Question about Philips GOGEAR SA6045 MP3 Player
My player is stuck on the start
My player has a problem it don't start it.this starts since i desconnect it when it said to don't because i didn't see and i restarted and after a little time i turn it on and it don't start now
  • 8,596 Answers
First - reset the player by using a paperclip, toothpick, etc and pressing it into the pinhole. Try doing this while the GoGear is "On" - but this may be difficult under the circumstances. Try connecting your GoGear to the computer after that, and see if Windows Media recognizes the player.
If that fails, conenct your GoGear to the computer, open Philips Device Manager (Start-->All Programs-->Philips), and click on the repair tab. Now, disconnect your GoGear from computer. Turn the GoGear off if it is not already. Press and hold the volume + key and connect the GoGear to the computer (while still pressing the volume +). A window will pop up saying a repair is being performed. now you can let go of the Volume + button. The repair will get your device workign normally again. WARNING: the repair process will delete any music/other media file from your GoGear.
-Tha Mp3 Doctor
Posted on Feb 07, 2008
I have a 94 caddy seville and it sat for a couple years anyway I can get it to start with starter fluid but it won't stay running I think its the emergency fuel shut off switch but I can't find...
gm didn't have a shut off like that on that model but the fuel pump could have stuck from sitting try smacking the fuel tank while someone is cranking the engine over
Sep 27, 2012 | Cars & Trucks
1994 Camaro3.4 S.F.I will start, but will mot idle or run.
did you check for spark or gas? if so, check for a broken kink or desconnected vacuum hose. Timing?
Jul 25, 2012 | Cars & Trucks
Stuck on load screen
I upgraded the unit on Dec. 24th and I now have the same problem. My solution is to take it to your local recycling plant and don't buy another Samsung player. I contacted support and because the unit is out of warranty they can't (will not) do anything. I tried reapplying the firmware via the USB and it didn't work. Anyone have a way to reset the firmware to the factory version?
Dec 24, 2011 | Samsung BD-P1500 Blu-Ray Player
Car will not start
A simple jump start with battery cables should get the car started and recharge the battery. If you don't like dealing with battery cables, there are products that attach from inside the car using the cigarette lighter to jump start the car that work very well.
Oct 28, 2011 | 2008 Toyota Prius
Alright so I have a sony walkman I think its the newest 16gb model I really don't know,but its black and has speakers,and the hold button is on the side along with the volume control,but anyway my...
Let's see... it would help if you might have the model number but here's a start. Below is the link page to Sony's latest NWZ walkman. I entered "trouble" in the search box and landed here.
This might be helpful to you at some point. Once you find your model number (their first bullet point) you can go to the home page for your specific players instructions...
link: https://www.sony.co.uk/electronics/support/digital-music-players-nw-nwz-ws-series
But for now, I searched your specific issue too and came up with this. Again - I don't have your model number but they are likely to be similar in solution. You may have tried each step as you'd mentioned but here is a step-by-step to check your own steps:
link: https://www.techwalla.com/articles/how-to-fix-frozen-walkmans
Resetting a Frozen Walkman
Step 1
Grab either a paper clip or a needle. If you have a paper clip, bend it so that it becomes a straight line.
Step 2
Locate the "Reset" button on the Walkman. Most Walkman models and, indeed, most MP3 players keep the Reset button somewhere near the volume control. Slide the pin needle or paper clip into the hole and press the "Reset" button.
Step 3
Hold down the "Reset" button for 3 to 5 seconds. If you see the screen flicker, the Walkman has reset. Release the "Reset" button and remove the pin needle from the hold.
Draining the Battery
Step 4
Power on your Sony Walkman. If already powered on, power down and then turn back on.
Step 5
Allow the MP3 player to burn through the battery life. This will take several hours. Wait an extra couple of hours to ensure the battery is completely dead. Just because the screen has gone dark does not mean that the battery has completely drained itself.
Step 6
Recharge the Walkman player until the battery holds a full charge. Turn the Walkman on. If the system operates as normal, the problem has been remedied.
Lastly, here is a utube troubleshoot video link (and again - I don't have your model number .... hint hint.)
https://www.youtube.com/watch?v=Qt9M92u9spY
Good luck - I hope something here works and that perhaps I have improved your day! :)
(Please let us know if this answer is helpful by clicking the button below, thanks!)
https://www.sony.co.uk/electronics/support/portable-music-players-digital-music-players
Apr 13, 2017 | Sony NWZ-S615FS VIDEO MP3 PLAYER Digital...
Cd player on 2001 lincoln ls - cd error when i press load button
My father inlaw just purchased a 2001 lincoln, with a six disc changer, Question is he loaded the unit ,and now he wants to eject the cd's and the changer won't open? any suggestions thanks
Jan 06, 2010 | 2001 Lincoln LS
How do i reset my sansa e270
Press and hold the "Power/Menu" button for 15 seconds to reset it back to its original factory default settings.
Sep 24, 2009 | SanDisk Sansa e270 MP3 Player
Why won`t my mp3 take itself off hold?
Power & Hold switch
Slide and hold in the opposite direction
of the arrow for power on/off.
Slide in the direction of the arrow to
lock the button functions.
If that fails,
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Apr 15, 2008 | Samsung YP-T10 Digital Media Player
Mpio HD-400 is stuck on loading screen windows doesnt recognize it
alotita, I have an MPIO HD-200. Does Windows play the sound like you have something attached when you plug it in? Or does Windows not regognize it al all? Either way, I've had to play with mine after I've dropped it a couple of times. I charge the battery all the way, then just keep plugging and unplugging from the USB wire. The last time, it took 20+ times before Windows would recognize it.
Nov 14, 2006 | Mpio HD-400 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
65 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
