Question about Samsung HCM4215W 42" Rear Projection Television
Tv wouldn't turn on, unplugged convergence board, turned on, replaced STKs, still have convergence problem
My Samsung HCM4215W stopped turning on. Went to turn it on one day, got no picture and heard high pitched noises and then the unit just wouldn't respond to the power button unless I unplugged it and plugged it back in. I think it was activating some failsafe or something so i didn't mess with it much more.
I found someone who was having similar problems and followed techman's advice and unplugged the convergence board and tried turning the TV on. It turned on just fine so I continued to follow the advice offered in that article and ordered replacment STKs and installed them.
The TV turns on with the convergence board plugged in now, but it has a dip in the middle (kind of like a U shape but very gentle). The green convergence lines are straight both vertically and horizontally and so are the red ones, it's just the blue that won't straighten out.
Time to order a new convergence board? Any advice? Thanks in advance.
P.S. it seems the STKs are getting really hot, really quickly, possibly more so than normal (i don't know how hot they're supposed to get). If that helps diagnose the problem any.
  • Aaron Galitzeck
    Aaron Galitzeck Feb 07, 2008
    powers on and red light flashes. Power supply? What is a good test to run to pin it down? The boards look ok, but I'm not very experienced with tv boards.
    Thanks for any input!! Aaron Galitzeck, Seattle WA.
    206 335 7363
  • gonzagarules Apr 16, 2008
    Hey there,
    I'm having the same problem with my set not turning on.
    Where did you get the tech advice on what to do?
    Also, where can I get a repair manual for the set?
    Thanks.
  • Samsung Master
  • 3,459 Answers
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Tv wouldn't turn on, unplugged convergence board,  - bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 22, 2010
Tv red light blinks off and on. Unplugged for an hour Tv worked for 10 monutes and then picture went to top left corner and got blurry. TV HAS BLINKING RED LIGHT AGAIN.
Replace Both of your convergence ICs one is bad ,but replace both STKs big black ICs also CK two resistors in same circuit 2.7ohms
Aug 11, 2009 | Samsung HCM4215W 42" Rear Projection...
Samsung 42" rear projection HD tv issue
pico fuses are those small on board fuses, usually soldered into place, that protect important parts of the board.
Feb 26, 2008 | Samsung HCM4215W 42" Rear Projection...
Blinking power light after replacing convergance board.
Your chips are most likely bad or you bridged the soldering.
For all others with similar convergence problems
This is a common problem.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 06, 2009 | Samsung HCM4215W 42" Rear Projection...
Red Convergence out on right side of the screen only
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
Dec 08, 2008 | Samsung HCM4215W 42" Rear Projection...
HCM4215W SAMSUNG TV TURNS ON AND TURNS OFF AFTER ABOUT 5 SECONDS
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 29, 2017 | Samsung HCM4215W 42" Rear Projection...
SAMSUNG HCM4215W Rear Projection HDTV shuts down
Low ohm resistors are open or poor solder connections on the bottom of a convergence IC.
You need to look at resistors in good light with magnifying glass. Bad ones may show as discolored or burnt.
The repair needs someone that has the schematic for the convergence cct, and can replace the burnt resistors or replace the whole convergence board.
http://calgaryconvergencerepair.weebly.com/index.html
If you are near Calgary, call me, if not, find someone that has done it before, preferably many times.
easyab
Aug 12, 2008 | Samsung HCM4216W 42" Rear Projection...
Samsung HCM4215W
Unplug the power.
Remove largest plug from convergence board. Plug in TV, see if it starts. If it does, then a convergence IC is are shorted.
Repair convergence
easyab
Jul 28, 2008 | Samsung HCM4215W 42" Rear Projection...
Tv wont turn on
Further, I've replaced the convergence board, but that didn't fix it either.
Nov 05, 2007 | Samsung HCM4215W 42" Rear Projection...
Samsung hcm4215w Convergence board problem
Use PANASONIC STK's.They are expensive,but they hold up!Safe,durable repairs require OEM or BETTER quality replacement parts.
Sep 27, 2007 | Samsung HCM4215W 42" Rear Projection...
Tv won't turn on
Your problem could be the Convergence board is loading down the power supplies and will not let the TV set come on, or the power/deflection board, part number AA94-08574A, or the STR type regulator IC, part number AA13-00105A. If you locate the convergence board, unplug the connectors, and see if the set will come on. if the set does come on, replace both of the STK convergence IC's at once. The part numbers for those IC's are STK392-40. You can get the original replacement IC's from MCM electronics for about 15 to 16 bucks a piece. Do not use the less expensive STK IC's as they are not the same. the replacement IC's should have the name of SANYO printed right on the face of the IC's. Good Luck
Jul 22, 2007 | Samsung HCM4215W 42" Rear Projection...
Samsung HCM4215W 42" Rear Projection Television Logo
134 people viewed this question
Henry  Thomas
Henry Thomas
