Question about Telex AUDIO DUPLICATORS: Mono 1-2-3 Single Dual Cassette Deck
Telex copyette 1-2-3 you can hear both sides at the same time
I use the telex copyette 1-2-3 tape duplicator for church services and we've had the deck for about 18 months. I don't do a lot of heavy duplicating, but sometimes I do get a lot of orders. It's worked fine up until recently. When you playback a copy you can hear side A loud and clear but you can also hear side B muffled at the same time. Its been a long while since I messed with tapes but it sounds like that favorite cassette that you used to play all the time right before it got to the end of the rope. HELP PLEASE! LOL thanks
  • 579 Answers
Clean the heads, oil the spindles.
Basic problem is the tape alignment is off a little. Could be caused by too much tape tension causing it to wander.
Hope Ya Fix It. So ya can spread the word!
Posted on Feb 10, 2008
Telex Copyette 123, getting different speeds when duplicating audio tapes.
You might be able to find someone to work on it but there is no parts support and not many people want to work on them for that reason.
Jun 29, 2016 | Telex Audio Players & Recorders
Telex Copyette 1-2-3: Master well wraps tape around the capstan.
Tape wrapping on a capstan shaft is commonly due to a sticky pinch roller or capstan shaft but is also because the take-up reel table does not provide enough torque or tension to gather up the tape. The Teac MTT160 cassette is a test tool we use to determine what the deck is doing torque wise. Telex probably has something similar. I worked with a guy who worked at Telex in the tape business- He did not talk about them much but he did say they had a lot of belts in them. Maybe you are just dealing with a belt that needs to be replaced. Lubrication also tends to be needed at every rotation point as well. That would include reel tables. I hope this gives you some help as Telex repairmen are getting to be like Hens teeth.
Aug 24, 2012 | Telex Copyette 1-2-3 Single Dual Cassette...
Meaning of facimile
fac•sim•i•le (f k-s m -l ). n. 1. An exact copy or reproduction, as of a document.
adj. 1. Of or used to produce exact reproductions, as of documents.
May 31, 2012 | Telex Stereo Copyette EH 1-2-1 Single...
Everytime I try to copy a tape, there's a big noise on the duplicate ones, even if the recording level is zero! I cleaned the heads with alcohol, but the problem remains. I have a TELEX ACC-4000. Many...
Is this a big bass hum?
Are you in the USA?
These are all mostly pretty old units by now but pro equipment none the less.
It's got circuitry problems but may be worth repair as I'm not sure anything like this is made anymore.
Sep 21, 2011 | Telex Copyette 1-2-3 Single Dual Cassette...
Can I use this machine (telex copyette 123)to cancel old cassettes by copying a blank cassette onto three cassettes??
You should be able to do that with it, but note that this is a mono copying machine rather than stereo, so it may not entirely write over the existing recording if it is in stereo and the heads are in a slightly different position, but that would be the same for a stereo recorder too.
I think it will work, but really for decent recordings, I wouldn't recommend 'recycling' tapes in this way, they deteriorate fairly quickly.
Aug 10, 2009 | Telex AUDIO DUPLICATORS: Mono 1-2-3 Single...
Side A led volume indicator is low when duplicating tapes
This is not a PrintWise burner problem. I posted incorretly. Henry
Jan 29, 2009 | Telex PrintWise 2000i (2000I) Burner
Telex copyette
Mechanism is not switching probably due to slack belt(s)
Apr 12, 2008 | Telex Copyette 1-2-3 Single Dual Cassette...
Telex AUDIO DUPLICATORS: Mono 1-2-3 Single Dual Cassette Deck Logo
322 people viewed this question
Top Telex Audio Players & Recorders Experts
Ben Armstrong
Sam Palermo
Sam Palermo
jairo sanchez
Are you a Telex Audio Player and Recorder Expert? Answer questions, earn points and help others
