ASUS MyPal A636
Problem for ASUS MyPal A636
It keeps turning off when it's not at the cradle.
By Minhyung on Feb 07, 2008
So, I purchased new battery, but it still keeps turning off.
I suspect that it's not getting power from its battery due to some reason.
Any hint? Where should I go to fix this?
Same Problem
Jan 28, 2009
-   My PDA is turning off while working , the screen goes off .
when I pressing power switch the display turn on for a 2 sec and off again . I do it for 2 or 3 times , then I can continue work.
I had replace a new battery but it is still has that problem.
Thank you-   Tzur
Best Solution
posted on Jul 23, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Is the battery got a tight connection to the pins in the device? Try jamming it in with paper. Mine had the sae problem when it tried to use the SD card. When I jammed in some paper to make a closer connection it worked.
Popular Solutions for ASUS MyPal A636
Questions and Unsolved Problems for ASUS MyPal A636
Do you recommend ASUS MyPal A636?
Answer
Answer
imate jama 201 only blue screen
Answer
old Compaq PDA will not hold a charge. Could be the stand or battery. P/N SPS Model 3870 Does anyone... (More)
Answer
i m using htc p3400i.2day i ws nt able 2 access my storage card...memory ws occupied bt files were... (More)
Answer
why the volume is too low in the incoming and outgoing calls in my htc shadow?
Answer
My stylus tip broke off. I glued it back together, but when I inserted the "fixed" stylus... (More)
Describe your PDAs problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PDA Experts
Top Computer & Laptop Repairmen
in , PA
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
