Question about Kenwood KVT-617DVD Car DVD Player
Brake bypass kvt 617dvd for 2004 maxima
Having trouble with bypass
Ground parking sensor wires to the ground wire at the head unit. It works perfectly.
Posted on Feb 19, 2008
Kenwood KVT-617DVD - Rear Camera Option Not Working
Since "...everything else is working..." indicates that there is no blown fuse or chances are nor any hardware is at fault.
When the battery was disconnected, the Kenwood KVT-617DVD may have suffered a memory failure and would require a reset.
Have you tried doing a reset? It's a small recessed button near the bottom right side of the font panel underneath the protection panel (right of the Joystick Track/Station Key & above the Eject Disc Key). Pressing the reset button should restore the Kenwood KVT-617DVD to default factory settings. Of course this will also remove any special programming that you may have such as favorite stations, etc.
You also posted "...Parking brake requirement...bypassed..." this is only to allow the display to be always ON. This is the green wire that must be grounded
You need also to check that the "Reverse" wire/trigger is also bypassed that is to set the "...camera...full time...rear view mirror and back-up monitor for the truck camper..." This is the pink wire that must be attached to the ACC of the vehicle's Ignition Switch. Alternately, it may be connected to the red wire of the Kenwood KVT-617DVD.
If the reset does not correct the problem, you may need to run the setup menu again following the user's manual. Should you need a copy, it is available on line here. Pls verify that you set R-Cam Interruption to ON & R-Cam Mirror to Reverse. This is better explained with appropriate illustrations in page 69 of the User's Manual.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 10, 2007 | Kenwood KVT-617DVD Car DVD Player
Having trouble with my kvt-617dvd car stereo
after disconnecting battery asking for code and i cant find remote help
Aug 26, 2009 | Kenwood KVT-617DVD Car DVD Player
Putting kenwood kvt 617 dvd in rear of surburan how can i bypass parking brake so movies can play while driving
On bypasses you can either hook the parking brake wire straight to ground, if that does not work you can install a toggle switch between the parking brake wire and ground so you can mimic the parking brake on off.
Jun 04, 2009 | Kenwood KVT-617DVD Car DVD Player
Kenwood bypass
you mean the hand brake? so you can watch dvds on the move?
Have a look at the installation guide, if the sense is - neg.
put a switch inline to earth/chassis,.. you will then be able to FOOL the system into thinking the handbrake is on.
If you have navigation it may cause problems/disable some features.
Feb 07, 2008 | Kenwood KVT-617DVD Car DVD Player
Kenwood kvt 729dvd
connect the green wire from head unit to ground perminetly
Feb 02, 2008 | Kenwood KVT-617DVD Car DVD Player
Kvt-617 bypass
u can wire the safety wire to a ground or to a switch that grounds the wire and that will bypass it.
Dec 27, 2007 | Kenwood KVT-617DVD Car DVD Player
Kenwood kvt-617dvd
tie the green parking brake switch wire to ground
Nov 30, 2007 | Kenwood KVT-617DVD Car DVD Player
Wiring
the wire that connects to your handbrake, well simple solution, run it to an earth as thats what happens when your handbrake is applied, it earths the switch!
so just earth it out
Nov 04, 2007 | Kenwood KVT-617DVD Car DVD Player
BYpass kenwood kvt-617dvd
Ground the Green "Brake" wire to your frame. This will fool the system into thinking that your brake is engaged.
Oct 12, 2007 | Kenwood KVT-617DVD Car DVD Player
Kenwood KVT-617DVD Car DVD Player Logo
148 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
