FixYa.com
Tags:
RIM BlackBerry  Pearl  8100
Blackberry pearl 8100 doesn't ring (by 11 users)
posted by princess12 on Feb 07, 2008
Hi my bb pearl won't ring anymore. it was working fine then it just stoped wanting to ring. anyone know what to do. i checked all the settings and everything is activated and on loud.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
10 Other Users Have The Same Problem
Comment by Guest, posted on Jul 06, 2008
It's an 8703e. (the model isn't available in the search string, but this problem is registered with a few blackberry models) It doesn't ring consitently.  It goes directly to VM.  I notice that it is pervasive on a number of forums.  The standard solution - remove the battery and replace after 30 or more secs - is only a temporary fix.  This is the case also with a number of people posting.  If anyone has any other solution, it would be much appreciated by all, I'm sure.  (The phone is out of warranty, of course).
Comment by Guest, posted on Jun 15, 2008
My Pearl, just like these, would not ring. Vibrate worked fine. I took the advice and took the battery out for about one minute or so. After it rebooted, the ringer worked fine.
Comment by Guest, posted on May 06, 2008
my phone was ringing ok up until it just decide to stop..i have tried to do the battery thing it doesnt work i checked the settings its on loud but no ringing...i am missing all my calls i have to be a watch dog so i dont miss anymore....help
Comment by Guest, posted on Apr 29, 2008
I have the same issue with my Blackberry not ringing. Took the battery out (several times) still no ring. Set the ringer to off, removed battery, put battery back in, set the ringer to Loud, still - no ring.
Comment by Guest, posted on Apr 25, 2008
Me too, mine vibrates 3 times (as settings) then rings once and goes to voice mail. Taking the battery out doesn't change anything. Anyone got any other ideas?????
Best Solution
posted on Mar 17, 2008
Helpful (85)
Hitting400
Rank:Apprentice Apprentice
Rating: 91%, 10 votes
I had the same damn problem. Took the battery out and put it right back in and now everything works. I now hear all calls. Hot damn.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Feb 07, 2008
Helpful (85)
joeneighbour
Rank:Wiz Wiz
Rating: 82%, 58 votes
Blackberries are famous for requiring the "take battery out and put back in" proceedure to reset things. Give it a try if you have not yet.
Hope that helps.. :)
Solution #3
posted on Jun 16, 2008
Helpful (85)
ChrisChris70
Rating: 85%, 2 votes
Okay I had the same problem, if you have a Blackberry 8100, go to media, video files, and play a video...if you have no sound tap the top button once quickly (it's the silver buttonon top which has a speaker icon on it with a line go through it,if you still hear no sound use the volume keys on the sound and you should hear the video playing, which in turn will turn on all you volumes for you phone to ring etc.
Hope this helps.
Solution #4
posted on Apr 06, 2008
Helpful (85)
foggolfer
Rating: 85%, 1 votes
Yep, the battery reboot just worked for me on this same problem. Thanks all.
Solution #5
posted on Aug 20, 2008
Not Rated (0)
jlongo
Rating: 0%, 0 votes
Make sure you aren't using a song downloaded from iTunes as your ringtone. They are mp4's not mp3's, and Blackberrys seem to have a problem with these sometimes.
Solution #6
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
Make sure the wireless is on.
Solution #7
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
If it is under a year since you bought the Blackberry, you can get it replaced.  I just did that and I am a happy camper now.  I am in Atlanta and they happened to have a warranty store here. They were very helpful.  If you are not near a warranty store, there has to be a way to mail it in and get another one.
Solution #8
posted on Apr 11, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
okay, any other suggestions? Cause that battery fix didn't work for me.
Can you Help with these PDAs problems?
adress book
microsoft windows xp cannot... Answer This...
No backlight
T he phone is on but we do not... Answer This...
code
so where can i get an unlock... Answer This...
tokajon@hotmail.com
hi can you give a code to... Answer This...
Rollerball Issues
My rollerball sends the cursor... Answer This...
10 Other Users Have The Same Problem - Continued
Comment by dallas8100, posted on Mar 29, 2008
My pearl is not ringing either. I took out the battery and waited at least 30 seconds and out it back in and still nothing. It does vibrate though. Any help?????
My pearl
Comment by stuckey, posted on Mar 27, 2008
My ringer does not ring - I can hear it slightly when I hold it to my ear. Any suggestions.  Have had it under 6 months
Comment by Liz Hertel, posted on Mar 02, 2008
Other than taking out the battery (which did not work) any other solutions?
Comment by renravenous1, posted on Feb 23, 2008
my pearl doesnt ring anymore either, but you can hear the music on the media player so i know the speaker isnt broken on the phone. i've taken out the battery while it was still on and reset it but still doesnt fix it. when i set it to loud in the profiles, it just vibrates and doesnt ring. does anyone know what other steps i should try? i have already uploaded the latest software version as well so any suggestions are appreciated.
Repair Service
Find PDA Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
