Question about Presto HeatDish Compact Heater
Presto Heat Dish
I have a Presto Heat Dish and it has to be cleaned, but I dont know how to clean it can you help?
  • 3 Answers
The hardest part of cleaning the dish is that you can't get your hand inside the cage surrounding the dish. What I did was to use a wire cutter to snip enough pieces of the cage off so that I could get access to the dish. If you do it carefully, it looks as if it was intended and doesn't prevent the cage from working. If you think of the cage/dish as a clock, I cut all the strips between 9 and 11, and 1 and 3. Easy to clean the dish afterwards.
That might not solve the buzzing problem, though. It didn't solve it for me.
Posted on Feb 19, 2008
How do i Clean presto heat dish
It all depends on the how much dust has accumulated on inside of the dish.
Try to use the Swiffer first before mechanically altering any part. Slide the duster in through the grate, and move it around. Pull it out and repeat on the other area. You'll just have to do this around 3 times.
If heavy clean is necessary, then you might have to resort to bending the lip of the dish to separate the grate off from the dish.
IMPORTANT: make sure the unit is unplugged and cool down before attempting any of these cleaning methods.
May 22, 2014 | Presto HeatDish Compact Heater
RE: Presto Heat Dish buzzer going off
I almost threw my heater out! I cleaned this morning with Window Cleaner and it works just fine now. It was just dust. I cleaned the round metal area not the coils.
Hope this helps.
Emailed Presto about replacing the buzzer and here is the answer I got:
There is no such part. Buzzer sounds when heater:
- is tipped
- rests uneven on floor
- is too close to furniture or wall
- has too much dust on parabolic dish
The most common reason is that the parabolic dish is dusty.
To clean the heater:
1. Unplug the heater and clean it when it is cool
2. Spray a cloth with an all-purpose cleaner such as 409
3. Wrap the cloth around a long handle such as a wooden spoon
4. Wipe between the grate from the outer edge to the center
If you have further questions, please let me know. Or call us at 1-800-877-0441 Monday through Friday 8:00 a.m. to 4:30 p.m. Central Time.
Jan 11, 2010 | Presto HeatDish Compact Heater
Buzzer goes off
This was the answer from Presto as I had the same problem. Cleaned it with window cleaner and a wooden spoon and paper towels and now it works great!
- is tipped
Dec 29, 2009 | Presto HeatDish Compact Heater
How to clean dish? Safety grate covering face of dish does not appear to have a way to remove it so backed on dist can be removed and heat dish can be returned to near new condition. Thanks, Mike
This is the answer I got from Presto. I cleaned it with window cleaner, wooden spoon and paper towels. Dish works great now.
- is tipped
Dec 21, 2009 | Presto HeatDish Compact Heater
Clean dish
'tdulany's remedy for cleaning the dish on the Presto Heat Dish probably works well, but how do you get past the grill covering the dish in order to clean it?
Nov 26, 2009 | Presto HeatDish Compact Heater
Please give me the number on how to purchase dust remover that came in presto heat dish box. Thank you!
- is tipped
Oct 25, 2009 | Presto HeatDish Compact Heater
Presto parabolic makes loud buzzing sound after a few minutes of
The metal dish must be dust free or it will transfer heat to the safety device. If this is not the solution call customer service at 800-877-0441
Jan 13, 2009 | Presto Like Parabolic Heater Heat Dish
Presto heaters
We have one in our office where our entry is pretty close to teh main door. It used to buzz all the time after being on for maybe 10 minutes. One day I got sick of it and took a cloth and some windex and cleaned the reflecting dish, and that actually stopped it
Oct 29, 2008 | Presto HeatDish Compact Heater
Presto Heat Dish w/footlight
This heater must be flat on the floor or it will buzz, and the metal dish must be clean or it will transfer heat to the safety device. If this does not solve the problem call customer service at 800-877-0441.
Jun 14, 2008 | Presto Heat Dish/Electric Heater with...
Presto HeatDish Problem
I rewired my heat dish. I UNPLUGGED THE HEAT DISH. I loosened the three screws on the back and removed them. Then I unclipped the dish at the bottom. The dish should be loose and the bottom section of the dish should be detached from the plastic casing. Look inside the casing at the bottom. There is a red cable attached to the buzzer (it’s the silver metallic piece). Detach the red cable from the buzzer. Now look directly behind the buzzer is a black wire that connects to the circuit next the buzzer. Attach the red cable to the female receptor foot the black cable. Plug it in and it should work fine. This will permantly disable the buzzer, SO YOUR HEATDISSH NOW LOINGER HAS A WARNING SYSYTEM. IF YOU TURN YOUR HEATER OVER THE BUZZER DOES NOT GO OFF, THE BUZZER ALSO INDICATES OVERHEATING OF THE UNIT. SO BE CAREFULL. MAKE SURE THE UNIT IS UNPLUGGED WHEN WORKING ON IT. GOOD LUCK AND BE SAFE
Oct 19, 2007 | Presto HeatDish Compact Heater
Presto HeatDish Compact Heater Logo
638 people viewed this question
Top Presto Heating & Cooling Experts
Mack Baxter
Starnley Johnwells
Starnley Johnwells
Paul Carew
Are you a Presto Heating and Cooling Expert? Answer questions, earn points and help others
