Lost document i lost a word document that was not saved, is there any way to get it back?
    Brigadier General:
  • 6,966 Answers
You can try:
1. go to your "Recycle Bin" and search for any semblance of the document. The filename maybe different as well as the extension. You can try use Notepad to view the text contents or even MS Word if allowed;
2. go to your c:\Documents and Settings\"your username"\Local Settings\Temp. Do the same as in #1;
3. Use a file recovery program. Do a Google for freeware. A good one (though paid) is GetDataBack.
Since it was not saved, you might be able to only recover part of the contents (if ever).
Hope this be of help. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Feb 07, 2008
How can I recover a PPT file that is unsaved?
Try opening up PPT and going into file>open>recent or something similar. PowerPoint generally has pretty good autosave or recovery options these days (if you have the latest version)
Feb 01, 2018 | The Computers & Internet
I can't find my auto saved document
Step 1:
What sort of document IE: word , excell , office ......
Microsoft Word's AutoRecover feature periodically saves your document while you're working in it, even if you forget to save it manually. If you close the document accidentally, Word closes improperly or you unthinkingly write over a document or change something important, this function can save you from losing all your work. Although Word doesn't AutoSave constantly, it might have automatically saved your lost document more recently than you manually saved it. Word 2010 makes this rescue process even easier than earlier versions of Word; it stores all recently AutoSaved versions of your documents under the "File" tab.
Open the document for which you lost information. For example, perhaps you were working in a document that you had previously saved, but then Word closed and you lost your most recent work. Click the "File" tab. Click on the most recently AutoSaved version of the document under the Versions heading, next to the "Manage Versions" icon. An Untitled, Unsaved Document b> Open Microsoft Word. Even if you never saved the document, and you can't find the file on your computer because you never gave it a name, Word might have saved a version of it. Click the "File" tab. Click "Recent" on the left column of the File screen. Click the "Manage Versions" icon at the bottom of the middle column. On the drop-down menu, click "Recover Unsaved Documents." Word presents an Open dialog box, taking you directly to the Unsaved Files folder that Word automatically created. Click on the document that you want to open, then click "Open" at the bottom of the dialog box. Click the "Save As" button on the yellow bar that appears above the document, below the Ribbon; in the pop-up menu, give your document a name, choose its storage location on your computer and click "Save."
http://office.microsoft.com/en-us/word-help/automatically-save-and-recover-office-files-HP010354296.aspx?CTT=1
Mar 10, 2013 | Microsoft Office Professional 2007 Full...
Looking for word document I did not save
The power just went out while you working on an important document you forgot to save.
Do not panic because Microsoft Word comes equipped with a feature that automatically will recover files you did not save.
Typically, this feature works by default.
The program allows you to change how often Word saves your documents and you can adjust the location where Microsoft Word saves these "Auto Recover" files.
Open up Microsoft Word.
Do not click on a file to open the program.
Instead, open the program by double-clicking on the program's icon.
Allow the program to load for a couple of minutes before clicking on anything.
Look on the left side of the screen.
If Microsoft Word recovered the file, a "Document Recovery" task pane will load.
Find the file's date.
Double-click on the file in the "Document Recovery" pane.
This will open the file in Microsoft Word.
Click on the "File Menu" and select "Save As."
Save the document as a ".doc" file type, and type a name for your document in the "File Name" box.
or
Open Microsoft Word to determine if the program auto-recovered your document.
If your software is set to auto-save your document every couple of minutes, when the program is restarted, any document that was not saved prior to closing, may appear in the auto-recover window on the left side of the screen.
Click on your document, and the last-saved file will open.
However, anything you typed after the last auto-save is gone, but at least you haven't lost the entire document.
Search the auto-recover files manually if the auto-recover pane did not appear when you opened MS Word.
Click the Start menu at the bottom of your computer screen, and click "Search." Some operating systems have the search option as a part of the Start menu.
Search for "*.asd" to search for any recovered files.
If you find the file, open Word, and click "Open" in the menu.
Search through all files, and locate the file that ended in .asd. Click "Open" to view your file.
If you are using Word 2002 or 2003, you need to restart your computer after clicking "Open." Re-open Word after your computer re-boots to view the recovered file.
Check your backup files.
If you have the "Always create backup copy" option selected in Word, you may be able to find a backup copy of your document.
Find the location where you last saved the document.
Check for the extension .wbk.
If there aren't any, search your whole computer for files with that extension.
Open your file by clicking "Open" in Word, and search all files for the .wbk extension.
Once you locate the file, click "Open."
Look in the temporary files on your computer.
Complete a search for files that end in the extension .tmp by typing "*.tmp" into the search box.
Narrow the search down to specific dates of when you were working on the document.
If the file does not show up, try searching for the "~*.*" convention.
Some temporary files are in this format instead.
If your document is now in your temporary files, you will need to recover the damaged document.
Search for it within Word.
Click "Open and Repair" when you find it.
Hope this helps
Nov 06, 2012 | Computers & Internet
My laptop just lost its document which are very important eg denali. all documents saved are no longer there,pliz assist.
could you please explain how it lost as we need to know if there was a hard disk error or a virus problem. The reason of loosing the document would help much on finding the method to recover it... Good Luck.
Jan 07, 2011 | LG Computers & Internet
Lost docs to be printed?
if u had saved the documents u will find it in my documents
thats located ... start> and u will see my documents
Feb 07, 2009 | HP PSC 2355 All-In-One InkJet Printer
I need to crash my acer 5100 laptop so i can reboot it to the factory state
no need to crash it, j
ust save your important documents on an external drive (or a USB flash), restart the computer, when it is booting click and hold ALT+F10
this will initiate a restore procedure to original factory state, remember all documents and files will be lost, so back them up externally before you do this
Nov 04, 2008 | Computers & Internet
Making changes to an old file - save - error -43 ( file not found )
Just downsave the document to one lower version and it should work
Jul 11, 2008 | QuarkXPress 4.1 for mac
Ms word password break
Yes, that can be possible & of sure with the help of this Office Password Tool, which can automatically find your forgotten password for protected Office Word doc, Excel spreadsheet, PowerPoint and more. No matter the document is password protected to be opened or editing, will help without any problems.
Best regards and good luck to you! - Seli.L
Feb 04, 2008 | Microsoft Word for PC
Lost items in Quark 6.1
the only way to get the text back is to import it again
Sep 20, 2007 | Quark Academic QuarkXPress 6.1 for PC
Computers & Internet Logo
Alun Cox
David Payne
David Payne
