Question about Denon DRA-685 Receiver
Right channel not working
Denon DRA-685 receiver it is hooked up, yes balance is in the middle
  • 2 more comments
  • Big wally Feb 07, 2008
    this problem is happening on all functions. Receiver has worked fine until just recently. It did smell hot recently and I don`t know if it was exact same time right channel stopped working.The pre out/main is not connected to any other equipment. The receiver connects to a Niles SPS-6 speaker selection,all 6 sets of speakers work with same problem. I do not see a location of a fuse on rear of receiver for speakers. Do I need to remove cover on the receiver to locate this fuse? Thanks you people!!
  • thirdrockbs Jun 25, 2008
    i have the same problem only it is only on the left channel.
  • Anonymous Mar 16, 2014
    denon receiver blown right channel
  • Anonymous Mar 19, 2014
    The channels were hooked up to the same speaker and something fried. Just not sure what it would be.
    Sergeant:
  • 395 Answers
Check the pre out /main in jumper there should be a loop jumper for both left and right. if you are using a graphic EQ check the wires connecting to the receiver and the EQ. also is this happening on all sources?
Posted on Feb 07, 2008
  • Robert Johnson Feb 07, 2008
    Ok, if you smelled something hot that is a good indication there is a problem internaly. maybe a resistor has opened or circuit has opened (fuse). if a fuse or resistor has opened up there is a chance the right channel amplifiers have shorted. there is a simple way to check to see if the amplier is good, disconnect the left speaker then slowly turn up the volume and listen to the right speaker if you hear a soft hiss the amp is running the next step is to check the preamp cicuit and the input ciruit. if you don't hear the hiss the amp is bad. there is one other thing that might be the problem is the speaker relay. this is a double switched relay (one for left one for right). it may not be making contact on the right side. any way it's internal to the receiver.
    Champion:
  • 204 Answers
Hi....you may want to check the speaker fuse, located on the rear of the unit.. sometimes too small wattage speakers get hooked up and the speaker fuse will blow as to not hurt the speakers.
Hope this helps.
Squipps
Hi i have a denon dra 685 and when i hook up the speakers i barley get a sound out of it im thinking one of the channels may be out but is there a way i can reset the system as i was given the amp
Hello. My name is Dave. Does this unit have a tape monitor button? If it does, you probably have it switched on. Make sure you turn down your volume before turning the tape monitor off. If not a tape monitor, it may may another switched path that you have engaged. Same fix as above.
Sep 30, 2012 | Denon DRA-685 Receiver
What can i do to be able to take my denon dra685 out of protection mode??????
I just recently picked up a Denon DRA-685 receiver that was stuck in protection mode. I found a site online that suggested it was due to two bad resistors on the main circuit board. More specifically resistor R-105 and R-106. They are both 1 ohm x 1 watt resistors. I ordered these from a supplier on Amazon for a few dollars, and just snipped the old resistors off, leaving the soldered leads sticking out. I then thinned the new leads and soldered them to the protruding wires, so I didn't have to remove everything. The unit now works like new. I'm happy I spent the time doing this, and grateful to the tech who discovered the common problem with this unit. Hope this can help somebody else. H
Nov 14, 2010 | Denon DRA-685 Receiver
How do i hook up an ipod to a denon dra-685?
you can use a 1/8 inch female to stereo RCA adapter and plug the patch cable into one of your inputs like DVD or CD player. The signal to noise ratio on those inputs is pretty good.
Feb 03, 2010 | Denon DRA-685 Receiver
The standy light continues to stay on
My CD player does the same thing. i need to press the power off button 2X then it'll power off. If it keeps doing it the easy way to correct it is to hook all you devices into a surge breaker and power off the unit.
Apr 11, 2009 | Denon DRA-685 Receiver
Reset danon receiver
You don't all you can do is unplug it for 5 mins
Jan 25, 2009 | Denon DRA-685 Receiver
Connecting new tv to DRA-685
you can use the headphone jack just get an adaptor to change from the headphone type to RCA type. adjust the volume of the tv to 3/4 of the way to give line level to the stereo, use an aux input on the stereo. if you had a suround sound dolby digital / DTS receiver then use the digital coax out to that type of receiver, but since you have an anolog 2 channel receiver you must use the only anolog source (the headphone).
May 21, 2008 | Denon DRA-685 Receiver
Denon DRA 685
Could it be that the speakers load is too much for the amp to handle? What are the ohm ratings? It should handle a low load but I am just wondering? How effcient are they?
Nov 29, 2007 | Denon DRA-685 Receiver
Protection error
your loudspeakers tweeters have shortcut *try them separetly)
Sep 08, 2007 | Denon DRA-685 Receiver
Denon DRA-685 Receiver Logo
349 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
