Question about Sony PlayStation Portable (PSP) Console
Cannot see screen on television
Just bought cables to connect psp to television and only receiving sound. Have checked connections and all is correct. is there something on the psp itself that needs to be programmed
  • lkrogan Oct 19, 2008
    I have purchased the TV-Link with the 5 cables, and still only receiving the sound and not the video through the TV. I have followed the the instructions ie: pressing the display button etc to have the video appear on the TV- but still nothing. TV Link instructions state this is the cvable required for the PSP -2000 Series model, which I have. Any suggestions ??
Hi, you have to use the RGB cable, the cable that has FIVE RCA connectors in one end, to play games. The COMPOSITE VIDEO CABLE that has only three RCA's will let you ONLY watch some videos.
Make sure you have the right one.
Posted on Feb 07, 2008
Connect tv audio input output receiver
Just make sure that you are using cables that are configured correctly physically and check to make sure that you are using the correct analog or digital signal necessary. Your audio settings need to be checked out and set accordingly. Check directions carefully.
Sep 03, 2017 | Sony DAV-DZ100 System
Hi how do I get surround sound coming from my tv
A Samsung home theatre system can make watching movies at home like going to the theater. Proper setup is essential to get the full benefit of the Samsung system, which is available in 5.1 and 7.1 channel surround sound configurations.
Typically the final step in setting up any home theater is connecting your TV to your system.
Like most home theatre systems, your Samsung home theater receiver will allow you to plug all of your components into it, meaning you only have to run a few cables to connect your television to your system.
Make sure your playback devices are properly connected to your receiver.
Whatever playback devices you use, make sure they are plugged into the appropriate inputs on your receiver.
DVD and Blu-ray players, satellite boxes and cable boxes should all be plugged into video inputs, and CD players should be plugged into audio inputs.
Your receiver will have labels on the back panel indicating into which input you should plug your devices.
Connect the video out to your TV's video input. Make sure you use the correct cable to make the connection. For newer receivers, the connection will likely be either HDMI or component.
If your receiver has an HDMI output, use an HDMI cable to connect the receiver to the HDMI input on your TV.
If your receiver uses a component output, use a component cable to connect your receiver to the component input on your TV.
Connect the audio output of your TV to one of the audio inputs on your Samsung receiver if you want to output your television's audio through your home theatre system.
Most recent TVs will either use an optical cable or a digital coaxial cable to connect to the receiver, allowing you 5.1 channel surround from your television.
If you have an older set, you will likely have to use standard RCA cables.
Turn on your receiver and press the "Setup/Menu" button on your receiver's remote.
When "Input" appears on the display, press the right arrow key on your remote to select TV from the list.
After selecting TV, press the up or down arrow keys on your remote to select the audio input jack into which you have plugged your TV's audio cable.
Press the "Exit" button on your remote to exit the setup menu and lock in the settings.
Samsung home theatre system owners guide download
http://downloadcenter.samsung.com/content/UM/200903/20090327091825515/HT-AS730S-XAA.pdfalso
If you're not an electronics junkie, hooking up your surround sound can seem daunting.
There are so many wires and settings that it's understandable why some people might rather pay someone else to do it for them.
But you can do it yourself as long as you make sure the speakers are positioned correctly; the wires are not only plugged in all the way, but plugged into the right places; and the settings on your television and amplifier are set up correctly.
Check to make sure your surround-sound speakers are correctly installed.
Locate the test function on your surround-sound remote control or amplifier panel to do this.
You will know your speakers are hooked up if sound comes out of each speaker during the test.
Make sure your audio cables are hooked up properly.
Make sure the audio cables running from your television to your amplifier are plugged in correctly. The red and white wires should be plugged into the "Audio Out" spot on the back of your television.
Those same red and white audio wires should be plugged into one of the "Audio Input" spaces on the back of your amplifier.
Turn on your television.
Locate the "Menu" button on either your television remote or your television set.
Scroll through your options until you find "Audio Mode" or a similar naming convention.
Select it.
Scroll through your options until you find "Digital Audio Out," or a similar naming convention. Choose it.
Scroll through your options until you find "Dolby Digital Out." Select that option.
Power your surround-sound system on.
Make sure you have the correct audio input selected.
After the correct audio input is selected, make sure you actually have the Dolby Digital aspect of your surround sound system turned on.
The default for most surround-sound systems is the standard two-channel, stereo output.
Set up a home theater
http://www.cnet.com/1991-7386_1-6214422-7.html
Aug 07, 2013 | Samsung Ht-E355 330W 5.1 Channel Home...
NO sound, display says CHECK SP cable? Just bought yamaha292 theater system with AV receiver HTR-6230, all speakers are wired, plug with 1 optical to my TV, selected the inputs and there's no sound. ...
Probably the speakers are not wired correctly. Check this by turning on the receiver without speakers connected. If the message is gone, issue was in the connection of speakers. Check that you have not short-wired the + and -.
Dec 13, 2009 | Yamaha HTR-6130 Receiver
My HDTV has a black screen. Everything is normal except for a black screen. What can I do?
This may be a connection problem. Here is something to try:
Turn off your system and check the connection to the HDTV system and make sure the cables are plugged in correctly. Then check the connections from the HDTV to your Cable box or Receiver.
Then turn it back on and see if it comes up.
Good luck,
SH
Sep 30, 2009 | LG RU-42PX10 42 in. HD-Ready Plasma...
When i connect psp to tv(hd) the screen apears red. Pls help.
It sounds like either the cables are reversed, loose, or possibly bad. This is what happens when a cable connection is not "solid". Please make sure all the cables are attached securely and in the correct order, if they are you may need to replace the cable. If it still happens with a new cable, it is probably the input on your TV that has an issue.
Aug 30, 2009 | Sony PlayStation Portable (PSP) Slim...
PSP2000 SONY GAME
no you cant... the t.v screen cant support the games of psp.
Mar 11, 2009 | Sony PSP (Piano Black)
No picture, blue screen
Use the TV input selector to select the right channel, that should fix it.
Jan 04, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Playing psp game in tv using component av cable
i have connect the psp av cable but i can't play psp games plzz guys help!!!!!!!!!!!!!!!!!!!!!!
Apr 18, 2008 | Sony ACY-BR81/OB
No sound dell 32in tv
These are the answers straight from the dell manual. Ensure that the audio cables are firmly connected to both the audio input connectors on your LCD TV and audio output connectors on your PC or Video player. If on certain TV channels you receive a picture but no sound, this means that you do not have the correct TV system. Modify the SYSTEM setting. Check if TV volume is turn off of muted Connect the audio cable securely Audio cable is connected incorrectly Verify that the audio source is selected correctly in the OSD
Jul 31, 2007 | Dell W1700 17 in. HD-Ready LCD Television
Hitachi 42" plasma TV (42PD6600)
IF you are saying that every thing is connected properly check your video cable it could be bad use a new one if that does not rectify your problem it is time to call in the tech you could be having problem in your video circuit but you did not mention if the screen light up with no picture but with sound or it does not light up blank with sound.however there could be two things 1 if the screen lightup with normal sound it could be a leaky ,open, or shorted, transistor or ic in the IF circuit.2 If the screen does not light up and has normal sound it could be a defective horizontal stage.so it is time you take the set to a tech for repairs.good luck.
Mar 26, 2007 | Hitachi 42HDT52 42 in. Plasma HDTV
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
