Question about Kodak EasyShare CX7330 Digital Camera
Broken lcd lens
Kodak camera lcd screen is broken inside. also the lens shutters don't open wide up anymore when you turn on the camera. not even 12months old yet.
are they both fixable and approx what cost am i looking at? worth while?
    Genius:
  • 1,226 Answers
In this case, since im very far from you, i would rather suggest you to go to the vendor of your camera maybe the have replacement part of the lens and let their tech do it. IN case they don't have, then i am sure they know the service center of your camera. about the cost i can't tell you i have no idea.
May this help, melnavz
Posted on Feb 07, 2008
Lcd screen does not show scene and photos are all black. can anyone help?
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 22, 2011 | Kodak EasyShare DX7630 Digital Camera
My sons kodak easyshare cx6230 only takes black/blank images. Screen works, but all photos taken are black. Suggestions please?
Oct 06, 2011 | Kodak EasyShare CX6230 Digital Camera
Kodak M1033 LCD black. entire images on SD black. It powers on and makes audio. Flash works as does the the green light. In other words it seems everything works except viewing, taking, and saving...
It might be easily fixed. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 12, 2011 | Kodak EasyShare M1033 Digital Camera
When i take the picture there are no lines but then when i see them in the lcd screen there are lines and when i upload them into my computer the pictures still have lines
The shutter inside lens doesn't work, it could be a broken shutter cable which happens to break on this model (also V803). It is a well known problem and the only solution is to replace the shutter unit or whole lens unit. You will have to contact Kodak. It might be cheaper to buy a new one (at least in the USA).
I work for Kodak.
Tom
Mar 07, 2010 | Kodak EasyShare V1003 Digital Camera
LCD screen is black-cannot take photos
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help: http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 16, 2009 | Kodak EasyShare CX7330 Digital Camera
The Same problem
I'm not sure why this works for me, but I think it's worth a try:
1) First, take your SD card out of the camera.
2) Then turn on your camera and let it turn itself off.
3) Read the next step first and be ready to press the shutter release button (take a picture) right after the LCD screen turns on
4) With the camera lens pointed down towards the floor (aim down), turn on the camera. At this point the LCD screen should not be blurry anymore. Immediately press the shutter release after confirming that the LCD is not blurry. If the camera stays on and you can review the picture (most likely of your feet), then you are almost done.
5) Turn off the camera and re-insert your SD card.
5) This may not be a permanent fix, but point the camera lens downward whenever you turn on the camera. It should work normally if you do this. Mine worked normally (meaning I don't have to point it downward when I turn it on) after doing this several times. Your results may vary.
Jun 05, 2009 | Kodak EasyShare M1033 Digital Camera
I have a kodak m1033 turns on then shuts right off
May 18, 2009 | Kodak EasyShare M1033 Digital Camera
Shutter stuck open/mirror locked up
merry christmas! :) Your shutter is broken.
Apr 01, 2009 | Photography
Kodak EasyShare DX4330 - shutter does not open
the problem seems to be the lens assembly, the electromagnet for the shutter does not work because the tiny film-wires are broken from wear and tear when you are zooming in and out
i corrected the wires myself but i am having trouble assembling back the lens, hope that helps all of you! it's a flaw in their design! (or not! :))
Jan 01, 2007 | Kodak EasyShare DX4330 Digital Camera
Kodak EasyShare CX7330 Digital Camera Logo
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
