Question about Nikon COOLPIX L4 Digital Camera
Reading lens error on nikoncoolpix l12
Please help
Hitting camera on desk once has partial fix.
When camera's batteries taken out & then put back in and the power on button pressed to switch camera on, the lens extends out & the camera now works.
BUT when the power button pressed to switch camera off the lens retracts AND a "Lens Error" msg appears on the LCD screen.
Just have to take batteries out to remove msg & start again as above but WITHOUT hitting the camera.
Thanks
Posted on May 30, 2008
I got the same problem, I couldn't fix mine, but some people have had success by hitting it.
http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00CW3S
Posted on Feb 27, 2008
The lens on my coolpix l12 keeps getting stuck and the shutter cover will not close
the lens on my coolpix l12 keeps getting stuck and the shutter cover will not close
Jul 19, 2011 | Nikon COOLPIX L12 Digital Camera
MY NIKONCOOLPIX SAYS LENS ERROR WHEN I TURN IT ON
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
Aug 14, 2010 | Nikon COOLPIX L5 Digital Camera
Says lens error and won't turn off
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 06, 2010 | Nikon COOLPIX L12 Digital Camera
How can I solve write protected on memory card ?
If the error is actually that the card is write protected this will help.
You should see a small slide on the side of the memory card.
Slide it towards the top of the card, the top being where the 45 degree cut is.
This is the card write protect slide.
Jul 10, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
TURN ON CAMERA THE LENS GOES IN AND OUT JUST A LITTLE THEN SAYS LENS ERROR
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 21, 2009 | Nikon COOLPIX L18 Digital Camera
Lens Error, Restart
Nikon System error help????
Sep 05, 2008 | Nikon COOLPIX L12 Digital Camera
Nikon coolpix l2
I had this issue and I read on the net to hold the lens down on a table of some sort and apply slight pressure while pressing the power button, it should go right back in, It did for me!
Jul 29, 2008 | Nikon COOLPIX L12 Digital Camera
Nikon coolpix l12 lens error
Dear All, Looking at other threads this seems a standard fault for many brands. I know the dreaded 'lens error' is a recognised Nikon fault.
I had the same problem with a Nikon Coolpix L1; lens would shuttle in and out rather woriedly and then get stage fright and freeze, hiding behind a lens error tag.
The solution came from a similar site to this and listed at least ten happy punters who tried it and found it worked, so, brace yerselfs....
Put a paperback book on decent sort of a table and slam the flat base of the camera down onto it as hard as you dare. If you slam and hold firm to the book it seems to give better shock without having to belt the poor thing to hell.
Worked first time for me. Not a cure, though. You'll have to repeat it every few months perhaps.
I suppose your camera may explode during the process; I decided mine was unusable as it was and so I'd nothing to lose.
If you break your wrist change to the other hand and don't slam so hard this time!!!
Before that I found some correlation between battery type, charge and lens function but the book bash was an instant cure.
Do let me know of any success
Apr 12, 2008 | Nikon COOLPIX L12 Digital Camera
Lens becomes jammed when taking pics.
this is the suggested way to contact them see the links on this page
http://www.nikonusa.com/template.php?goingto=inc_service
Jan 27, 2008 | Nikon COOLPIX L12 Digital Camera
Nikon COOLPIX L4 Digital Camera Logo
182 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
