Question about Kenmore 84052 Dryer
How to take apart a dryer?
I have a Kenmore front load dryer. I need the bottom panel off how do I take it off?
  • 2 more comments
  • roedogg Feb 09, 2008
    Thanks, I am trying to change the thermistor control, I see it. Is there an easy way to do this, the air duct seems to be in the way and the wires are on the thermistor very tight. I am afraid I will break the tab from the thermistor and have to rewire it. I clearly don't know what I am doing.
  • roedogg Feb 10, 2008
    Thank you, honestly I got impatient and called a repairman, I couldn't find my needle nose pliers, or a screwdriver long enough. I didn't want to take everything apart and wasn't 100% sure it was the problem. Apparently, it wasn't the only problem the mositure sensor wasn't reading on the ohm meter. At least I didn't have to change what I thought was the problem the Control Panel board.
  • AKCLC Mar 03, 2008
    I have a general electric gas dryer and need to replace the drum felt is making horrible noise. Mod # DNSR473GVOAA but can not figure out how to get the panels off? How do I remove the panels to access the drum?
  • Anonymous Sep 06, 2008
    running hot
  • 5,911 Answers
First of all, UNPLUG the dryer if you plan on servicing the inside. There are still dangerous voltages present with the dryer turned off.
Lift the front of the dryer slightly in order to place a block of wood under the front feet (I recommend a couple of small pieces of 2 x 4). This will give you access to the screws without having to hold the machine up at the same time. There should be a couple of torx style screws under the bottom seam of the panel. Remove these screws and the panel should drop down and come off. Sometimes these panels can stick. If this occurs, tap on the side slightly and it shoudl come free. I hope this helps you. If you have any further questions, please post back with your comments.
Posted on Feb 07, 2008
  • Jeff Rockwell
    Jeff Rockwell Feb 09, 2008
    An easier way to gain access is to remove the drum, but I don't think you want to do that. On this model washer it involves removing the dryer top, operator control panel, the front panel with the door and the drum. This elevates a somewhat simple job to one that becomes quite involved for someone that has never worked on one of these type dryers before. I try not to discourage anyone from attempting to make repairs themselves. However, if gaining more access can make the job more difficult, I will not recommend it. The wire lugs can be a bit tight at times. This is actually a good thing. We don't need wires coming loose inside a dryer. If you are able to get a good grip on the wire lugs with a pair off needle nose pliers, I would recommend you give that a try. Try not to grab the wires. Grab the lug itself. Slowly rock the lug back and forth sideways as you gradually pull. It should come off. Are you attempting to replace the thermal cut-out? If this is the TCO or High Limit Thermostat, you may be able to remove the back of the dryer and get better access that way. Let me know if this helps.
  • Mshi320 Feb 13, 2011
    I got the front panel off, cleaned inside and put it back together and now it makes a high pitched whirring sound. everything's back in place. Any ideas
2 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: how to remove the bottom front of a kenmore dryer
Check this video out: HOW TO
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Feb 04, 2010
How do you take off toe panel from he3 electric kenmore dryer to clean plugged lint
Hello;
My name is Peter. I am a retired field service appliance technician.
There are two spring clips, one on each side of the bottom toe plate panel.
Dec 02, 2014 | Kenmore Dryers
How do you get the bottom panel under the door of the dryer off? It looks like there are clips of some sort there, but can't remove or move the clips enough to remove the door? please give step by step...
Unplug the dryer before attempting any repair works.
The bottom front panel is secured to bottom of the top front panel by two securing clips. Insert a flat-bladed screwdriver between the top front panel and the bottom front panel as shown then pry the panel out then lift it off the cabinet.
Install the bottom of the bottom front panel first when reinstalling then push the top back into position until the clips engage.
Aug 21, 2010 | Kenmore 62982 Electric Dryer
How do you remove the front of the kenmore 80 gas dryer
You need to remove the panel at the top, then you remove the top, then the front, screws for front are inside of dryer. Go to www.appliancepartspros.com and put in your brand and model number. It will pull up all parts for your dryer including schematics that you can enlarge and print of the whole breakdown of you dryer. This will really help you to take apart and put together. Gas coils are at bottom under drum.
May 07, 2010 | Kenmore 72062 Gas Dryer
I have a Kenmore Stacked washer/dryer that was given to me. The dryer has a pretty loud sqweek. Is this normal?
A loud squeek is normally caused by the tension pully or the rear drum rollers seizing. Remove the two screws holding the inspection panel between the washer and the dryer. Remove the panel. Slide a 1/2 inch paint scraper between the top and the cabnet front and releave the spring loaded clips that hold the top on and remove the top. Loosen the two screws at the bottom of the dryer front panel. Looking down inside the front panel remove the two screws holding the front panel to the cabnet. Mark and remove the wires going to the door switch and remove the front panel. At the rear of the dryer remove the inspection plate at the bottom of the dryer and remove the belt from the spring loaded tension pulley. Go the the front of the dryer and remove the dryer drum and belt. Now you can check to see if the rollers are worn or seized and check to see if the tension pulley is seized.
Purches a kit that includes a new belt, drum rollers and tension pulley and replace all. Reassemble the dryer in the reverse as to how you took it apart.
Jan 30, 2010 | Washing Machines
I have a kenmore 80 series clothes dryer and i have to replace the blower wheel. Do ihave to remove the motor and if i do, how do i do it?
you do not need to remove the motor but you do need to take the front of the dryer off the door and front panel come off one of 2 ways. Ckeck at the very bottom of the dryer front panel if you have 2 screws there take them out and lift from the bottom carefully. Disconnect the two wires that connect to the door switch and un hinge the top from there you should be able to see wht else you'll have to take apart. If you don't have those two screws, then you have to pry the top up with a wide flat screw driver about an inch and a half in from edges from there look inside the front panel toward top and take out 2 screws and pull top of front out disconnect door wires and lift out. Good Luck
Mar 01, 2009 | Kenmore 63942 Dryer
Kenmore dryer help?
Sounds like motor is stalled. Remove the lint filter, look inside down toward the bottom left corner at the blower wheel. Something may be jammed in the blower wheel. If difficult to see, TURN OFF POWER TO MACHINE, remove bottom access panel. 2 to 3 screws on bottom of panel. Remove lint housing (3 to 4 screws) and inspect blower wheel for debris.
May 27, 2008 | Kenmore Elite HE4 Electric Dryer
I need to clean out the dryer duct and inside.
You just need to remove the two small bolts at each bottom corner of the panel.
Sep 16, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore 84052 Dryer Logo
2,809 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
