Question about Whirlpool Duet GHW9150P Front Load Washer
Washing machine slowly fills with water when off
After cycle is complete and clothing is spun dry, machine starts filling with water again... HELP
miryryan@gmail.com
    Genius:
  • 1,554 Answers
Its likely the diaphragm on the water valve is clogged with hard water deposits and is leaking.
You can try to fix it by running some CLR cleaner through the water hose with it disconnected from the tap. or just replace the water valve.
a symptom of this issue is that water is always filling the machine. and you have hard water.
you can get to the water valves and take them out and replace/clean them by removing the top cover (3screws in top rear)
unplug the AC cord.
follow the water hose from the tap the first dual block you see has 4 wires and the hoses plastic connected to it. easy to remove.
But if the machine is not leaking all the time and the machine just wildly decides to activate the relays for water ( you will hear the solenoids click for more water flow then the issue could be the computer control unit.
Posted on Feb 13, 2008
LG Turbodrum DD 8.5kg WT-R852 washing machine, will not completely fill with water to water, to initiate the wash cycle, wash process stops there.
THE WASHER IS OBVIOUSLY HAVING A PROBLEM DETECTING THE WATER LEVEL? IT DETECTS AS FULL WHEN ITS NOT AND THEN GOES INTO DRAIN CYCLE? THE FILLS AGAIN? I would suspect the water pressure switch but if it was detecting a full cycle it would sent it into wash cycle? the water inlet valve only allows the amount of water it is told to send in and does not control the amount or drain cycle. Im not sure here but Im thinking maybe the water level switch may be flawed, the one that has low-medium and high? all these can be checked with a multimeter
Mar 01, 2015 | LG Washing Machines
Indesit wie 147
I think you have to fill it with water first. My machine won't work unless the previous cycle has a chance to complete. i.e., it has to fill with water before the wash cycle starts, or it has to have water before it rinses/spins dry.
Mar 14, 2014 | Washing Machines
Washer completes cycle 100% but then it restarts and starts filling all over again/ rewashes in essence
Dear William, I guess first you have to check if the start switch is shorted. When you turn on the machine, does it automatically go into cycle? If yes, then your start switch is faulty. Otherwise, you may have to replace your timer/sequencer.
Jan 16, 2014 | Washing Machines
Hoover 500m top loader washing machine fails to stop at 'OFF'
timer and dont think u can get them any more
Jan 18, 2013 | Washing Machines
Stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Jan 05, 2009 | GE Profile WPRE6100G Top Load Washer
WF860 drum filling with water
Normally I would think that the problem is with the drain system (faulty pump or clogged lines), but you told me that also "When the washing machine is not bein.g used the drum slowly starts to fill with water!!" therefor I think it can be a dafective inlet valve or a faulty control assembly.
In either case, you will need a technician to fix this.
Dec 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Drying cycle ma;function
The problem lies with the water valve at the water entrance area; trace the pipe from where the water comes to dispenser. This should be done after opening up the top ( careful not to touch any part which could give you electric shock or anything) The pipe where the water gushes should be traced back to the inlet area, you will have to change this valve. To see the gush gently open the dispenser drawer.
Nov 27, 2007 | Malber WD1000 Front Load Washer/Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
237 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
