Question about Car Audio & Video
95 Jeep Wrangler Windscreen Wipers Dont work!
I was replacing the fuses for my jeep wrangler and now my windscreen wipers dont work.
Is this a fuse shortage? if so i dont know which fuse it is! I dont have a key for what each one is.
Any other suggestions on how to fix this?
Very much appreciated!
Regards
Sam Dihm
  • 2,039 Answers
Checking fuses is very easy you need a 12volt test light one end you connect to ground good clean metal of car kee on take test light touch the 2 metal pin in the fusespower go trus a good fuses the test light should come on on the 2 side if 1 side light up only replase the fusesand if you think youremove the fuses and didnt put back just put a 20amp fuses in the missing hole 20 amp is a yellow fuses activate our wiper before fill in the holes with fuses if it start good if not put everything on take a screw driver touchthe wiper motor and the body at the same time if it work the wiper motor is not grounded you need to attach a wire from wiper motor to body again good clean metal with screws as long at it tight thank you for using fixya pierre
Posted on Feb 07, 2008
    Brigadier General:
  • 6,966 Answers
Initially what can be suggested is to try and redo the fuse insertion again but wiggle them a bit when installed. It might also be of help if you spray the insertion points or fuse clips with an electronic contact cleaner prior to reinserting the fuses. In some instances, the fuse clip/holder need to be manually scraped for corrosion or grime/dirt. It is also possible that a wire might have been dislodged that leads to the wiper motor.
Good luck and kind regards.
Heater blower and wipers dont work on my 2005 jeep wrangler
Have you checked fuses? Did both stop at the same time?
Dec 28, 2014 | Jeep Wrangler Cars & Trucks
2003 jeep wrangler x fuse box diagram
just a flash light and 5min. looking finds 99% bad fuses.
why do you need to know the exact one?
here is the full FSM> see wiper wiring, its fuse #17 runs the front.
it runs the waster too, so if that works its not Fuse 17.
or any fuse ,.
17 is marked FRT WIPE
see power distrubution page 3. top left corner fuse.
if the fuse is good we use a voltmeter to find out what really is bad.
ask.
Mar 07, 2014 | 2003 Jeep Wrangler
Jeep wrangler electronics went haywire?
I had the same problem and believe it or not it was a running light out
Jan 16, 2013 | 2008 Jeep Wrangler
Wipers quite working on my 95 wrangler fuses look good what else can it be?
Bad wires connections, Multiswitch go to bad or finally wiper motor.
Apr 27, 2011 | Jeep Wrangler Cars & Trucks
I found the fuse bos but i dont know which one controls the wipers.
the fuse diagram is on the back of the cover or in the vehicle manual describing each one, usually titled "Wiper"
Jan 18, 2011 | 2002 Jeep Wrangler
1997 jeep wrangler fuse box diagram. wiper motor works....new wiper switch...connect and still no wiper function....fuse? location?
The fuse for the wipers on a 97 wrangler are located behind glove box just unhook strap that holds up glove box and replace.
Aug 11, 2010 | 1997 Jeep Wrangler
Wipers dont work
Check your fuses. And if that doesnt work check the wiper motor.
Jan 27, 2010 | 1993 Jeep Wrangler
Wiper will not work on 95 jeep wrangler? What to
start with fuse then switch and the motor
Dec 19, 2009 | 1995 Jeep Wrangler
Blinkers, Wipers and Dome Light Control do not work. 2007 Jeep Wrangler
That's got to be a fuse. Look in your manual under Fuses to see which one needs to be replaced.
Oct 25, 2009 | 2007 Jeep Wrangler Unlimited Rubicon 2...
Car Audio & Video Logo
248 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
