Question about LG DLE2532W Electric Dryer
LG DLE2532W Electric Dryer doesn't allow adjustment of drying options
On our LG DLE2532W Electric Dryer, once we choose a drying cycle, the selected options aren't changable by pressing the buttons. For example, we choose the Normal cycle, but then can't set the heat to anything else (e.g., High, Med, Med Low). Dryer works perfectly fine except for this quirk. Ideas?
  • Faron Fowler
    Faron Fowler Nov 25, 2008
    I am having the same problem....also it will not dry worth a $#!%, I have to run at least two full cycles of more than 50 minutes each.
  • Anonymous Mar 29, 2014
    not heating
  • 92 Answers
It may be possible the contol is bad can you change the settings at all
Posted on Feb 10, 2008
I have an LG model DLE2532W dryer that is taking forever to dry our clothes. I have checked the continuity on the coil and it seems to be fine. I have also replaced the cycling thermostat. The heating unit...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 04, 2011 | LG DLE2532W Electric Dryer
Takes to long to dry clothes, we have cleaned the back of all lint
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Sep 06, 2010 | LG DLE2532W Electric Dryer
Does not dry clothes like is should, takes forever and does not get dry
Check for restricted vent. Could also be the cycling thermostat. There are videos at www.appliancehelponline.com/servicemanual.html that show you how to check. The video is for gas dryer but checking thermostats and thermal fuses are the same on both.
Feb 26, 2010 | LG DLE2532W Electric Dryer
My LG dryer takes two cycles to dry the clothes
check the dryer vent to make sure it is clear. is there any heat, if not the thermostat or heating coil burned out.
Dec 06, 2009 | LG DLE2532W Electric Dryer
LG dryer won't shut off - gets stuck at 6 minutes
Your problem seems to be the timer switch is faulty.
Timer switches are normally non-repairable. You would need to replace the faulty switch
Oct 04, 2009 | LG DLE2532W Electric Dryer
Where do i locate the heating element on my lg dryer
no fuse unless an electronic fuse on control board, check your element continuity, then the hi-limit switch then any cycling switches for proper continuity and operation
Aug 24, 2009 | LG DLE2532W Electric Dryer
I have an LG DLE2532W dryer and it takes hours to
the vent pipe is probably full of lint. pull the dryer away from the wall, disconnect the vent pipe and look inside the rear of the dryer and thru the vent pipe. remove any lint u find as it is a fire hazard.
Apr 21, 2009 | LG DLE2532W Electric Dryer
Dle2532 lg dryer, cooling light is always on
I'll take a stab that you use dryer softener sheets. These will deposit a coating on the two metal sensor bars (about 4 inches long, very near the lint filter inside the drum) which prevents the sensor from "seeing" that the clothes are still wet, so the dryer jumps to the cool down portion of the cycle. Clean the metal bars off and it should work again. (note: the bars are not in the cycle if you choose time dry instead of using the automatic cycles)
Apr 11, 2009 | LG DLE2532W Electric Dryer
Lg dryer
My LG dryer makes too much noise during dry cycles. What part do I need to replace? Do you have an online manuel? My email is drlofton@aol.com
Jul 30, 2008 | LG DLE2532W Electric Dryer
LG DLE2532W Electric Dryer Logo
271 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
