Question about Canon i850 InkJet Photo Printer
Problem with colors in Canon i850
My printer (Canon i850) does not print any color but yellow and black. I checked the cartridges and they are all full. I also did nozzle check and the rectangles under the letters B, C and G did not appear. The only colors that appeared were: light blue, black, yellow and pink. I also used the regular and deep cleaning option but this did not change anything.What should I do?
  • Sonny Fields
    Sonny Fields Mar 03, 2008
    My i850 prints only in yellow and sometimes not at all. I have removed the printer head and let it sit in windex cleaned it well blew on all three ports and color would come out, rinsed it good in hot water and dried it good, replaced it to no avail.I even changed the ink in each color.
I found a solution My black was not printing every 1/2 inch. What I did was I took the print head out and removed the ink cartilages. This gets messy. The print head has two screws at the bottom. Remove those two screws and carfuly using a small screwdriver. pry the white peice away from the main body of the print head which is black. You will hear two snapping sounds. That is okay you are not breaking anything vital. The snapping is the glue holding the tan/brown ribbon cable to the body of the print head.
Underneight the white peice is a gray rubber gasket. Leave the gasket alone. Focus on the white peice this is the actual print head.
Hold the white peice up to the light looking thru print head screen
Eye ----> print head screen (tan brownish color -------> white plastic that was stuck to black plastic with gasket ---> Light source
Looking thru the print screen you can see any dried up ink pigment. If you do, this is causing the problems of skipping colors at regular intervals. Soak in hot water (not boiling) or iso alcohol. Using a compressed air source try and blow the pigment out of the screen. Then use a syringe to **** water or alcohol. thru the microscreen; syringe ( ****) -----> white part with holes for colors-----> microscreens -----> water or alcohol. If you do it right you should see a pigment clot in the syringe.
Dry everything off put back together. and Print a test page. It took me 10 minutes to get my printer working again.
Posted on Nov 11, 2008
  • 30 Answers
OK this is the tricky part. You will have to take your printhead out of the machine (the peice of plastic the cartridges sit in). It just has a single arm holding it in and nothing else. There a few things you can try I will list them in order of safest to least safe.
1. Leave the cartridges in the head (even if you have to hold them in with your hand) and use a thin head on a decent vacuum cleaner (preferably one that can handle wet and dry so you don't get ink everywhere) on the bottom of the head where the ink comes out. You may be able to suck the ink through effectively removing any blockages.
2. You can leave it to soak in Isopropyl alcohol or windex or really hot water (not boiling) and it may remove any blockages. You must make sure that it is completely dry before reinstalling it though or you will wreck the head.
3. Using a jeweller's ring cleaner sit your printhead in an inch of water and activate it for 60 seconds (This can also damage your printhead).
You can get an idea how successful you have been each time by dabbing the bottom (where the ink comes out) onto paper towel or a tissue. You should see 4 lines, black, cyan (blue), magenta (red) and yellow.
If all of this fails you may need a new printhead which is dearer then a new machine.
Good Luck.
Please rate my advice, good or bad.
Posted on Feb 07, 2008
My Canon i850 printer has stopped responding to a
The Canon i850 uses cartridges of type BCI-3. according to Canon, the color cartridges are compatible to:
BJC-3000 Series, BJC 6000, i450, i550, i850 Series, MultiPASS F30, F50, F60, F80, MP 700 and MP 730, S400, S450, S500, S520, S530D, S600, S630, S630 Network and S750.
The black one will work in a few more models.
Feb 07, 2010 | Canon i850 InkJet Photo Printer
The black color doesn't print.
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Feb 05, 2010 | Canon i850 InkJet Photo Printer
All of the sudden the color does not print properly on my canon I850 - its washed out and orangish
Check the color cartridges, especially the yellow. If the yellow looks llike orange or brown then the ink is contaminated. It happens when the printhead goes bad. A membrane between the colors breaks allowing the inks to contaminate each other.
Nov 25, 2009 | Canon i850 InkJet Photo Printer
7 yellow flashes not printing
hi welcome to fixya!
I believe there is no print head failure happening. I experience that one time, it only needs a new ink cartridge. Be sure to replace the right color!
have a nice day!
Apr 17, 2009 | Canon i850 InkJet Photo Printer
Printer wont print in color and i just replaced with all new ink cart.
new cartridges can be defective also.
Remove and re-insert the cartridge, double check them,
( leave printer on )
Check printer's Advanced properties are not set for black only,
switch off at mains, reboot,
Run maintainance on it, head cleaner, nozzles etc...
if the same, swap out, the color cartridge it is faulty.
Hope this helps
Regards.
Apr 16, 2009 | Canon i850 InkJet Photo Printer
Ink Cartridge Settings
Have you tried Canons FAQ? They suggest checking the grayscale box, which apparently only works with certain kinds of printing (duplexing and borderless will still use colors). I don't understand how colored inks are used to create black, but that's what they claim. Anyway, here's the link: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=11641
Jan 29, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
All colors print blue
You did the right thing. Sometimes a bad printhead or a bad cartridge will cause a leak and will damage both. Good job!
Jun 05, 2007 | Canon i850 InkJet Photo Printer
Incorrect colour is printed
I would try to replace the printhead and the magenta cartridge at the same time. Lots of people with leaky cartridges have this same symptom only, it is with whatever color is malfunctioning.
Apr 25, 2007 | Canon i850 InkJet Photo Printer
Canon i850 InkJet Photo Printer Logo
192 people viewed this question
old marine
old marine
