Question about RIM BlackBerry Pearl 8100
Bb pearl won't ring
Hi my blackberry pearl stoped ringing. Everything else works. I looked at all the settings and everything is on and loud. I don't know what else to do.
  • princess12 Feb 07, 2008
    Hi i already checked that and have taken the battery out to reboot it, still nothing. thank you anyways for trying.
  • 80 Answers
Have you checked the "profiles" (click the icon on the desktop). Make sure it is not in silent or vibrate mode.
Hope that helps... :)
Posted on Feb 07, 2008
My bb 8100 track ball will not go left! How do I fix it?
Hello.
Your Blackberry probably just needs cleaning.
Removing the pearl’s cover would the best way to get access to its sensor and clean it.
Carefully remove the silver metal ring that holds the trackball component in its position. The silver ring which covers the trackball can easily be removed if you use a small screwdriver to lift it at the outer side of the ring. Be careful here! all parts have very small plastic pieces which can break very easy. When the silver plastic ring is removed, you will see the inner trackball component which can be removed completely. The trackball component itself can also be carved. For every direction the ball can roll, you’ll find a sensor wheel. You'll probably find that that those wheels are dirty and need cleaning. Once this is done put everything back together to the place the pieces came from and secure the trackball with the silver plastic ring you removed in the first step.
Hope this helps.
Jan 13, 2010 | RIM BlackBerry Pearl 8100
My blackberry suddenly stopped making noise. The ring, alarm or music will not work. It still vibrates but no noise comes out of it.
You have to pop the battery out to reboot it...happens ALL the time!!! I have to do it almost every other day
Oct 05, 2009 | RIM BlackBerry Pearl 8100
My BB pearl 8100 doesn't ring for incoming calls/messages/emails, but if i go to listen my ringtones or music they all sound fine, i think it got corrupted or something because no matter how i change the...
Not sure if the pearl interface is the same as mine, a Storm - I have an option on my main screen to fast-select ring volume (called Notification), which affects both calls and messages, and I can choose loud, soft, vibrate, silent, and also go into options for more detailed settings. You may have such an option that is easy to find, and maybe easy to set by mistake, without realising it.
Pearl manual at this location:
http://docs.blackberry.com/en/smartphone_users/deliverables/1217/userguide_bb8100_gprs.pdf
see p193, Notification Profiles.
There are other keys, eg # that affect notification sounds/vibrate. Download and search in the manual for 'Notification" to find all the places mentioned.
Even if you have a paper manual, I recommend keeping the electronic one since you can easily search for keywords and find all the places they are mentioned quickly.
Sep 11, 2009 | RIM BlackBerry Pearl 8100
My BB Pearl goes straight to missed call without ringing?
you might have the call dirversion set to on. check that in your call settings
Sep 02, 2009 | RIM BlackBerry Pearl 8100
Volume is set for loud but can hardy hear it ring on my
make sure you check all your settings just because your volume is set for high your call ring might be low
Jan 05, 2009 | RIM BlackBerry Pearl 8100
No ringtone or caller id
Press Call Button
Press Blackberry Button
Scroll down to Options
Go through options to see if there is anything obvious.
Gadget
Aug 13, 2008 | RIM BlackBerry Pearl Smartphone
My blackberry only vibrates and does not ring.
Sounds like it just need to change the profile settings. Click the menu button then Profiles and select either the loud or normal profile.
Jun 03, 2008 | RIM BlackBerry Pearl 8100
My ringtones
Check the volume level of the ringer in the settings.
Secondly use a loud tone. There are some in this package http://www.exectones.com/
Mar 31, 2008 | RIM BlackBerry Pearl 8100
Blackberry pearl 8100 doesn't ring
Blackberries are famous for requiring the "take battery out and put back in" proceedure to reset things. Give it a try if you have not yet.
Hope that helps.. :)
Feb 07, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry  Pearl  8100 Logo
121 people viewed this question
Top RIM Computers & Internet Experts
ismael castillo
David
Jerry Greenberg
Jerry Greenberg
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
