Question about Car Audio & Video
Formula MACH-6000 nothing happens
I got this amp from a neighbor. I hooked it up and nothing happens. No power led, no nothing. I took it to a sound repair place and they said it had a blown channel and that it would cost 70$ to repair so I told them never mind. Is there anything I can do to repair this myself?
    Problem Solver:
  • 8 Answers
Well im not sure ifyou have seen into an amp case but its quite complicated if you havent got the electrical exprience as the pros do but it could be as simple as finding the blown component and replacing it however when something blows it doesnt mean that its visable, this is where either a multi meter or load tester comes into play, so yea it can be complicated.
I rekon if its a good amp it could be worth it have a look in google and find specs
Sorry this is the best i can do without looking at it
Finder066
Posted on Feb 13, 2008
My Friend put A Rockford Fosgate P250.2 Amp in his car and while hooking it up he forgot to connect the ground but still got power to the amp but no sound from the subs and the thermal light is on. so he...
Your friend has damaged his amp. The power light coming on means that the amp's power indicator LED is at least working. That light is only there to tell you that the amp is receiving power on it's 12 volt rails, not that it's necessarily using the power in any way other than warming up the amp's internal circuitry. When you say the amp gets power, I'm not clear on whether you mean the amp works in that fashion, or there's just a red LED glowing but nothing else happens. The amp needs to be repaired, and I would suggest to him to not apply power to it again until it is checked by a professional. The power supply has probably been damaged, and it's possible, depending on how the amp was mounted, that it was searching for ground through the amp's chassis if it was screwed into metal at its mounting location. All that seems certain as of now is that the LED works, but nothing else, unfortunately.
Jul 02, 2017 | Rockford Fosgate P3001 Car Audio Amplifier
I Have a 97 mustang gt with the mach system in and I am trying to install a deh-p3700mp into it. I have power but no sound can you help
could be as simple as hooking up the amp turn on wire, or wrong harness, or bad amps or blown amp fuses
May 19, 2010 | Car Audio & Video
Try to turn Dell Inspiron 6000 laptop and nothing happens. No lights, no sounds, nothing. Power chord is good and has output voltage of 19.5.
remove battery and then insert power cord and power it up. if it powers, then insert battery while laptop is on. otherwise, if it doesnt, get the battery charged from else where and insert it just to confirm that the power supply unit isnt spoilt.
Regards
Feb 13, 2010 | Dell Inspiron 6000 Notebook
Sub will drain all the sound off the front speakers
if you have both amps connected to the same power wire this will happen...run another power wire to the alpine and this should solve the problem.
Jul 25, 2009 | Rockford Fosgate Punch 301S Car Audio...
My 12v touched my ground last night and big spark happened
hello sound to me you may have burnt the main power wire to the body or other metal on the car ..
if i was you i would first check the fused if there not popped trace the wire from the battery to the amp see if you can find a burnt spot on the wire it should have a burnt spot on the ajasent part of the car.. untell you find that wire it will drain your battery "try to disconnect the amp wire from the battery recharge or jump start your car run your car for 20 mins" that should fix your car... www.tonytkokelly@yahoo.com if you have questions
Dec 20, 2008 | Solid Audio Formula Series F2000 2-Channel...
Amp wont turn on
New amp sounds messed up... grounds are bad and sometimes the amp tries to draw power but cant... So it immediately goes to protect... All jacked up... Audio specialist could help... Repair shop if local ..
Nov 04, 2008 | Kenwood KAC-9102D Car Audio Amplifier
Coleman Mach III 13,500 btu ducted roof air conditioner
Did you plug upper unit (on roof) into lower control unit (inside). Not to insult you, because i've done it myself, in a rush situation. Breaker on? Sure you didn't mix up any wiring?
Jun 29, 2008 | Coleman Mach III Air Conditioner
Power Problem, LED Lights up and then shuts off
Do you have the switch or activate wire on the new amp. to the right hookup? If you do, then theres a problem with the amp and if your not a tech these can be a difficult thing to trouble shoot. Take back the amp or seek out a pro to test it on a bench. Good Luck
Jul 24, 2006 | American Pro VS1405 Car Audio Amplifier
Car Audio & Video Logo
494 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
