Question about InFocus Proxima DP1000X Multimedia Projector
Proxima dp 1000x
My projector shuts off by itself. i'm wandering if it shuts down before the bulb shatters, cause the bulb has 1,069hrs on it i;m not sure how long it is supposed to have on the bulb before it is no good. i just dont want to buy another bulb if that does not fix the problem. please help me.
  • 2,237 Answers
The lamp is good for 2000 hours. it may shut down due to fan obstructions, overheating, or the colorwheel is bad and needs replacing. also, the power supply/ballast may need replacing.
Posted on Sep 03, 2009
Proxima dp6150 shuts down unexpectedly
the interface between the mother-board and the power-supply is not work well
Add some solder on the interface , it will increase the contact surface
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, motherboard,
powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 18, 2014 | InFocus Proxima DP6150 Multimedia...
Tip
Dp5600
i bought a projector from a friend but the red light keeps coming on what causes this
on Mar 04, 2008 | ASK Proxima L114 Projector Lamp for...
The source is constantly switching from video to computer
try brand new cables and reflashing the firmware. if this fails then your main board is likely the culprit.
Jul 22, 2010 | ASK Proxima DP1200x Multimedia Projector
Can the bulb out of Proxima DP6860 work in a DP6850?
No they will not interchange.
The DP6860 takes a bulb number LAMP-030 and is a 250 watt bulb.
The DP6850 takes a bulb number LAMP-017 and is a 190 watt bulb.
If you could physically make them fit by some means, likely just the wattage difference would cause problems with the projector. These bulbs require much more electronics to light up than what a normal household bulb does. I'm assuming the projector would think the lamp is either burned out or worst case cause damage to the power supply in the projector.
Mar 30, 2010 | ASK Proxima DP6860 Plus Multimedia...
Image looks doble in colors.Gren,Blue Red
Depending on how severe it is, it can be fixed. I can do the repair if you'd like.
Mar 10, 2010 | InFocus Proxima DP6155 Multimedia...
My projector keeps shutting down(sleep mode) after only being on for 5 minutes. how can I stop that from happening?
The problem with you Projector is most likely the bulb. Here is a good guide on how to change out the lamp on your projector:
http://www.fixyourdlp.com/guides/ask-proxima/sp-lamp-017/ask-proxima-sp-lamp-017-lamp-replacement-guide.php
I also suggest reading about the counterfeit lamps and buying the original lamp as recommended by the above link. You may find yourself troubleshooting further for no reason simply by buying an aftermarket replacement.
Mar 04, 2010 | ASK Proxima C160 Multimedia Projector
Projector
lamp is over 2000 hours and needs replacing.
Shuts down
how many hours on bulb take it apart clean it dust it out nice
Feb 05, 2008 | InFocus Proxima DP1000X Multimedia...
White vertical line in the center of projected image
I have a Dell 2400MP projector that had the same problem of vertical white lines appearing over the screen.
This may seem like a simple solution, and I don't know if this will work for you, but the way I solved the problem was simply to press the bottom side of the projector, until the white lines disappear . Until now, the problem has yet to resurface.
Here's some simple steps:
1. Turn on projector
2. Connect projector to computer
3. Focus projector
4. If white vertical line appears, firmly press underside body of projector
5. See if vertical white line disappears
6. If not, try slowly pressing other parts of the body of the projector and see if white lines disappear.
7. If solution doesn't work, you may need to send it to the service center.
Hope this solution works for you.
Best Regards,
Ghazali Ridzwan
http://www.ghazaliridzwan.com
Nov 28, 2007 | ASK Proxima Proxima DP2000S Data Video...
InFocus Proxima DP1000X Multimedia Projector Logo
82 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
