Question about Car Audio & Video
Easy fix one of my channels dont work but when i mess with gain knop it cuts in and out
  • 2 more comments
  • briguy234 Feb 07, 2008
    thanks
    thanks to all
  • toddgilbert Feb 12, 2008
    when i mess with the gain knob my sub comes back in, but with being left alone it cuts out
  • Anonymous Apr 19, 2009
    one ch dont work
    Problem Solver:
  • 6 Answers
Sounds like the potentiameter has gone bad. Relatively easy fix if you can solder and have access to radio shack (or maybe a slightly better electronics shop). Take the old one in with you. Will probably cost less than $10.
Posted on Feb 07, 2008
Rear left channel makes my speaker pop cuts in and ou at certain settings
Swap left and right speakers. Does it stay with the speakers if so you have a blown or damaged speaker. If not then swap input cables only. If it stayed with the speaker you now know the amp has a bad channel and needs repair. If it swapped again you either have a bad cable or issue with your source unit.
Jul 26, 2016 | Kicker ZX650.4 Multi-Channel Amp - 480W ZX...
How to remove selector knob from bosch hammer drill gbh 2-20 s
Take a little screwdriver under the knop and jump him out BUT be carefull there is a little metal pin inside the knob that can be loose and easy lost .
And important Jump out the knop (BEFORE) you have removed the 4 screws of the black house.
Jan 09, 2016 | Bosch Drills
How to setup a vocals
Turn gain CCW. plug microphone in, mute the channel. turn gain CW until peak LED flashes (while singing loud!) and turn gain back a little bit.
Take the channel fader down, unmute the channel. Put masters at 0dB (near maximum) and adjust the loudness with the channel fader to what you like.
EQ: it always depends on your location. Keep it flat. You might like to reduce at about 200-300 Hz. Cut the low end (Hi Pass Filter = on) or if no HiPass reduce "bass" for about 6...10dB.
ok?
Mar 29, 2014 | Mackie 1604 Vlz3 16 Channel Mixer
Speakers cutting in and out at high volume
The amp is going into protect on the two channels powering the speakers. Turn down the gain on those two channels. You also may want to consider crossing over the speakers a little higher than they are now.
The rating on those speakers are way too high. 6.5's and 6x9's will take 50-100 clean watts tops before they start to break up.
The best solution to get it perfect is....unplug the subs. Turn the gain on the speaker channels all the way down. Then turn up the deck 80% as high as it will go. Play a song. Then increase the gain on the amp until the speakers are as load as they go without distortion. Shut off the car, replugg in the subs and do the same thing. Gain on sub channels all the way down, deck then to 80%, find a bass heavy song, then turn gain up until subs become distorted. If you do this procedure your speakers and subs will be "gain matched" to the proper levels.
Good Luck
Dec 07, 2013 | Kicker IX500.4 4-Channel 500 Watt Car...
My volume control box is broken, how do i fix it?
Just anyway to gain access to open the box is ok there is no easy way really remove the screws (If) it has any or cut an access hole to reattach the wires just dont damage the speaker is all that needs to be watched for. Remember to rate my solution
Apr 26, 2012 | Logitech X-530 Computer Speakers
Our 32fx mixer has intermittant channel faiures. The symptoms are the channel faders and tones controls stop working, but the audio continues to be routed to the LR outputs. The channel level can the...
Try performing a full firmware re-install, or update if your not already on the current firmware. Click on the "Downloads" tab to access the latest firmware. http://www.peavey.com/products/browse.cfm/action/detail/item/116194/32FX™.cfm
Mar 29, 2010 | Peavey 32fx USB 32 Channel Mixer
Ive got no power to the amp trough the rem wire unless i connect.
You need a bigger amp and make sure its a two channel. Four and five channel amps are for mids and highs. If you want real bass get a two channel. If you dont want to buy a bigger amp, Go get a capacitor. It acts like a battery charge storage for when your sub needs to hit those real low notes. It takes a lot of power. Also if you get a capacitor your altinater that charges your battery will not have to work so hard keeping your battery charged, Thus not wearing out your altinater and not having to replace it so soon because it will happen.
Another quick fix is turning your gain down. I turn my gain up half way, maybe a little past half way. You might not get the bass hitting as hard but at least it wont shut off on you.
Nov 20, 2008 | Kicker 01C8VR4 Car Subwoofer
PANASONIC KX-A144EXS
druk middelste knop ,nr verschijnt !
druk ronde knop rechts,
druk ronde knop naar beneden tot WISSEN verchijnt en druk dan ronde knop rechts en kl is kees
Sep 06, 2007 | Panasonic KX-T7730 Corded Phone
Car Audio & Video Logo
50 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
