Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Door partially opens in cold weather
Problem 1 My Chamberlain door openers (both) open the doors partially and at random heights in cold weather conditions.
Problem 2 Both brackets which connect the doors attached to the openers have pulled away from each door. The panels have cracked from apparent metal fatigue. Is there a repair for this damage? Should there have been some type of mounting bracket to keep this damage from occurring? One more bit of information, a metal bar is attached to the top panel. The self tapping screws are offset by 1/8 in due to the fact that the bottom screw goes through this bar while the top screw in this bracket is directly attached to the top panel. This may have caused some flexing in the panel.
Should there have been some reinforcement in the top panel to prevent this damage. FYI the doors are CHI.
Thanks,
Mike
    President:
  • 4,402 Answers
I would contact CHI
Posted on Feb 20, 2008
When it is cold, my door will not open completly. I have to stand by the door and activate the remote and as the door rises, assist the rise of the door manually.
There is a couple of torque setting controls on the door opener itself..it seems that when the weather gets too cold that the grease inside gets thick and the unit will not complete it's cycle. you can adjust these torque settings to increase the torque to get it to open the door completely
Dec 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
The door only opens partially and then stops
IF THE DOOR WORKS WELL MANUALLY.
ADJUST THE UP SENSITIVITY ABOUT 1/8 TURN AND TRY AGAIN.
HOPE THIS HELPS
Jun 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Have a Chamberlain liftmaster professional 1/2 horsepower garage door opener that is only opening 6-12 inches and then stops. Just started in cold weather. If I keep retrying it, the door will eventually...
if you can open door Manually- find the FORCE adjustments-Not Travel. These might be "blue" in color. Increase the UP slightly. this adjustment in the cold weather is due to door hardware dry, lube rollers/hinges with wd-40 while door is down, lube every 30 days, keeps it moving quietly...
Jan 04, 2010 | liftmaster Chamberlain Garage Door Opener...
My garage door opener fails to send the door down when the weather is cold. It works when it is warm. Any suggestions?
I live in Florida, my spring broke when it got cold. The repairman said that the coil spring has to be lubricated frequently, especially when cold. Try spraying it down with silicone or wd 40 and see if it helps. You could also save the spring from breaking.
Dec 30, 2009 | liftmaster Chamberlain Garage Door Opener...
Cold weather. Opener lifts door ~8
If there is any grease in the tracks clean it all out. On the rear of your motor unit you will find the 'up force' control. Turn this about 1/4 turn and try. You also should take a good look at your door springs and make sure one isn't broken. Release the door from the opener and open it manually. Shouldn't be heavy and should stay when released about 1/2 way up.
Dec 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener will not close in cold weather
The are two knobs on the back of the opener. They are force settings. One is the upforce and the other is downforce. Turn both knobs to "5" and try. This should take care of the problem. They come from the factory at 1 or 2 and when it gets cold it takes a little more force to cloce the door.
Jan 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage overhead door will not go up in cold weather.
Pull the opener release rope and try yto open the door if it open hard the springs need adj. or door is binding in the track. if it opens easily then adj the lifting force setting on the opener
Dec 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener
You can turn up the up and down force on the motor head to give the unit more power. During colder weather the unit needs more power. Afterward do a 2x4 safety reversal test. thanks, BB
Sep 14, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
242 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Marvin
Marvin
richie46
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
