Question about Seagate FreeAgent Pro Desktop - 320GB - 7200rpm - 480Mbps USB 2.0, 300Mbps External SATA ... Hard Drive
Free agent desktop
I have used this device before, but one time i removed it from the computer because I was moving. When i tried to hook it up and retrieve my files it was not available, the path could not be found, going t o my computer did not find either
What can i do
  • 2 more comments
  • goffngm Feb 09, 2008
    I have a Seagate FreeAgent 320 hard drive device which I have used before. I have removed it from the computer. When I hooked it back up, I was unable to retrieve my files, the path could not be found, my computer did not find my files.
    What do I need to do to correct this problem.
  • Slider240 Mar 06, 2008
    It use to work, not it just blinks and "My Computer" doesn't even recognize that there's a device connected....help please!
  • cagui2254 Oct 05, 2008
  • Anonymous Dec 20, 2008
    My items can not be found after the hard drive has been plugged in for awhile
Installed a new 500 seagate now the computer says "no hard drive found" any suggestions? thanks
Posted on Feb 18, 2008
Just bought the GoFLex Pro 750 GB. I have two PCs, both on XP... neither can see the HD via my computer... I have done a check via computer managment and it says the HD is fine... but it is not...
Hi, Thanks for using fixya.
Remove any usb devices from your computer other than your Free agent then reboot the computer see if it is reconized and it is useable. Then plug in your other devices one at a time make sure you see the Your device is ready to use. If your Free Agent is not reconized got to Seagate.com search for your device driver. Remember when you want to pull out any usb device make sure you remove it throught windows first. Fastest way is to go in My Computer or Computer right click on the device and choose eject. After the name changes to removable device it is safe to pull our.
Hope this helps,
Terry
Feb 17, 2011 | Seagate FreeAgent GoFlex Pro 750 GB USB 30...
My verbatim will not load says there has been an exception....what do I do?
Most problems relating to "External Devices"
Understanding Windows Defender
Real-Time spyware protection alerts you when spyware and other potentionally unwanted software attempts to install itself on your computer. Depending on the alert level, you can choose one of these to apply to the software.
Quarantine: Moves the software to another location on your computer, and the prevents it running until you choose to restore it or move it from your computer.
Remove: Permanently deletes the software from your computer.
Allow: Adds the software to the Windows Defender allowed list and allows it to run on your computer. Windows Defender will stop alerting you risks that the software might pose to your privacy or your computer. Add Software to the allowed list - only if you trust the software and the software publisher.
You can choose the software and settings you want Window Defender to monitor, but recommend that you use all the real-time protection options, called agents Real Time Protection Agents!!!!
I hope the above information is of some use!!
Feb 11, 2011 | Verbatim External, USB 2.0, 750GB...
MY Seagate Free Agent Pro 750GB External Hard drive is no longer registering on my computer. It's only about 1/3 full and I need to recover the data. The software on my computer does not detect a free...
Sounds like the enclosure has a problem. If this is one of those free agent go flex drives with the removable USB to Sata interface you might try getting another drive like it and borrow the interface from that drive when you need to use this one. That's something I have to do now because one of my interfaces died also.
I’m happy to help further over the phone at https://www.6ya.com/expert/matt_7e951e081251ffbc
Jun 30, 2017 | Seagate ST307504FPA1E3-RK FreeAgent Pro...
Hello, I just bought a Seagate Free Agent Go 1
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Nov 20, 2010 | Seagate FreeAgent Go (ST910004FAA2E1RK) 1...
How do I fix the dcom server launcher, the computer keeps shutting down after it's been on for about five minutes?
Click Here to Download this program (its free). Install it. Update it. Run a FULL scan of your computer (took about 30 minutes and the viruses didn't pop up until the very end of the scan). Delete ALL of them (note: you have to reboot to delete the ones in windows system 32) There will be a list of about 5-10 infections they should be similar to:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\tdssdata (Trojan.Agent)
HKEY_LOCAL_MACHINE\SOFTWARE\tdss (Trojan.Agent)
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\Tcpip\Parameters\NameServer (Trojan.DNSChanger)
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\T cpip\Parameters\NameServer (Trojan.DNSChanger)
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet003\Services\T cpip\Parameters\NameServer (Trojan.DNSChanger)
C:\WINDOWS\system32\tdssadw.dll (Trojan.Agent)
C:\WINDOWS\system32\tdssl.dll (Trojan.Agent)
C:\WINDOWS\system32\tdssserf.dll (Trojan.Agent)
C:\WINDOWS\system32\tdssmain.dll (Trojan.Agent)
C:\WINDOWS\system32\tdssinit.dll (Trojan.Agent)
C:\WINDOWS\system32\tdsslog.dll (Trojan.Agent)
C:\WINDOWS\system32\tdssservers.dat (Trojan.Agent)
C:\WINDOWS\system32\drivers\tdssserv.sys (Trojan.Agent)
Thanks for using Fixya!
