Question about Samsung LN-T4671F 46 in. LCD Television
Trouble removing the stand
Me and a guy tried for over an hour to remove the stand and we couldn't find a screwdriver to fit the grooves it looks like a regular screw but the grooves aren't deep enough to grip so what do i do please help thank you
  • gnicol Feb 16, 2008
    I have the same problem. It has taken 2 hours and I only have one screw of 4 out.
    The instructions only talk about 2 screws, but it appears there are 4.
    My screw driver is turning the screws as I can losen then and then feel then stop when I re-tighten them.
    They are so deep and you can't see what you are doing. The last think you want to do is screw up such an expensive piece of hardware.
  • Anonymous Feb 18, 2008
    i have the same problem but i had taken off four screws at the back, marked with holes with an (s) is there any lock or any thing else i have to depress to get it out can i get an detailed description.
    Thank's
  • 29 Answers
There are 4 screws lay the tv flat on it's face and leave the stand hanging over the edge of the table, put a blanket under the tv to protect the screen, hold the stand up to take the pressure of the screws and use a philips head driver with magnetism, I do this for a living and you should not be having such a problem
Posted on Mar 15, 2008
Halfshaft will not come out of passerger side differential
Try Autozone's loan-a-tool deal. The typical half-shaft remover is a fork that fits between the inner CV's housing and the transaxle case. The fork is attached to a slide hammer, only takes a blow or two to pull the half-shaft free.
Another way is to get a large screwdriver or pry bar or punch, use it against the inner CV's housing, tap it outward with a hammer. If you can get a good whack on it, it usually frees the axle. There is a circlip (ring) in a groove on the inner end of the shaft. This circlip fits in a corresponding groove in the transaxle gears. Once the ring clears the groove, the axle will slip right out.
Oct 04, 2015 | 2000 Suzuki Vitara
Tip
C45 Cross Trainer drive belt replacement
Needs
Cost = £25 for drive belt + any tools needed (saving of £150 - £200).
Tools = Long shafted crosshead screwdriver, 3 & 4 & 6mm hex keys, metric spanners, ratchet tie-down luggage straps (2), wire twists.
Time = 3-4 hours.
Difficulty = Moderate.
General
The 15mm grooved belt is tensioned by a spring loaded jockey pulley. Dealing with this is the crux. Handing is relative to front view of the machine. Beware of magnetic field near brake when running under load - pace-makers, watches etc.
Procedure
1. Disconnect dc supply and remove plug. Clear access is needed to both sides, with most of the work done from RHS.
2. Disconnect both drive arms from the drive discs using hex key. Pull front ends outwards to clear the trunnions. Push both arms back out of the way. (Drive discs cannot be removed without special tools).
3. Remove RHS cover using crosshead driver to undo screws in deep slots round edge.
4. Remove dc socket from LHS cover (hex nut) before removing LHS cover.
5. Working from RHS, note layout of electromagnet brake unit. Cut out old belt. Remove jockey spring.
6. Plates on either side clamp the magnet core. Remove the RHS plate only (which also carries the jockey pulley crank). Remove hex nut on end of brake pulley shaft. Use spanner and hex key to remove 4 long bolts one at a time and partially reinsert each from LHS - this prevents the short aluminium spacers on LHS from falling out. Don't lose the long spacers or the crank mounting bell washer from RHS. Remove 2 short screws from lower edge of plate using hex key. Each has a plain and a spring washer. Do not slacken the corresponding 2 screws on LHS, since that risks disturbing the distance between the driving and brake axes.
7. Remove old belt debris and clean.
8. Pass new belt over RHS drive disc. Fit centrally into grooves on topside of disc only, leaving enough slack to fit centrally round the small brake pulley.
9. Grease mounting washer and replace crank with jockey pulley hanging underneath belt. Refit RHS plate, starting with the spindle hex nut. Take care that each bolt passes through both long and short aluminium spacers. (There seems no reason to remove and reinsert the bolts from RHS - this only increases the chance of dislodging the small spacers). If a spacer does move, use a wire twist to hold in place temporarily while inserting bolt. Ensure that all bolts and screws are fully tightened before step 10.
10. Refit jockey spring, ensuring that the pulley pushes against belt's lower surface. Anchor ratchet tie-down to back foot of machine, wrap round crank arm, then pull back spring as far as possible. Use 2 tie-downs for safety and maximum tension.
11. Slowly rotate RHS drive disc anticlockwise while keeping belt central on both pulleys. Use a screwdriver blade to prevent the belt jumping the grooves on the brake pulley and slipping off the jockey pulley. Once the belt is grooved, keep turning to check that it runs true - no grooves should be visible on the brake pulley. Use side pressure while turning to re-position. Mind your fingers.
12. Release tie-downs very carefully, since the spring reacts with a bang. Temporarily attach drive arms and dc supply. Test. When satisfied that all is OK and belt runs true under load, detach drive arms, replace LHS cover, dc socket, RHS cover, drive arms, and plug in dc supply.
on Jan 22, 2015 | Tunturi Exercise & Fitness
I have dry hardened dough stuck in the motor area, i need to open it up and remove the flour which is ratteling
hi. 1. remove the screw near the cable. 2. use something sharp, small and robust to lever out the white screw cover which is underneath and in the middle. it looks like plastic moulding. 3. the screw head has a raised middle in the flat head groove. I put a medium flat head screwdriver in a vice and used a hack saw to remove some metal in the middle. it only took 15 minutes so don't be put off. unscrew. 4. lift off the cover. 5.use a toothbrush and the something pokey to clean.
