Question about Canon PowerShot A530 Digital Camera
Canon A530 Is there a place in the menu to change the size of the picture being taken? I want it set to 4x6 and it seems to be set to 4x3...it cuts my pictures off when I print them out.
  • 1 more comment
  • Mhankes Feb 07, 2008
    I print through online sources and at photo kiosks at Target. If I crop it myself, I can make sure I'm not cutting anything important out...but that means I have to crop every picture to 4x6 or risk it chopping off a head.
    I use a PC
  • nsfbr May 11, 2010
    Unfortunately, the A530 only captures images in a 4:3 ratio.  So, we are going to have to find another way to get your images to print without losing portions of the image.  By the way, this 4:3 ratio is common in this type of camera.  It isn't until and unless you use a more expensive digital, like a d(for digital) SLR camera that you typically have a 1.5:1 ratio.  That is the ratio of 35mm film, which is actually a 24 x 36mm frame size.
    Can I ask you to post what printer you are using, what software you are using to print from, and what your computer operating system is?
    Scholar:
  • 33 Answers
The only way I know to help you is to suggest a software approach.  The reason I asked for your OS is to know whether or not a Mac solution (which I can personally vouch for) or a Windows solution (which I don't know for sure, but believe will work.
What you need to do is to change the images to that 1.5:1 ratio by adding blank white (or black, or whatever you want) to the long dimension.  This can be done easily using the batch capabilities of a program like GraphicConverter (Mac), Irfanview (PC) or Photoshop or Photoshop Elements (both).
If you are like me, then you want to save the expanded images to a new location with a new name.
If you tell me what software you have, I can give you step by step instructions for GraphicConverter or Photoshop.
A second alternative would of course be to find a place that can make prints in the same ratio as your images.  The problem is that this somewhat unpopular print ratio.  Oddly, it is a very popular image ratio for inexpensive cameras.
A third alternative approach would be to just take the potential cropping into account when you take the picture in the first place.  You could even place some tape over the parts of the LCD that will get cut off.
Please let me know if I can be of any more help.
Posted on Feb 07, 2008
  • nsfbr Feb 07, 2008
    Okay, here you go:
    1) Download Irfanview from here: http://www.irfanview.com/ and install it.
    2) Open the program and select the Batch Conversion/Rename function in the File menu
    3) In the window that opens, locate your pictures so that they show up in the rectangular frame on the right hand side. You can select them all with the Add all button, or select the ones you want and them add them using the Add button. There are several things to set in this window such as where you want to store the new files, etc.
    4) In the lower right section of the window make sure you have selected Batch conversion -Rename result files. Below that, there is a place to choose the output format, it should be JPG and a button to choose the options. Click the button and leave everything alone but make sure the quality is 100%. You may want to experiment with this later, but for now, this is the safest option.
    5) Now click the button to the far right called Set Advanced Options. EVERYTHING should be unchecked for now. Check the first item in the Miscellaneous section (lower right) under Canvas size. Then click the button next to it called canvas size.
    6) You need to figure out where you want extra space in your images. The numbers you will enter here depend on what resolution you are shooting at. If you are using the maximum resolution of the A530, which is 2592 x 1944 you need to make the larger size equal to 1.5 times the smaller, so that is 1944 x 1.5 = 2916, or 324 pixels larger than it is now (2916-2592=324). If I were doing it I'd probably add half of that to each side of the large dimension, but you can do it any way you want. So, if you are doing that, you will enter 162, 162, 0, 0 for left, right, top and bottom. Now, change the border color if you want, hit okay to return to the batch conversion window and you are almost done.
    7) At the very bottom of the window click the Set rename options or just type into the box. Use something that begins with $N which is code to keep the main part of the filename and then add something like - 4x6.
    8) If you are all ready, click the start button and in some small amount of time the program should make a whole new set of image files that are just like the ones you started with but ready to print without cropping at 4x6.
    This may seem like a lot of work, but Irfanview is free and once you set it up, it is pretty effortless.