Jan 31, 2010 | Computers & Internet
SimpleTech 250GB External Hard Drive can't be recognized
First of all,
uncheck the "Allow the computer to turn off this device to save power" option in the device manager for USB Hub Properties, Power Management Tab.
Try rebooting the computer once as C:\Windows\inf\INFCACHE.1 file may be corrupted and need to be replaced (either restore a previous version or just delete it and try connecting again).
Next,completely uninstall all USB devices and the main hub and then re-install.
Sep 07, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
How to partion seagate Free Agent Pro in Windows XP
First make sure that you have a bootable Windows Vista installation DVD, as you will be unable to use your computer if you don’t. Next, download the GParted Live CD and burn it to cd.
Boot off the GParted cd, and you will see your hard drives in the drop-down list. The first drive is typically your boot drive, but you can check the Flags column to make sure.
Next you’ll need to right-click on the partition and choose Resize/Move from the menu.
Now you can either use the New Size textbox, or just click and drag the partition to make it smaller (or bigger). When you are done, click the Resize/Move button.This doesn’t immediately apply the changes, though. You can make other changes to your partitions and then when you are finished click the Apply button.Depending on the amount of data and the speed of your computer, it can take quite a while to resize the partitions. On my computer it took more than 30 minutes.
Once it’s done, quit, remove the live cd and then reboot your computer. Unless you are very lucky, you’ll be greeted with this horrible error message saying “Windows Failed to start. A recent hardware or software change might be the cause.”
Hope this helps!
Sep 07, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I reformatted my C: drive and ever since Windows will not recognize my Seagate External Free Agent hard drive. It shows up under ?My Computer? as Removable Disk (I: )? It used to be listed as Seagate...
Try connecting it to another computer. If you can see your data then back it up etc.
After you have recovered your data connect it to your computer, from Disk Manager, remove the partition, recreate it again and then format the drive, hopefully your external drive will be operational again.
There is a possibility that the hard disk has died and you will have lost your data. If you are desparate, hard drive data recovery companies charge an arm and a leg to recover data from dead drives.
Jan 10, 2009 | Seagate Free Agent Go Small 12 GB USB...
Installation issue - Not recognizing
hmm, no problem plugging in either side, just be sure to do the power cable first. What's doing the beep, beep?
Found a guy who had similar prob, here was his solution:
Go to Control Panel. Click on Device Manager.
Check to see if FreeAgent is shown as a disk drive.
If not, check the device list for any Free Agent device, double click and check driver. No driver installed? Update does not work? On the driver tab….click uninstall device.
Shut down computer. Unplug Free agent USB and power at the drive.
Reboot computer. As it is rebooting, plug in the power cord. Wait a minute or two….then plug in USB cord.
Windows will “found new device” ….. Just let the computer complete the reboot.
Then go to the device manager. Chances are you will find Free Agent in the drives….and in the USB list of devices. Open windows explorer….and you should see you Free Agent as a drive.
Windows will ask you to install manufacturer disk. You have no disk…non needed. Windows has installed the device. Just click on close. I you keep getting windows wants to install device…..ignore it. You can click on “don’t ask again”. (That is if your Free Agent drive is showing in the device manager as a disk…and in windows explorer….along with your other drive or drives.)
If at some later time….your Free Agent drive does not appear….repeat the steps as listed above.
(You may think it is not working….or that it has gone bad. Try this before you try to return.)
Seagate Tools…the new version….does not recognize to diagnose the Free Agent….
I have not tried Seagate Tools after getting the computer to recognize the drive.
I am surprised Seagate does not provide a Tool to recognize their own drives…and install and/or test Free Agent.
This does work for me with Vista. Thought I had lost the drive…. Seagate should provide a patch or a drive that Windows will recognize when you get the “found new hardware” and Windows asks you to insert manufacturer’s installation disk. I do not understand why that is not already there….a driver file for Free Agent...that Windows would install.
I did not buy Pro….because I did not need the backup software. I wonder if those who bought Pro are having these problems.
Oct 30, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Seagate FreeAgent Pro Desktop - 320GB - 7200rpm - 480Mbps USB 2.0, 300Mbps External SATA ... Hard Drive Logo
259 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
