My washer/dryer sits in a enclosed back porch there is about 2 feeet of exposed pipes due to the cold weather a pipe burst i turned the water off at the main line replaced the pipe waited about 24 hrs turned the machine on it filled with hot water but now wont do anything else. is there like a reset button?
Try the Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse. or your motor coupling could have broken!
Testimonial: "easy to understand information; it helped with the trouble shooting thanks a lot"
