Question about Bosch 24 in. SHU43 Built-in Dishwasher
SHU 43 Built in-removed door, clips fell out
I have a SHU43 that when I switched out the white door panel for the stainless one, the door clips fell out..what do I have to do to put them in again and in the correct way?
  • Tommy Stebbins May 11, 2010
    are these 2 black plastic pieces about 2-3 inches long, if so they go toward the bottom left and right of the inner door about 6 inches from the bottom of the hinges there is a notch cut out they fit in with the rounded edge fitting out. they just add a bit of rigidity to the door
Those clips will fit into slots on each side of the door frame just above the hinges, Put them back into the frame, then install your new stainless panel. If they fall out b/4 you can get the panel back on, try taping them to the door frame with some masking tape to hold them in place while you secure the stainless panel.
good luck.
Posted on Feb 20, 2008
The drivers side window fell into the door of 96 rendezvous. How do i put it back on track?
The door trim is held on with a combination of screws and push clips Once you have the trim off you will probably find that the window motor regulator is defective. I would recommend replacing the regulator and motor as an assembly.
Are you sure of the year? Didn't think that they made a 1996 Buck rendezvous
.http://www.dormanproducts.com/gsearch.aspx?
Feb 23, 2015 | Cars & Trucks
I have a Kenmore Refrigerator/freezer, model # 59673503201. The freezer door was dented, so I ordered a new one, which arrived without a handle. I removed the 8 screws on the inside panel and attempted...
The handle is held by screws and butter clip. You removed the screws,but also release the clips.If in case the clips break during removal,then you can replace the clips too.The cost of each clip is $2.There are two clips in total.One clip on each side of the handle.Once you release this clips the handle should freely come out.To see how the clips look.See the fig below:-- helpmech_57.jpg
This clips are called butter clips or mounting clips.To order this clips if required.Please click on the link below:---- http://www.repairclinic.com/PartDetail/Mounting-Clip/1023807 -------------- If you want door handle removing diagram for your refrigerator: Click on the link below:--- see the diagram:--- http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/M0307112-00001.png ---------------- If you require new handle then click this link directly:---The cost of new handle is $21.----- http://www.repairclinic.com/PartDetail/Handle/1070320 ------------ Also for more help,if you require,freezer door disassembly diagram.Please click on the link below:--- http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/M0307112-00004.png ---------------- This should help.Thanks.Helpmech.
Jan 26, 2011 | Refrigerators
I have a 1997 Dodge Ram. The window on the drivers side door fell off its track. I have the door panel, and the plastic off. How do I get to the window, and put the window back on its track?
I had the same problem on my 97 Ram. Take the door panel off, get some liquid nail, squirt just a little into the two clips that hold the glass. Then set the glass back into the clips and run the window up almost to the top so you can still get your fingers on top of the glass. Run it all the way back down again putting a little down pressure on it. Now run it all the way up, put the panel back on and let it sit for a few days before you roll it down again.
You have to run it up and down to make sure the clips are in the proper position, if yours is as loose as mine was it will slide around in the clips pretty easy.
Jan 07, 2011 | 1997 Dodge Ram 1500 Club Cab
I want to replace the white door panel with stainless steel
Have you checked with www.applianceart.com? They have faux stainless and real stainless options. PLus a ton of other choices there.
Feb 21, 2010 | KitchenAid 34 in. KUDP01FLSS Stainless...
92 cadi devile exterior door fell out having proablmes with clips.
92 cadi devile exterior door fell out having proablmes with clips. ANSWER GO TO JUNK YARD NEAR YOU PICK UP NEW USED SET OF HINGES MAKE SHURE ITS THE AXACT SIDE EXACT YEAR AND MODEL TAKE IT TO ANY AUTO BODY SHOP DOOR HAS TO BE LIFTED ON A CAR JACK AND TO BE FITED TO HAVE PERFECT CLOSING WILL BE HARD FOR 1 PERSON TO DO THE AIMING DOOR EXACLY TO HINGES PUT LOTS OF WHITE GREASE AFTER AS FOR SMOTH ACTIONS CLOSING/OPENING DOOR.
May 03, 2009 | 1994 Cadillac DeVille
White to stainless
Black, white and bisque seem to be the only colors available for the double convection oven. Might be possible to find the cooktop, but it's hard to know for sure without the model number.
In my experience, it's often not economical to switch to stainless steel as stainless steel panels can be extremely expensive (I've seen a freezer door on a side by side fridge sell for over $850... Just the freezer door!)
Mar 05, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Change a white door to stainless??? can I
Okay here we go. The SHU43C05UC/17 is the stainless model. The parts needed to change over to SS are 1) 431828 SS Facia cost 72.80. 1) 417981 power switch button 15.40. 1) 426062 program buttons set 5.40. 1) 214750 SS outer door panel 101.50. 1) 426063 lid (fits inside the handle area) 3.90. As you see it will not be cheap to change over to a SS dw. These prices are from Bosch's Quick Finder website. Hope this helps.
Mar 31, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Door clips fell out
IF THE CLIPS ARE BLACK AND ABOUT 1 1/2 INCHES BY 2 1/2 INCHES THEY GO ONTO THE HINGES AND THE DOOR GOES OVER THE TOP OF THEM, YOU MAY NEED TO LIGHTLY FLEX THE SIDES OF THE PANEL TO GO OVER THE HINGES. THE TOP OF THE PANEL SHOULD SLIDE UP INTO THE CONSOLE BEFORE THE BOTTOM WILL GO IN. HOPE THIS HELPS YOU OUT
Feb 07, 2008 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Rinse agent dispenser
The only "fast" way is to remove the dispenser completely and rinse with warm water until clean! (by removing front panel and then disconnecting jumpers and clips...can be tricky to do alone, as you need 3 hands to pry clips from dispenser to remove from door!) Oshie.
Sep 28, 2006 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
201 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
