Question about Bosch 24 in. SHU5305UC Built-in Dishwasher
Door clips fell out
I was replacing the white door panel with a stainless steel one and the door clips fell out...who do I put them back in?
  • 125 Answers
IF THE CLIPS ARE BLACK AND ABOUT 1 1/2 INCHES BY 2 1/2 INCHES THEY GO ONTO THE HINGES AND THE DOOR GOES OVER THE TOP OF THEM, YOU MAY NEED TO LIGHTLY FLEX THE SIDES OF THE PANEL TO GO OVER THE HINGES. THE TOP OF THE PANEL SHOULD SLIDE UP INTO THE CONSOLE BEFORE THE BOTTOM WILL GO IN. HOPE THIS HELPS YOU OUT
Posted on Feb 07, 2008
Dishwasher door handle
Remove the screws around the inside of the stainless steel door panel, once you can gain access, repair or replace the door handle and return the door panel to normal.
May 05, 2016 | LG Dishwashers
I have a Kenmore Refrigerator/freezer, model # 59673503201. The freezer door was dented, so I ordered a new one, which arrived without a handle. I removed the 8 screws on the inside panel and attempted...
The handle is held by screws and butter clip. You removed the screws,but also release the clips.If in case the clips break during removal,then you can replace the clips too.The cost of each clip is $2.There are two clips in total.One clip on each side of the handle.Once you release this clips the handle should freely come out.To see how the clips look.See the fig below:-- helpmech_57.jpg
This clips are called butter clips or mounting clips.To order this clips if required.Please click on the link below:---- http://www.repairclinic.com/PartDetail/Mounting-Clip/1023807 -------------- If you want door handle removing diagram for your refrigerator: Click on the link below:--- see the diagram:--- http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/M0307112-00001.png ---------------- If you require new handle then click this link directly:---The cost of new handle is $21.----- http://www.repairclinic.com/PartDetail/Handle/1070320 ------------ Also for more help,if you require,freezer door disassembly diagram.Please click on the link below:--- http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/M0307112-00004.png ---------------- This should help.Thanks.Helpmech.
Jan 26, 2011 | Refrigerators
I want to replace the white door panel with stainless steel
Have you checked with www.applianceart.com? They have faux stainless and real stainless options. PLus a ton of other choices there.
Feb 21, 2010 | KitchenAid 34 in. KUDP01FLSS Stainless...
If i have a problem with my mdb7601aww dishwasher door can i replace it with a stainless steel door instead of the white door
When I searched the parts list for your dishwasher, I only found the door panel available in white but call the manufacturer and ask them because I believe you may be able to change to stainless.
Feb 25, 2009 | Maytag 24 in. MDB7601AWS Stainless Steel...
Replacement Door Panel for GE Profile Dishwasher
Are you trying to replace the microwave door or the GE dishwasher. Either way, www.applianceart.com (under the stainless steel section) has this roll of stainless material that you apply to your appliances. I saw it on the "Today Show." Its basically faux stainless. We put it on our refrigerator and it looks and even feels like real stainless steel. Its really cool. I think its called stainless foil or something like that. Also if you're looking for a stainless panel for your dishwasher they sell actual stianless panels there too.
Nov 24, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Kitchenaid Microwave torsion spring replacement
I just replaced torsion spring 4452396 on my microwave. We heard a "pop" and then the door got heavy. here are a couple things I learned...THE HARD WAY!
We had the stainless steel front to the door and needed spring 4452396, not 4451008. The stainless steel door is heavier so therefore a stiffer spring. I'm not sure i could justify the 4x cost in the part...but that's just the way it is. It's a bit of a pain to repair the thing..so it's worth it to get the correct spring. You don't wan to be doing this every couple of of months!
You have to remove the front panel of the door to access the springs. there are 2 of them...they cross each other in an "x" pattern on the lower part of the door. We had to pull the unit out a bit to get the spring in the hole for correct position. No need to remove the door etc. If you need help with this...email me.
My mistake was when I was trying to figure out how to gain access to the springs I assumed you did from the inside of the door. I removed the two black things you see on the lower right/left of the door (screw on the bottom of them) then proceeded to remove the two recessed screws on the inside top corners of the door. Well next thing i know.....CRASH! the whole front of the door fell off and shattered! Come to find out those screws and brackets on the bottom hold the face of the door on. The glass is intergrated into the color panel of the door..so it's one piece! 150.00 later and a new piece of glass/panel i learned a hard lesson.
Let me know if you need help...it's fairly easy to do now that I look back on it. dave dlacki@gmail.com
May 14, 2008 | KitchenAid Architect Series KEMC308KSS...
SHU 43 Built in-removed door, clips fell out
Those clips will fit into slots on each side of the door frame just above the hinges, Put them back into the frame, then install your new stainless panel. If they fall out b/4 you can get the panel back on, try taping them to the door frame with some masking tape to hold them in place while you secure the stainless panel.
good luck.
Feb 07, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Door handle loose
they are a vivration attenuator and yes are spacer too, but are a little dificult to mount if the machine are working well ok leaved like that but check every coples of month for a loose screew.....good luck and rate me
Jan 10, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch 24 in. SHU5305UC Built-in Dishwasher Logo
252 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
