The volume control on my
Bose 38 lifestyle system will not adjust the system, with either the remote or the volume controls on on the console.
On a Bose 38, the volume will self adjust at start, and then you will be able to change volume using either radio remote, or buttons on main unit (the one with DVD).
If the unit is not responding , then there is a fault.
A fault where the Bose 38 is working (eg. you can swap from DVD to AUX on bose), but you cannot control volume (you do not see the values on main unit display) is rather unusual.
Ensure that you have correctly connected TV, receiver, or any other external device to the bose in Input, not in output from Bose.
If you have an HDTV, use the optical input on Bose, that is the only digital audio in on a Bose 38.
Check if the problem depends on connections, if it does not, let me know.
