Question about Whirlpool GU2400XTP Built-in Dishwasher
Lock mode can't get the machine out of lock mode. Used the "normal/heated dry" sequence but won't release
  • CCBW Feb 10, 2008
    Same problem with QPII locked, 3 blinks, wont reset. any suggestions? thanks
TRY UNPLUGGING AND REPLAUG AFTER AFTER 12secs
Posted on Feb 07, 2008
How do I reset the code.the lights are lit 4 hour delay, rinse only steam clean.
THIS DISHWASHER WAS RECALLED BY MAYTAG.. You might want to call them to see if it is still covered.
If already repaired you might try:
Normal - heated dry - normal - heated dry. then try to use the machine.
Oct 19, 2015 | Maytag MDB7809AWB - MaytagR JetcleanR Plus...
MDB7749AWB
Hello I had the same issue the sequence for resetting the panel is;
heated dry...normal...heated dry...normal
all the lights will go on then off. on my machine it started the normal wash cycle. I let it run normally so far this worked.
Hope this helps.
Dec 30, 2011 | Maytag MDB7749AWB Builtin Dishwasher
Need trouble shooting proceedure to enter self diagnostics for maytag neptune
From the service manual there is more to it but that was all I could put here.
Accessing Service/Diagnostic Mode:
Pressing down the damp dry and time (-) keys
for 5 seconds places the machine in the
diagnostic mode.
SPECIAL TESTS
The following table lists the various tests
available while in the Service Mode, which
can be accessed by pressing the following
keys:
Press Keys Special Test/ Function
wrinkle
release Diagnostic Codes
dryer
temp(^ )
Sequences up the
help/diagnostic code list
dryer temp(v) Sequences down the
time (-) Displays Software Revision
Number
very dry(< ) View current cycle
temperature (Co)
start/pause
Start or pause cycle running
but remain in Diagnostic
mode
Accessing Diagnostic Codes
After the machine is in the diagnostic mode,
a ‘d’ will display and let the technician know
they are in the diagnostic mode. Pressing the
wrinkle release key will access the diagnostic
codes.The diagnostic codes can be viewed by
using the temperature (^) & (v) keys.
The down arrow key will sequence down the
list one each time it is pushed with no wrap.
The first time the down arrow key is pushed
the display will sequence to the next code
logged. The last code being displayed being
the oldest code. The up arrow will sequence
up the list one code each time it is pushed
until it reaches the top code. If there are no
diagnostic codes available, ‘00‘ will be
displayed for the diagnostic code.
There will be no multiple occurrences of
either a diagnostic code or help code generated
in the same cycle reported on the list.
But if the same code occurs in repeated
cycles, it will be registered.
To clear the diagnostic code list press
wrinkle prevent and very dry (>) for 5
seconds while viewing the list.
System Check Mode
While in diagnostic mode, pressing the damp
dry
and signal (+) keys for 2 seconds, will
put the dryer into the system check mode.
"SC" will display.
This mode will allow the various inputs and
outputs to be controlled and viewed by the
technician by pressing individual keys. If no
activity is seen for 5 minutes after a key is
depressed, the control will reset back to the
normal mode. If no further activity is seen
after an additional 5 minutes the washer will
turn off. The following table lists the various
functions based upon on keys being depressed.
Membrane Pad Check
While in system check mode, pressing the
damp dry and sensor dry keys for 5 seconds,
will start a membrane pad switch test.
The membrane check involves turning all the
embedded LED on the membrane pad on.
All the LED’s can be toggled off by pressing
the key associated with the LED. To exit the
test at any point, press the damp dry (>) &
sensor dry keys again for 5 seconds or press
the off key to exit diagnostic mode.
Key Pressed: Function Performed
sensor dry
Enable sensor dry circuit.
(sense dry LED) When short
circuit is detected across the
sensor bars the normal dry
LED will turn on.
start/ pause
Cycles the motor relay
on/off. When the motor is
running the start/pause LED
is on.
dry temp(^ )
If motor is running, cycles
the heater/gas valve on/off.
When the heater is regular
temp LED is on.
temperature (Co)
www.appliancehelponline.com
Mar 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Normal cycle button blinking, cannot start new wash cycle
Press Heated Dry, Normal, Heated Dry, Normal buttons in sequence within 6 seconds to reset control. Could also be locked. Press and holding the air dry button for four seconds.
Nov 18, 2009 | KitchenAid 24 in. KUDI01IL - Multiple...
Dishwasher: Green light flashes and will not turn on
Hi
Please press the following sequence to reset the washer "Heated dry" "Normal" Heated Dry" "Normal". This will reset the machine. Also try and locate the tech sheet in lower kickplate.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 10, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool quiet partner III clean light blinking green
press:
heated dry
normal
heated dry
normal
then cancel..... wait until 2 minute cycle is done. open and close the door and make sure it is closed.
Then run another cycle. saw this on another post and it worked for me. They said that if it did not reset then either the latch has a bad connection or the heater for the water is bad.. it must register that the door is closed in order to actually start the heater for the water. I hope this helps you as well as it helped me.
---Rhino---
Dec 21, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Buttons won't work on GE Profile PDW7980N10SS
You have the control lock activated. Press and hold the heated dry pad for 5 seconds and it should unlock it
Nov 15, 2008 | GE Profile PDW8400J Built-in Dishwasher
Kenmore elite dishwasher 665 15962990
Hold down the "HEATED DRY" button for 4 seconds to unlock.
Try to press these botton in sequence,Heated Wash, Heated Dry, Heated Wash, Heated Dry.release your hand, the unit will go into diagnostic mode. that is all leds will ON for a few seconds,and start normal operations.
If that does not work, you might need to check the electronic control board if the ribbon is seated properly.
Finally solution, is to change the electronic control board.
Jul 27, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore ultra wash quiet guard 3 dishwasher problem
call sears, 1-800-4MY-HOME. They have a trouble-shooting department that will get rid of this problem. It is caused by water temperature being wrong at the start of the cycle.... blah, blah, blah. The representative will tell you to push a certain set of buttons in a certain order and that unlocks the dishwasher.
Sorry I don't know the sequence
Jun 08, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
"Heater Circuit Malfunction" Kenmore 16033
Lynn, on the newer boards the key dance is heated dry-normal-heated dry-normal. On the older boards it was high temp-air dry-high temp-air dry. Don't know if yours has been changed or not..Catriver...post back.
Aug 28, 2006 | Kenmore 24 in. 16033 Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
64 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
