Question about NexxTech (COB6V5216) Burner
Dvd rom drive
I threw in a dvd rom drive... nexxtech 16x. I know I connected everything in correctly but the computer will not read it. I went to add new hardware and it showed, proceded to instal it, then at the end said installed but there might be problems it installed incorrectly. Computer doesnt read a disk when thrown in it and my computer shows i only have only a floppy drive.
  • 2 more comments
  • Jeffvand Feb 07, 2008
    Just switched with original master cd rom drive. same exact place. Thought this was just plug and play what the heck.
    Not sure what jumper on back is or means. Sorry dont know much about computers. Hence the perdicament.
    wait whats the jumper? i got the ma means master and sl means slave. I dont quite see where they are on plastic thing. but as of now my machine is like this dvd drive on top and cd/cd burning drive on bottom. Are you saying to reverse the plugs and plastic thing on them? dvd on bottom with those plugs and cd on top with the master plugs?
  • Anonymous Feb 29, 2008
    All systems connected correctly. Unit plays adio CD, burns files. when DVD is inserted ti reads no disc in drive. Checked profile and it does not show a reagon. Device mananger says no region specified for drive I need help
    Problem Solver:
  • 42 Answers
Hi!good pm...hope this will help...
if you have only one ide cable connected to your hard disk and cdrom,the hard disk must be master and the cdrom is slave...check your cdrom,at the back there's an indicator which type of connection you have.slave (sl)-cable select (cs)-master (m).put the jumper on slave.connect it to the cable and power your pc on...
Posted on Feb 07, 2008
    Master:
    Sergeant:
  • 440 Answers
Is cable on master jumpers or slave ?
  • 1 more comment
  • nick helpap
    nick helpap Feb 07, 2008
    ok has to be on maste rthen on jumper on back if your on top
  • nick helpap
    well on back u see platsic thingys vertical going in above it says ma meens master ok sl meens slave middle of ide cable make sure jumper is over ma pins on back ok
  • nick helpap
    ok so were in new drive if its on top master if its bottem drive use slave middle of ide cable ok on back man eahs on thers jumper mark this as fix ya thx nick
ARTEC DHM-G48R 5.xx (16x/48x) IDE DVD-ROM 16X is not showing up as DVD Drive it is showing up as CD Drive. What do I do to fix this???
If you insert a DVD disk, and then open "My Computer", does it now correctly show that a DVD disk has been detected?
Jun 26, 2011 | Artec DHM G48 DVDROM drive internal 16x...
My DVD drive can read a CD-ROM and play an audio CD, but it cannot play a DVD
Your computer is missing a DVD decoder software. Simply download and install VLC media player and K-Lite codec. Both are free download. You will find the download link by simply doing a google search.
May 04, 2010 | Sony DDU-1615 / 16x DVD-ROM / 48x CD-ROM /...
Dvd rom drive does not work
Try to open control panel then click add hardware. If you have entered the dialogue box, answer whatever is asked according to what you're searching. Then click whatever hardware your PC would like to detect then click finshed. After the detection, close the wizard box then try to open your DVD ROM and try it.
Hope this answers your question.
Feb 18, 2010 | Artec 16X DVD-ROM 48X CD-ROM Drive with...
DVD ROM can play CD, but not DVD
try with next dvd which is burnt in less than 16x speed then check what happens.
Jun 02, 2009 | ASUS (E616P2) Internal DVD Drive
16x dvd-R dISCS
Can you read from the CD-RW drive? If you can then the optics are most likely fine. Try reading from the disk you are trying to write to. It should show a lot of space available if you check it's properties. If not, then that disk has likely been closed and you can't write to it any more. If you can't see the drive on your computers HARDWARE viewer, then the drive either isn't connected (you have said it is), or power isn't getting to it. If you can read from a factory produced CDrom, then you should be good to go.
Jan 27, 2018 | IBM Electronics - Others
Pc died
Hello, I have had similar problems with that same motherboard in the past and have found that resetting the cmos (see users manual) or just taking the battery of the motherboard for a few minutes can solve this. CAUTION please remove the power lead on your tower before touching any components inside, and earth yourself first by touching metal.. as static discharge kills pc components..
Hope this helps.....
Tony.
Sep 09, 2008 | ASUS K8N4-E Deluxe Motherboard
Looking for.....
You will need a low profile dvd. Do you want a part and vendor?
Worldvet
Jun 21, 2008 | HP Compaq Business d530 Ultra-Slim PC...
My computer cannot find it!
ok cheak jumper son back master or slave if your instaling it as master then set pin s on master on back ma ok thats for end of the ide cable top drive if u install this on middel of comp slave then for jumper middle of ide cable ok set jumper for sl then tighten cables nice use new one if it came iwth one next tech uslaly low quilty nexttime buy benq ok hi end
Jan 06, 2008 | NexxTech (DR30G0) System
Why my pc does not work with 16x DVD
the dvd reading capability of your drive could be less than that of the dvd speed,,,,
Dec 30, 2007 | Samsung Sony 16X IDE DVD-ROM Drive DVD...
Dvd writer for toshiba satellite pro
HP dvd1040i 20x Super Multiformat DVD Writer
Price: $69.99
  Internal drive (double layer)
 Write speed: 8x double layer, 20x DVD±R, 48x CD-R
Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
Read speed: 16x DVD-ROM; 48x CD-ROM
Lightscribe disc-labeling technology
one-year limited warranty....
HP dvd1040e 20x Super Multi DVD Writer
External drive (double layer)
  • •   Write speed: 8x double layer, 20x DVD±R, 48x CD-R
  • •   Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
  • •   Read speed: 16x DVD-ROM; 48x CD-ROM
  • Lightscribe disc-labeling technology
    Price: 109.99
    These are the best DVD writers....
    Lightscribe technology is where you can burn your pictures on the disc as a label..... This is Hp's latest technology
    Oct 22, 2007 | Computers & Internet
    NexxTech (COB6V5216) Burner Logo
    111 people viewed this question
    Top NexxTech Computers & Internet Experts
    Steven Wander
    Steven Wander
    Alun Cox
    Joe Goldman
    Joe Goldman
    Are you a NexxTech Computer and Internet Expert? Answer questions, earn points and help others
