Question about Cameras
Resolution on Samsung L830.
I have a new L830 and like it. But I use it in my work and need to be able to lower the resolution to less than 1M in order to make electronic transmissions along with reports. I can't see how to lower the resolution so the photos aren't so large. Camera doesn't have an "internet setting". I need to lower image size to say - 640. Any ideas?
    Master:
    Sergeant:
  • 440 Answers
U can use kodak software and when u tranfer then set to low quilty does good job shrinking them for u ok or picture shrinker software all over web ok thx nick
Posted on Feb 07, 2008
Change the resolution on my Samsung B2030 LCD Monitor
1600X900 is a higher resolution than that of 1280X1024. Therefore 1600X900 is a better resolution. If you would like to run at the lower resolution simply right click your desktop screen and click properties. Then on the settings tab use the slider bar to adjust the resolution. Lower to the left and higher to the right. If the desired resolution is unavailable then you could try downloading and installing the latest drivers for your graphics card installed in your computer.
Your card will either be AMD/ATI Radeon or Nvidia. You will need the model number of the graphics card, the latest drivers may increase resolution support for your card.
Also look on the bottom right hand side of your screen for an Nvidia Control Panel logo in green. Right click it and select the option to "change screen resolution" This may provide you with additional resolution options.
Take care!
damnor01
Nov 02, 2011 | Samsung B2030 LCD Monitor
I am trying to change the camera resolution on my L200, I think it is currently set to 1M, I would like it at maximum, 10.2M
Use the FN button and go to SIZE, there you will be able to change the resolution.
Here is a link for your user manual also:
http://www.samsung.com/uk/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=SAMSUNG%20L200
Hope this helps!
Jul 28, 2011 | Samsung L200 Digital Camera
I have a samsung wave 525 touch screen mobile. I tried to play a video that I transferred from my laptop but it is not working. it said file format unrecognized. the file was an avi file. So I went online...
convert your video to 3 gp or mp4 format by any video converter
while converting set the resolution less than your cell's resolution that is less than 400*240
*best resolution 320*240
use total video converter for best performence
u can also use abc 3 gp converter for easy converting
Nov 13, 2010 | Samsung SGH-L760v Cellular Phone
Hi I've got a Samsung TFT monitor -Syncmaster 710V - that gives an error message.Message reads: Not optimum mode Recommended Mode: 1280 x 1024 60Hz This screen is impossible to get rid of. Anyone know the...
Try to change the desktop display settings, see screenshots below, see if it works
Right click on your destop and go to properties > settings
  1. Set your Screen resolution to 1280X1024
  2. Then click advanced and go to Monitor and set the refresh rate to 60 Hertz.
Dec 06, 2009 | Samsung 710V 17" LCD Monitor
I have a samsung syncmaster 915a which resets to max resolution. Can I change their Motherboard equivelint??
Resolution is determined by the display settings, up to the limits of the hardware. In windows, if you right-click on your desktop and select settings, click the "display settings" tab on the resulting window, you can select lower resolutions (icons etc. get bigger, less stuff fits on screen) if you desire. Be sure to click "apply"
Nov 15, 2009 | Computers & Internet
I have the same problem on my new samsung 2234sw monitor.
The answer to your last questions are yes. Your old video card may not support so high a resolution and this is causing the flicker. Since you said lowering the resolution fixes the problem this would be the most obvious fix. You can get a new GTX 260 with 216 cores 896 mb RAM for about $165. This would allow you to play any games out there or watch hd without any problems. Just make sure your power supply is in the recomended range and has the required connectors for the card. You can get better than a 260 depending on your budget. Hope this helps.
Jul 19, 2009 | Samsung 2243SWX Monitor
I CAN ONLY TAKE 10 pictures and then it says memory full. i used to be able to take 200 pics
You need to reset the size of your pictures (to a lower resolution). This will allow the camera to take more pictures (albeit at a lower resolution) per memory card. The less pixels, the more pictures.
Apr 11, 2009 | Samsung Digimax D53 Digital Camera
My pictures are too big to load
You have two options:
First: use a picture management software to resize the pictures to a smaller resolution such as 640x480 pixels.
Second: reduce resolution on camera. The smallest resolution possible is 1024x768 on L200.
To do so in your Samsung L200, press Fn button. Then scrool up or down until you see SIZE on-screen. Press button to right until 1M appears, then press OK.
Oct 27, 2008 | Samsung L200 Digital Camera
Display Problem
video card may not be capable of that resolution and color depth, check your video cards max resolution and color depth.
I have several lcd monitors that are 1280x 1024 and they do not need drivers to work. the video card must be capable of generating that resolution.
Jun 06, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Changing the picture resolution
Turn on your camera.
Trun the switch on the top of the camera to AUTO.
Press the middle button right of the display (x/-).
Then you can first change the size (7M, 6M, 5M, 5M, 3M, 1M).
If you now use the circle button on the right bottom and on this button you press up or down you can change the quality (very fine, fine, normal).
You can change the size and quality if you press left/right on the circle button.
Jan 04, 2008 | Samsung Digimax S730 Digital Camera
Cameras Logo
46 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
