Question about Zanussi TD4100W Electric Dryer
Clothes dryer leaves black marks on clothes when taking out of dryer
  • 30 Answers
It could be rust stains coming from the tub of the dryer during the drying cycle. The only concern is that rust stains are usually brown streaks on the clothes. I'd check the to make sure there are no rust stains on the tub, check the seal of the door to make sure its still in good condition. The last possibilty could be a good cleaning of the dryer (removing lint from the lint screen compartment and the tub of the dryer).
A schematic of your dryer can be found on www3.sears.com and should show how to get into your lint screen compartment and your tub.
Posted on Mar 08, 2008
agitateme
  • 88 Answers
SOURCE: Dryer is leaving brown streaks on cotton clothes
The 417 dryers have two seals on the front panel, the top seal has drum glides which wear down over time. Because the drum rests on those glides, when it wears down it leaves a gap between the drum and the seal, clothes will drag in that gap and come out with rust and/or seal adhesive stains. Try replacing the top and lower seals, this works most of the time...sometimes though, if left unattended long enough, the lack of support from the front glides causes too much strain on the rear drum bearing, and even after replacing the seals clothes may still catch, although the brown spotting will stop for awhile. You can feel the gap if you run your hand along the inside of the drum at the seal point.
Posted on Jan 17, 2008
jsrock516
  • 5911 Answers
SOURCE: black marks on clothing at completion of drying cycle
Is the residue coming from the back or front of the drum? Most dryers are equipped with 2 drum roller supports in the rear under the drum. You may have a drum roller that is going bad and some of the rubber residue is getting past the drum seal. Some dryers are quipped with an additional pair of drum rollers under the front of the drum as well. I would check all the drum rollers to see if they are all in good shape. A definite symptom of a bad drum roller is finding black residue along the outside of the drum where the rollers ride. You will have to open the dryer cabinet to see the outside of the drum. Also, check the rear drum seal to make sure it is not crimped or folded inwards in the drum. The felt seal in the back should should ride evenly all the way around the drum and should not be that visible inside the drum itself. That is, you may see some of the seal, but you shouldn't see part of it folded inside the drum or bits of it tattered or torn. I hope this makes sense to you. Let me know if this helps.
Posted on Jul 06, 2007
docjohn174
  • 943 Answers
SOURCE: Dryer Leaving Burn Marks On Clothes
HI thanks for your question. the problem with your dryer, is that the front felt bearing is worn. and dropped the drum a bit and clothes getting caught. replace the front bearing and the back bearing. not too expensive. thanks the appliance doc. please rate my question. thanks.
Posted on Oct 09, 2008
  • 10865 Answers
SOURCE: My dryer leaves burn marks on the clothes. What
Hi. Thanks for using fixya. I can help you. When clothes get marked or torn in your dryer, check these: Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it. small_8_13.jpg
Posted on Nov 09, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Maytag dryer is leaving black marks or rings on clothes
If your clothes get marked or torn in your dryer, check these: Rollers Rear seal Front glides Front seal Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Posted on Aug 01, 2010
Leaves black marks clothes
Are we talking tumble dryers here as it's been posted under the 'washing machine' section?
Anyway all depending on what type of dryer you have, normal vented one (with outlet hose that you stick out of the window) or a condenser dryer? Get back to me I may be able to help you with this ok, cheers, Ken.
Mar 11, 2014 | Hotpoint Dryers
Dryer drys great. is leaving black marks on clothes
Are the black marks a result of an ink stain in the drum or is the black marks coming for the dryer seal?
If they are coming from an ink stain then alcohol or hair spray with paper towels will normally get them off the drum.
If the black marks are coming from the seal, that means that the seal is not positioned correctly and would require that the dryer be disassebled and a new seal be installed.
Jun 18, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag gas dryer about 10 years old leaving black smudge marks on clothing. The wheel was hanging up on the dryer drum. Could there be other causes for the smudge marks?
your clothes are getting caught between the drum and the rim due to bearings out of the wheel guides. These guides are what the drum rests on when it is turning. Most dryers you can access these guides by taking the front off the dryer. Not a big expense just a little difficult to get to .
Apr 12, 2011 | Dryers
Aug 01, 2010 | Maytag Dryers
Dryer leaves black marks on clothes
Front bearing assembly or just the slides. Easy check is open the door reach in and push up in the front if the drum has play replace bearing assembly or maybe just get away with the slides if it hasn't eaten in to far. To replace watch the video at www.appliancehelponline.com/servicemanual.html
Feb 26, 2010 | GE Dryers
My dryer is leaving black marks on clothes, how can I fix it?
if you left a marker or ink pin in the dryer. then take a flashlight and look inside.if it is a mark then take a rag with a little fastorange handcleaner,and wipe on with small amounts. then take a clean paper towel and dampen with water and wipe all of the hand cleaner.thanks karl
Dec 02, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer is leaving black marks on cloths.
was a pen or crayon placed in the machine by mistake ? You will need to
remove the residue, use rubbing alcohol on a rag for marker or pen ink , crayon use a razor scraper and then clenser and scrunge pad.
Oct 26, 2009 | Fisher and Paykel DE06 Electric Dryer
The dryer is squealing and leaving burn marks on the clothes
Squeak is caused by a worn out roller rolling metal to metal - Most dryers have rollers, felts and drum slides to balance drum rotation:
When rollers wear off, black powder leaks to rear felts and black marks are left on clothes.
Same thing happens when drum slides wear off (black marks are left on clothes)
Aug 15, 2009 | Frigidaire Dryers
Dryer Noise & Black Marks On Clothes
Most likely the front drum bearing part number 5303937139 needs to be replaced. Instructions come with the kit.
May 31, 2008 | Frigidaire FDE336RE Dryer
Zanussi TD4100W Electric Dryer Logo
555 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Marvin
Marvin
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
