Question about Frigidaire 14 cu. ft. / 396 liter Upright Freezer FFU14FC4A
My freezer is not cold inside right now, and all the vegatables i had grown in my garden are not cold any more but soggy.
The temepratue was on six, which was the highest and there was nothing wrong with it before.
  • Anonymous May 21, 2008
    Have lost instructions, does the fridge temperature get colder if I set it to a lower number ie 2 or a higher setting ie 6?
  • 92 Answers
Can you here the compressor running or any clicking noises
Posted on Feb 10, 2008
  • Sara Whitfield
    Sara Whitfield Jul 25, 2012
    yes i can, i need help with mine too
Hello, I have Kenmore freezer and it doesn't work anymore. I defrosted it and it won't get cold or freeze anymore.
Hello Tom;
My name is Peter; I am a retired field service appliance technician.
You did not provide a model number which is located on the inside liner of the refrigerator.
If the freezer light is the only thing that works, then you are locked into the defrost mode. Every 8-10 hours your unit will shut down for about 10-20 minutes. At this time your defrost heater turns on. Thereafter, your unit restarts to cool.
Go into the following website. You will get diagrams and part numbers for your components.
Locate your defrost timer. It may be in the lower back right hand side (a metal plate with a through hole). With a flat head screw driver turn the stem one click at a time clockwise to trip the defrost timer.
Or, it may be in your control board or elsewhere.
If it is in your control board do not panic. Take the part number from the website search the internet (Buy used/remanufacture) and get the board for 40-50% less.
If it is the control board, ground yourself by touching bare metal. Static electricity will knock out a control board. Water Filters Lawn Garden Appliance Parts
Mar 02, 2016 | Kenmore Freezers
Freezer is not cold enough, even though the control panel says that the temperature is where it should be.
pull the panels inside and check the fan usually in a fridge freezer the fan cacks out or is full of ice clean it out and clean the overflow tube if fridge is cold enough then it is the freezer fan
Jun 07, 2015 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
I have a Kelvinator upright freezer model k330uf the bottom section does not work
Sounds like its got blockage.
There is a channel that allows cold air to "fall" into the bottom chamber. There is also a return. Typically the "fall" chamber is choked with either something that fell in and was trapped, frozen solid with ice or algie has grown and closed the hole.
The best thing to do is empty it completely and inspect the drop channel.
Put all your frozen goods in ice chests to keep them from thawing out.
Good Luck.
Jan 08, 2015 | Kelvinator Freezers
The lower half of the freezer is cold but not the top. There is no air blowing ou the top vent. What should I do?
Hello friend, thanks for your inquiry!
I understand that the top of your Frigidaire freezer is not cold but the lower half is. I would recommend to perform a defrost on your freezer, I understand that it is a frost free freezer but it could be that maybe something has caused it to freezer over. You can perform a manual defrost by unplugging your appliance for four to six hours. If that is unsuccessful and you are still not getting cooler temperature up top I would seek assistance from a professional to come out and diagnose your appliance. -Matt
Aug 14, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
The fridge freezer does not get cold. The outside of it gets cold but not the inside. There is still a humming noise.
if the outside gets cold and inside is not getting cold this is sign of low refrigerant
Aug 27, 2010 | Freezers
The top of the freezer is not freezing.
Normal 0 If the bottom of the freezer is freezing (but only just), but the top is just above freezing, then your problem may be either your defrost timer or the defrost heating element. You'll need a thermometer to determine how cold (or not cold) your freezer is getting. Usually a freezer is happiest when it's full, so being too full is likely NOT the problem (there is room for air to circulate, right?).
If you're handy, you can troubleshoot the problem yourself by following the suggestions found here, as that may at least identify the problem. Replacing components inside your refrigerator isn't incredibly complicated, but if you're uncomfortable with taking things apart, you may be better off seeking the help of a properly trained professional.
Hope this information helps!
Aug 24, 2009 | Freezers
Freezer Not Freezing Food
there is a circulation fan and also a vent. Either the fan is blowing, or there is a cloged vent.
Feb 11, 2009 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Maytag upright freezer model MQU1556AEW
I experienced the same problem last week with my freezer. Apparently the change in temperature during defrosting allows the blade locking mechanism to slide on the motor shaft during the spinning operation. The blade pulls itself along the shaft until it comes in contact with the motor mounting bolt. If your freezer just stops getting super cold, but remains cool and you don't hear the fan spinning, remove the inside back panel and check the fan blades for freedom of movement. I almost disposed of the freezer this past week but decided to make one last check of the mechanisms.
Sep 22, 2008 | Freezers
Indest Fridge Freezer
Possibly something was spilled and it got to the door gasket. Clean the door gasket area with warm soapy water. In the door there is nothing critical to the system operation that should cause the condition you have.
May 17, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Frigidaire 14 cu. ft. / 396 liter Upright Freezer FFU14FC4A Logo
249 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