    Have fun.
Proper settings for 4x6
Unless you have reason not to, stick with the Large image size (see "Changing the Recording Pixel Setting" on pages 70-71 of the manual).
The biggest thing to watch out for is that the camera takes pictures that are 4 by 3 in aspect ratio. That's equivalent to a 4.5 inch by 6 inch photo, so some of the top and bottom will be cut off when you make a 4x6 print. Alternatively, many photo places will give you 4.5x6 prints for the same price.
If you need a manual, you may download a copy at http://gdlp01.c-wss.com/gds/5/0300003855/04/PSSX130IS_CUG_EN_03.pdf
Mar 03, 2014 | Canon PowerShot Cameras
How do I take a picture with the date and time stamp in the picture
The date stamp only works in "Postcard" resolution. Press the "Func Set" button, then scroll down to the bottom to select postcard resolution.
Then press the menu button. Select the "Camera" menu, then scroll down to the the Date Time Stamp selection to turn it on.
Nov 05, 2009 | Canon PowerShot A530 Digital Camera
Hi there When I shoot in 16x9 widescreen with my Canon XL1 the viewfinder shows the same image as when shooting in 4x3. Can this be adjusted. Regards John
It is not showing the same image, it is showing the 16x9 squished down to the 4x3 aspect ratio. I thought I had the same thing at first too. But to check & make sure set up a shot of something square in one or the other shooting ratios. Then go into the menu & set it up on the 16x9 on/off. To make it easier to see the picture hook up to a monitor to see the picture without squinting through the eye piece. Now while you are watching the picture switch the 16x9 on & off on the camera. If you started in 16x9 the square will lengthen from side to side in 4x3, while the square in 4x3 will become squished on the sides. If you can't tell, take a piece of tape [removable tape that is] and make the sides of the box before & after you change the aspect ratio.
Apr 29, 2009 | Canon XL1S PAL Mini DV Digital Camcorder
Printing 4x6 photos on photo paper
Sorry but your question seems to be unclear.
Here are the solutions that I see:
- try fixing the orientation of your paper on the printer:
-- go to printer "properties" then select "paper" then set it to
landscape or portrait. You might just have to cut the extra
papers
- try changing the paper size on the printer "properties" if it has
no 4x6 then choose "custom size"
Jan 19, 2009 | Samsung CLP 300 Laser Printer
Embed Date-Canon PowerShot A530
The only way to have the Date directly on the photo is to change your picture size into postcard mode. do that by hitting function set, and going to the bottom of the options where you choose your picture size... after that do what you described above, however the option will not be greyed out... that will put the pictures directly on the photo... warning!! the reason they make it a pain in the rear is because it will be on all pictures all the time.. no way to remove after!!! you can get several photo programs that will let you insert the date on only the pictures you choose.. Or you can go somewhere other then walmart where the technicians aren't required to have them ready in an hour... yes.. speed isn't always best... and they should be able to choose it in there settings... because the Date is always in your file Data... just not being displayed.. Or go get a little photo printer and print the ones you want... average cost.. 30 cents.. a little more.. but you have the control!! and you don't have to burn and gas while doing so!! Cheers
Jun 09, 2007 | Canon PowerShot A530 Digital Camera
Will not print 4 x 6 prints
try to find the margin settings of the application that you are printing  with. If margins are setup in a wrong way it will print anywhere it likes.
Aso see the paper size. e.g. A4, A3 etc.
I think you should take a normal a4 paper and print it and see the size of the image and the size of the document that you have created.
Another way to test it is to copy the image(content) only and paste it in some other application like MS Word or something else and try to print it in 4x6.
If it is an image and you can copy it to MS Paint then do it and cut everything else (crop the image accordig to its' size), then print.
Remember to place the paper on the right hand side of the paper tray. (You can do the reverse also if it required.)
Sep 25, 2006 | Canon S520 InkJet Photo Printer
Canon PowerShot A530 Digital Camera Logo
85 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
