Question about Garmin Foretrex 101 GPS Receiver
How do i get my Garmin Forerunner 101 Open
My Garmin Forerunner 101 is working fine, but has something rattling around inside. Id like to open it up and find out what it is. Its currently working fine.
  • sgrosskleg Sep 03, 2008
    trying to get the unit open for repair and i can't seem to figure it out
3 Suggested Answers
SOURCE: Garmin forerunner 301
oops, i meant i know its NOT the oxidation problem
Posted on Aug 01, 2008
SOURCE: Change battery on Garmin Forerunner 301
Hi - look at this solution for a forerunner 201, which has the same case design. I was just looking myself! R_nz Rank: Apprentice Rating: 96%, 8 votes I've made some progress here, I discovered that there is a small notch beneath the flat black pastic insert that holds the rubber button cover in. By gently prising this out, I can at least expose the pcb with the buttons on. I still can't figure out how to open the case though ****! Comments: Jan 29, 2008 - Well, I got there in the end! As above, I managed to prise the plastic insert cover off the rubber button cover, the peeeled this off as well. Underneath is a mylar printed circuit with the silver domeos of the buttons moulded in. This is siliconed down, but you can peel it up with a fingernail. The top left end (above the on button) is aatached inside the case, so start at the other end. Jan 29, 2008 - .ctd.. Once you have lifted the mylar strip, you can get at the case seam underneath and prise it gently open with a flat blade. The case is glued together with a light silicon or something. My problem was unresponsive buttons and by detaching and then re-attaching the small connector by the big silver block where the mylar attaches to the main board and then re-attaching it, it seemed to fix it! :-) Oct 22, 2008 - As an end-note; I glued my 201 back together with a light Silicone sealer. It seems to be at least rain proof anyway. Forerunner 201 battery replacement (Expert level): Opening the 201 was not easy and could not be done 100% clean, but thanks to R_nz (above) I got it open. My problem was dead (almost) battery, after 6 years of superb operation. I found the battery to be glued (double sided tape) to the back cover. To remove, push it up slowely and pull out. Beware of the short wires. 1. It is a flat battery, wrapped in shrinkable tube. Made by MDTechnology, P/N 043048 3.7V, 500mAh see http://www.mydbattery.com/EN/products.asp?ID=12 2. On the cover, the battery is soldered to the underside of a small PCB, hard to get to (by expert!). If you find a battery, suggest to cut the wires and solder wire-to-wire. Hope that helps
Posted on Jul 08, 2009
My garmin forerunner 101 won't receive a signal
Try giving the unit a hard reset by following the instructions in the link provided http://www.heartratemonitor.co.uk/garmin_forerunner_201_reset.html.
Hope this helps!
Feb 08, 2011 | Garmin Forerunner 101 GPS Receiver
Tip
Garmin Forerunner 101 manual.
Follow this link and download manual for personal trainer Forerunner 101. <a href="http://static.garmincdn.com/pumac/Forerunner101_OwnersManual.pdf">http://static.garmincdn.com/pumac/Forerunner101_OwnersManual.pdf</a>
on Feb 26, 2011 | GPS
My Garmin 101 won't turn on, even with new batteries. Any ideas?
You said your watch was a "101", I assume that is a Forerunner 101.
The instruction say "press and hold the power button until the welcome page is displayed".
Perhaps you are not holding on to the power button for long enough?
Incidentally, if you do not have a copy of the instruction manual, you can obtain a copy from their web site "garmin.com". "Select support" and "manuals", fill in all three boxes and select your manual from the list given.
Jan 26, 2010 | Garmin Forerunner 101 Gps Training Watch -...
The watch has been working fine and suddenly will
I would recommend having the charger checked for good electrical flow and I would also have the rechargeable battery inside the watch checked. Even capacitors need to be replaced every so often because they just get wore out. Also, be sure that you arent exposing your charger or watch to extreme temperatures as this will cause problems.
If you have trouble finding a shop that can do this you can contact Garmin support directly at:
1-800-800-1020
or
garmin.com/support
Sep 19, 2009 | Garmin Forerunner 205 Gps Training Watch
My garmin 305 only operates when connected to charger. It says that the charge is complete but does not operate when not connected to charger.
Go to the garmin website and install the firmware update.
http://www8.garmin.com/support/download_details.jsp?id=1421
Took about 5 minutes to do the whole thing. Seems to work fine now. Didn't even loose data.
Jul 29, 2009 | Garmin Forerunner 305 GPS Receiver
Jul 08, 2009 | Garmin Forerunner 301
Water inside Garmin, so no display.
This was recommended by Coopers4508 under the Forerunner 201 thread, and it worked equally well for my Foretrex 101.
As Coops said:
I know it sounds crazy, but worked without damage. Placed the forerunner in a table vice (long end to end) and gently applied pressure, opened right up.
It worked perfect for me - just be sure to compress slowly and listen for the separation of the centre seam. A very tidy solution.
Feb 09, 2009 | Garmin Foretrex 101 GPS Receiver
Garmin forerunner 205 won't stay turned on
The battery circuit connects to the main board with spring clips, near the top of the case. If the case is coming open it can cause the unit to spontaneously turn off. These spring clips may also be a little corroded from sweat or water that has leaked into the unit. Try squeezing the top of the unit gently a few times to wiggle the clips inside the case.
If you feel up to it you can open the case, clean and bend the clips, and seal it back up with silicone adhesive.
Jun 21, 2008 | Garmin Forerunner 205 GPS Receiver
Garmin Forerunner 305 cannot locate satellites
Hey, I install Garmin GPS Chipset Type G and now it seems work well.
Mar 01, 2008 | Garmin Forerunner 305 GPS Receiver
Garmin forerunner
Nov 21, 2007 | Garmin Foretrex 101 GPS Receiver
Garmin Foretrex 101 GPS Receiver Logo
559 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
