Question about HP PhotoSmart 7760 InkJet Printer
Printer reads insert card.
A black piece fell out of computer when i was trying to fix the first problem which was reading paper jam. The black piece has a bar code. My computer still will not print and now reads insert card.
  • Richard Wilbur May 11, 2010
    The black piece fell out of your computer, or your printer? And what part of your computer or printer? If you unplug the printer does it stop telling you to insert the card?
    It sounds like you had a card in the card reader and it broke. Answer the above and it might help my diagnosis. Thanks!
  • 103 Answers
Removing from my que due to inactivity
Posted on May 07, 2008
My printer states "paper jam" although I don't see any paper. I bought new ink cartridges & it doesn't print the multi-color, only the black.
Paper jam means just that. Look for paper or a piece of paper jammed into a gear or stuck between a roller or even in your ink cartridge . When you put in your new ink did you take off the protective seal and run the HP software to check if it is reading the Cartridge ,You might want to read the instruction on how to install an ink cartridge. It might also help you ?
Nov 03, 2014 | HP Deskjet 3052A
My HP 3050 Laser printer is not recognizing the print cartridge. I had a paper jamb and the error message started. I have tried to power down the machine, reinstalled a new cartridge, removed and...
Hello, If your cartridges are not empty, but you continue to receive the 'Ink Cartridge(s) are Empty ' error message, follow these steps to override the message. Disconnect any cables (Ethernet cable or USB cable) that connect both the printer and the computer. Restart your computer. (Consider bookmarking this page in your Web browser so that you can easily return to it after the computer restarts.) With the printer turned on , remove the power cord from the back of the printer. Wait 30 seconds. Insert the power cord back into the printer, and turn the printer on. Clear any error messages. Reconnect any cables that connect the printer to the computer. If the above doesn't solve the problem, you will have to download Hp diagnostic utility on your your computer, install is on your computer and it will help to detect and solve the problem. Visit the hp link below, read all the information on the page and download the diagnostic tool from the page. Click here: Keep me informed if none of the above seems to solve your problem. Good luck.
Jul 11, 2011 | HP LaserJet 3050 All-In-One Printer
My granddaughter put a toy in printer & a part broke off - thin, translucent piece about 1/4 inch wide by 7 inches long. How do I open up the printer in order to try to put this part back?
The plastic piece you are talking about it just prevents the paper from bending forward when is inserted in the printer. That plastic piece should not cause any paper jams or printing problems. If you do happen to have paper jams maybe a piece of plastic fell inside where the paper goes. Simply turn off the printer, remove the paper and flip the printer upside down and shake it a little that should remove any debris inside the printer.
Jan 31, 2010 | Lexmark X5470 All-In-One InkJet Printer
Canon ip 2600 printer. Paper does not feed
Hey I had the same problem. Called the company; we couldn't fix it. Well I turned it upside down and a 2" flower stem fell out from when I cut some flowers next to my desk. It still didn't work. I was examining the feed area while it was running and I found another little piece of stem that was lodged way in there. I had to get it out with tweasers and it turned out to be 1" long. Couldn't really see it at all. Works fine now.
Oct 25, 2009 | Canon Pixma iP2600 Photo InkJet Printer
HI Paper got jammed whilst printing, retrieved paper and message now reads See trouble shooting and routine mainenance Chaper in users guide what do I do now do not have manual to hand
if the paper is fully out if not then check there might be a small piece stuck on the sensor,try to check the sensor actuator may be misplaced it usually black in color try to fix it properly so that it moves freely.
Oct 20, 2009 | Brother DCP 115C All-In-One InkJet Printer
Message reads: the paper is jammed clear the paper and press OK
Even if a small piece of paper stuck inside the printer you ll get this msg.  So what you have to do is if you have a Air blower or vaccum cleaner blow air inside the printer,  If any piece of paper is stuck inside it will come out and you won't get that msg again.  Try this and sure it will work...!
Mar 18, 2009 | Office Equipment & Supplies
Printer keeps reading paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 07, 2009 | Canon MX300 Office All-In-One Printer
Canon MX310 paper jam
"Gclanton" had it right.
I had the same problem today. I ended up taking a piece of paper and from the back side started lightly forcing the paper in the back slot. I had the top cover open where you replace the ink cartridges. Towards the back you can see the paper start coming into the printer next to some rollers. On mine there was a small black switch about an inch from the right in the middle of the plastic piece above the rollers. Once I started pushing this paper in I could see this switch was stuck in the down position. After several minutes of pushing the paper in and out the switch moved up and out of the paper path. I then pulled out the paper and hit the ok button and it came on line. This may work better with a piece of card stock.
That switch is the issue.  I ended up finding an object lodged against the switch.  Needed a flashlight, plastic giftcard and a tweezers to get it out.  Works great now.
Nov 24, 2008 | Canon PIXMA MX310 All-In-One Printer
ERROR: Paper Output Jam
HI i just recently 5 min ago fixed this problem.....I tried for days. Most likely something like in my case a small bobby pin fell in the back tray and went into the machine. Some people turn the machine upside down and shake it to get whatever it is out.. nothing fell out of mine when i tried this.. I had to take off the left side of the machine panel ,,,2 screwss in the back and pry down and outward there are 2 screws in the front as well under the silver corner push downward on edge.
I held a piece of paper in front of the front roller and revese fed it into the machine by turning the exposed "wheel " on the left side. You have to guide it through lift up top to see in there as the paper goes under the white rollers. At this point the paper may jam so look inside top at the white rollers about an inch from the right there is a small rectangle shaped hole in there is a black plastic part that part needs to be lifted with a paperclip so the paer can be feed under it,,,,at that point is when the paper i was reversing pushed out a bobby mine works great again......main thing here is there mostlikley is something clogged in there,,blocking the paper.........also check you paper that gets stuck my paper kept having a bend in it where it jammed and thats where the pin was in there.
Sep 24, 2008 | Canon PIXMA MP470 All-in-One Printer
No paper light stays on and printer won't print (paper is full)
There is a black, curved-shape piece that hangs down (protrudes) from within the paper bay (visible with cartridge removed) that is spring-loaded. That piece might be jammed or broken.
Jan 22, 2008 | Dell 1600n All-In-One Laser Printer
HP PhotoSmart 7760 InkJet Printer Logo
Ben Johnson