Feb 04, 2013 | Breville SHM2 Twin Hand and Stand Mixer
How can the sebo k3 be dismantled to fit a new cable ?
I wrote this guide originally for dismantling the Sebo K1, but I believe that with respect to the cable-rewind, the K3 is pretty much identical. So here goes:
1. remove the hose
2. remove the hose-retaining ring
3. remove the flap that covers the green filter.
4. remove the screw beneath that flap nearest to the handle (there's a deeply recessed screw on the other side, but you can ignore that)
5. remove the clip at the back of the machine where the airbelt joins (lever it off carefully with a screwdriver)
6. this is where it begins to get interesting. The airbelt is in two parts - the bulky foam strip and a thin material cover. The cover is held in grooves, top and bottom, running all the way round the machine, by two thin plastic strips around which it is wrapped and which just slip into those grooves. The first challenge is to get those strips, and the covering material, out without damaging them. Just prise one end out with a small screwdriver and work your way around the machine - it's more a matter of patience than anything else. (The second challenge is getting it back neatly!)
7. remove the ends of the foam strip far enough to reveal two plastic clips that hold top and bottom of the body together
8. prise those clips off with a screwdriver.
9. it should now be possible to lift the top cover off. It can be a bit fiddly getting it off over the neck where the hose plugs in, but it does come off.
10. the cable rewind spool is now revealed in all its glory.
11. if you've found my advice helpful so far, here's a final piece... don't try to fit a new cable to the old spool - fit a complete new spool.
12. good luck!
I value feedback, so please remember to rate this response.
Jan 20, 2010 | Sebo Vacuums
Horseshoe clip back on?
Lay the clip on the turntable with the legs in the groove. Using needle nosed pliers, point them straight down and reach down and squeeze the clip into place.
Jul 25, 2009 | Aiwa PX-E860 Turntable
I have a SEBO air belt k. The wire retraction is not working. I dont see how to get a look at the mechanism. Can you help?
OK, but be warned... it's not so difficult getting the thing apart, but making a neat job of reassembly has been known to drive grown men to despair. And that's because you have to remove the airbelt. But first things first:
1. remove the hose
12. good luck!
May 03, 2009 | Sebo Air Belt K2 Bagged Canister Vacuum
How to change door seal on hotpoint m w a 60 washing m/c
you need to remove the outer retaining ring which is a wire around the lip of the seal typically joined with a spring., using a small screwdriver.
the inner retainer is held together by a ratchet type assembly. prise one end of the wire by twisting the folded end of the wire out of the groove til it comes free.
replace the seal. fit the inner retainer together using some long nose pliers, prefferably bent-nosed. the outer retainer with a screwdriver.
Feb 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
No power steering
You need to put the car up on axle stands or ramps. Look for a lose or missing power steering belt, fluid leaks from hoses and fittings. You should check the fluid level first since you can do that from under the hood. Look up online repair guides to see if you want to try it yourself or take it to a garage.You might be able to fix leaking fittings by simply tightening them. So it's worth a try if you have ramps or axle stands.
Jan 28, 2009 | 1997 Pontiac Grand Am
How do I change belt on Eureka Capture
lay your vacuum completely on its back on the floor, like you are going to vacuum under a bed, then turn it over on its "belly", you should be able to see the bottom of the unit, where there are 2 small wheels ..... look where embedded in the plastic are #'s 1-4 there are 4 screw pockets, 2 in front and 2 in rear, those are deep, so you need a phillips screwdriver with a long skinny barrel to get in the deep pocket.remove those 4 screws, stand the unit upright, then grasp both sides of the "hood" of the unit remove the the plastic cover, you should see the belt on the right side as you face the vacuum. If the belt is broken, just pull up on the brushroll , removing it from the base. Clean any hair,thread, etc.. from the brushes, and ends , place new belt over the motor shaft (looks like a nail sticking out toward the back of the belt area) slide the brushroll through the other loop of belt in the belt groove, then slide the stop sign shaped end pieces in the grooves in base , pressing down until it is seated in place, gently turn the brushroll with fingers watching the belt making sure it is staying straight , then place the hood of vacuum back in place, make sure it fits correctly, recline handle again all the way down, roll vacuum over again to place screws back in bottom of unit.
Jan 11, 2009 | Eureka Luxury Family 8-Person 2-Room Titan...
Removing the mounting stand
You've probably worked it out by now, but I thought I'd post the answer anyway, for anybody who may come looking in the future......
If you look at the back of the monitor you'll see two screws which can be easily removed. What's not as obvious is the THIRD screw. To get at it you need to remove the top plastic section of the stand; I carefully inserted a blade screwdriver in the groove, then gently twisted it in a few places. There's no need to dismantle the rest of the base.
It was my 12 year-old son's eagle eyes which spotted that third screw. My contribution to this part of his MAME project was figuring out how to get at it.
I hope that helps someone.
Colin
May 12, 2008 | HP L1706 17" LCD Monitor
Samsung LN-T4671F 46 in. LCD Television Logo
432 people viewed this question
Henry  Thomas
Henry Thomas
