- SET THE AIR INLET DAMPERS
It is not possible for the manufacture to factory set your stove to work properly without some adjustments. The dampers help control the amount of airflow supplied for combustion.
A damper PUSHED IN all the way, maximizes concentrated air flow to the burn pot. This will maintain a robust fire.
The Auger timing is designed to be run, in most conditions, with the dampers closed.
In some areas/conditions, it mybe necessary to adjust the damper open slighty in order to slow down the flame and allow the pellets to keep pace with the rate of burn. This should be monitored closely to ensure you have the propoer feed rate established. If dampers are opened too much, the rate of burn will be very slow and the pellets will build up.
This setting needs to be fine tuned to according to your location and elevation. It is recommended that you start with the dampers pushed in to start.
