 20, 2011 | Cosmi Perfect PDF Creator Full Version for...
I have acquired a casio CE 3700 without a manual and need to change the company name that is printing on the receipts - please help
A very rare but great machine. You need to pull the stamp out from the back of the receipt side of the printer (there is a small black handle that you pull just under the paper entry). Then take the stamp to a stamp maker to get your name, tax number etc cut into a new stamp.
If anyone is looking for a Casio CE-3700 manual, there is a user and programming manual here: http://the-checkout-tech.com/manuals/cashregisters/Casio_CE-3700_operators_and_programming_manual.html
Oct 11, 2010 | Casio Parts Cash Register PC Desktop
How to supress the date and time and location of the sender
the date and time will always be printed but the name is what you put in under fax header (you leave that blank). But that is supposed to be there as far as FCC rules.
Apr 15, 2010 | Canon LaserClass 9000L Plain Paper Fax
How do I get a confirmation of a fax that I sent
u can get a confirmation sent by enbling a communication report printing
and if your fax have a stamp u can enable it to work and give a small stamp on the paper after sending
Apr 06, 2010 | HP 640 Inkjet Fax Machine
Extra Line when printing from a dos-based program
your printer paper size shorter than your PC dos-program print size setting, example: if use a letter size paper to print a A4 size file which should occur two paper go out..
so you need check your PC print setting or take a presetting paper size, make a size match between PC program and paper in printer .
hope you fix it, please take a rating let me know how much helped you thanks!
May 21, 2009 | Dell 5100cn Laser Printer
Tx image set not to display
getfile.asp?rid=1258 September 11, 2008
getfile.asp?rid=3215 Product : imagePRESS C1, All Fax Capable imageRUNNER Models Title : Setting the TX Terminal ID print options Question :
What are the options to print the TX Terminal ID on received pages?
Answer :
The TX Terminal ID settings enables you to specify whether the sender information is printed at the top of every document that you send via i-fax. Information such as your i-fax address is printed, enabling the recipient to know who sent the document.
Note: If you set TX Terminal ID to 'On' you can also set the position of the Terminal ID information which is printed on the recipient's paper.
The default settings are:
TX Terminal ID: On
Printing Position: Outside
Display Destination Name: On
1) Press Additional Functions
2) Communications Settings
3) TX Settings under Common Settings.
4) Press the up or down arrow keys until you see TX Terminal ID
5) Select On or Off
If you select ON:
Select the printing position of the Terminal ID information, select 'On' or 'Off' for display Destination name, press OK.
Printing Position:
Inside: The Terminal ID information is printed inside the image area on the recipient's paper.
Outside: The Terminal ID information is printed outside the image area on the recipient's paper.
On: The destination's name registered in the Address Book is displayed in the Terminal ID information.
Off: The destination's name registered in the Address Book is not displayed in the Terminal ID information.
If you select OFF
Press OK
6) Press Done repeatedly until the Send Basic features screen appears.
Canon USA, Inc. Systems & Technical Support Division 1-800-528-2830
May 05, 2009 | Canon imageRUNNER C3200 Copier
Verification stamp
there is no function to print it on the fax you sent but you can have a come journal.
press the following.
function-7-4-start-1-2-start-2"should say always" start stop then this will give you what you want
Jan 20, 2009 | Panasonic Panafax UF-560 Plain Paper Laser...
One phone in our office name will not program
Hi, to assign the name is Transfer 104, the link to the video I have sent is on http://www.abbeytelecom.com , there are loads of Samsung Dcs videos on this site.
Nov 26, 2008 | Samsung Phone PDCSLCD12B
106 people viewed this question
old marine
old marine
