Expert
- Posted on Jan 09, 2010
Re: cd/dvd drive cant read
Try Uninstalling the driver & restart the system &
Try Updating the device driver from support.dell.com
And also try this
work well for more people
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:
- Click Start, type regedit in the Start Search box, and then click regedit in thePrograms list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
- Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
- In the right pane, right-click UpperFilters, and then click Delete.
- Click Yes to confirm the removal of the UpperFilters registry entry.
- In the right pane, right-click LowerFilters, and then click Delete.
- Click Yes to confirm the removal of the LowerFilters registry entry.
- Exit Registry Editor, and then restart the computer.
