Question about Kyocera Mita FS-1800N Laser Printer
Message problem Could some one pls let me know what does it mean when printer says PersonE2:0040494? Thanks!
  • 30 Answers
Your error indicates that you have a problem somewhere between your engine board and your laser scanner unit. This is usually either the board, the unit or the wiring harness between the two. If you are comfortable with pulling your machine apart and using a multimeter on some points on the logic boards then you can find out which. If not then you will need to take it to a qualified technician. Sorry I don't have better news.
P.S just to explain the error to you the person is part of "call service person" the E2 Means Laser Scanner Unit (Polygon motor) error and the remaining numbers are simplye the page count of the machine.
Good Luck.
Please rate my advice, good or bad.
Posted on Feb 07, 2008
Brother dcp 7055 printer toner ended error
i haver Brother Laserjet DCP 7055 printer. Once i refilled its toner but now on 2nd time i refilled it the printer is gives an "Toner Ended" error & replace the toner message.... Pls help meto solve it... Thanks lucky bareilly
Jan 10, 2012 | Office Equipment & Supplies
There's a message appeared the minolta qms 9100 "disk & flash loader v1.1" what does it mean.. and pls. help to fix my minolta qms
Your soft ware that one the machine mite be corrupted. I don't know where you would go to get it firmware reloaded it is a Minolta Legacy machine using windows 95 or xp at best. Try konicaminolta web site.
Jun 03, 2011 | Minolta QMS PagePro 9100 Laser Printer
PRINTER mp145 is displaying E2 error message saying that no paper, how ever im not going to use printer, instead i want to use scanner but with E2 error message i cannot scan so pls give me one solution.
Do you mean E,2,2 indication? It means Carriage error.
Replace the following parts in the given oder
Timing **** strip film Logic board ***'y Carriage motor (Main unit) Carriage unit (Main unit)
May 15, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Pls we need your help with ricoh affico printer 3224C the screen of it write this message : used toner bottle setting error used toner bottle -2 is not set properly. open the part as shown and set the...
look my friend used toner means that this toner is disposal or exhausted ok ensure that empty exhausted toner not mean fresh toner are yo ander stand
Jan 12, 2011 | Ricoh Aficio 1035 Copier
Getting an E31 message on my KX-P4440 printer... what does it mean
It means "heater quartz lamp" problem and must be replaced. It's going to be hard because it pretty old.
pls. vote for better service. Thanks
Nov 12, 2010 | Panasonic KX-P4440 Laser Printer
Error message E00001*000
It means that you have fixing problems, try to enter the service mode * 2 8 * and under clear select clear err or all.turn off and on. If doesnt help you need to change the lamp or thermistors.
Pls. rate
May 10, 2010 | Canon imageRUNNER 2000 Copier
Change the batteries error message
your have to cheak your new batteries. cheak their model no with your old batteties
May 03, 2008 | Canon MF8180C Color Laser MFC Printer
"Replace Drum" message won't go away
pls install the drump properly if it is in correct position that mean printer need to be service.
Sep 27, 2007 | Panasonic KX-FLB801 All-In-One Laser...
Error code ##343
We have just attempted to install an Cannon imageclass mp360 and the error message "check printer ##343" is displayed.
Can you please help.
May 14, 2007 | Canon SmartBase MP360 All-In-One InkJet...
Kyocera Mita FS-1800N Laser Printer Logo
176 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
