Question about Lexmark X1150 All-In-One InkJet Printer
LEXMARK SCANNER AND COPIER
I CAN PRINT ONLY. AS FAR AS SCANNING AND COPYING A LARGE MAGNIFYING GLASS COMES UP AND SAYS IT IS SEARCHING FOR THE SCANNER. WILL DO THIS FOR HOURS. HELP. I NEED MY COPIER AND SCANNER.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Lexmark Master
  • 1,362 Answers
Reload driver, it did not load the scanner part.
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:435:0:0
Posted on Feb 18, 2008
Print quality is batter but copy quality is not batter horizontal lines come in copy
Clean the glass for the scanner. If you get lines only when copying usually it is dirt. If your copier has both an adf and a flat glass for scanning, scan from both and compare the quality.
Dec 16, 2014 | Office Equipment & Supplies
Samsung CLX-6220-FX vertical lines when scanning and copying
The reason for such lines if they appear only on scans/copies from the automatic document feeder (adf), but not on regular scans and printouts is that there is dirt on the small glass stripe next to the scanner area that is used for scanning from the adf. Just clean that glass stripe and the lines should go away.
Jan 21, 2014 | Samsung CLX 6220FX - multifunction fax /...
SCX 4826FN everything that goe in through the top feeder (scans, copies, faxes) comes out with a solid vertical black line on the paper. All other printing jobs that pull paper from the tray are ok. It...
This black line sounds like it is definately coming from the ADF scanner glass. This is the thinner strip of glass that is located just to the left of the large original glass. You can verify this by making a copy from the large glass instead of using the feeder on top. If the copy comes out clean then it is definately the scanner glass. Just clean the glass well with glass cleaner and a soft cloth. This glass is only used when copying/scanning using the top automatic feeder
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 04, 2010 | Samsung Office Equipment & Supplies
I have a wide black stripe when scanning pictures or making copies. Printing is fine.
Sounds like there is either something on the glass, under the glass or there is some malfunction with the scanner itself. You will probably need to take it in for repair.
Oct 28, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Use of Scanner
On this model there is a SCAN in black and white or color buttons but you need to have something on the glass to scan. Once it scans it prints!!!
Now lexmark software if installed comes with a program to scan with. you need to check under your prgrams folder under lexmark for the scanning software that was installed with the print driver.
If you open the lid and you do not see the white light chances are your scanner has and needs a bulb inside and at the point to install one of these you might want to concider a new printer.
Please be considerate and leave your feedback and comments and ratings before you leave, Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 30, 2010 | Lexmark X2500 All-In-One Printer
Solid black line when scanning or copying from KODAK ESP-3
Get a damp soft cloth and clean the scanner glass. If that doesn't resolve the issue there is a chance the scanning unit itself is damaged.
Let me know.
Cheers, Chris
Jun 21, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Black vertical line (1 inch wide) appears while scanning/copying
For this kind of problem you need to call the tech support because the printer is already messed up and it is in need of replacement
Hope this help
Byron
Jun 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
I can receive faxes but when I send them they are illegible.
make sure glass is totally clean and pad is clean, also could be an issue with your scanner bulb
Feb 04, 2009 | Lexmark X7170 All-In-One InkJet Printer
Facing copying problem from scanning section
Although you didn't specify the scanner model, this solution should work.
If the scanner has a top feeder, open it.
You will see a thin strip of glass, either to the left, or right of the large scanner glass.
There is most likely a small spec of ink, white out, etc on it.
Clean the strip glass with rubbing alcohol and the line should go away.
Apr 09, 2008 | Office Equipment & Supplies
Problem in scanning
Your scanner glass, mirrors and lens need to be cleaned.
There is an adjustment you can try.
Press in order. Menu #1934. That will enter diagnostics.
On your menu scroll around to find maintenance, then scroll to Shading adjustment.
Place 5 pieces of paper on the glass and press enter until it runs the shading adjustment. That is the scanner calabration.
That can help. But most likely the mirrors and lass are hazy.
Unlike an old copier where dirty optics showed up as a dark image, dirty scanners see less light reflected from your document and therefore print out what they see which can be streaky, faded and very very poor gray scale.
If you want me to I can send you the steps in disassembling that machine, but it does require pretty much disassembling the machine and that scanner head, you can break the lamp easily.
Dec 31, 2007 | Xerox WorkCentre PE16 All-In-One Laser...
Lexmark X1150 All-In-One InkJet Printer Logo
232 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
