Question about Hotpoint Aquarius WF000 Front Load Washer
Flashing lights all across the front
Press ON button and all lights flicker but go off either with bump or switching off at mains,is this circuit board/card failure
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 27 Answers
It may just be the wiering harnes has worked loose also sometimes wires get caught and short out
Posted on Feb 22, 2008
Remote works intermittently on RCA LED32B30RQD television. Not the remote itself but something on main board since I've heard of this same problem but don't know what the solution was.
Here's how you test the remote. Use your camera on your cell phone and shine the remote at the camera. Press each and every button on the remote and watch the results on your phone. With each button press, you will see the led on the end of the remote flash when you look at it on the screen of the phone. If every button produces a flickering light, then the remote is OK. The IR sensor circuits on the main board of the TV are failing. A replacement board can be purchased from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Jul 23, 2017 | RCA Televison & Video
I have zanussi ZWH 6140 P WATER WONT DRAIN ERROR CODE 5 FLASHING RED LED LIGHTS?
First, always check carbon brushes on main motor especially if the appliance is in use for several years.
Five times the red alarm means a problem with the engine washing.
So, could be:
E51 - Motor power triac short-circuited.
Current leakage from motor or from wiring; Main PCB faulty
E52 - No signal from motor tachometric generator.
Wiring faulty; Motor faulty; Main circuit board faulty.
E53 - Motor triac sensing circuit faulty (wrong input voltage to
microprocessor). Main circuit board faulty.
E54 - Motor relay contacts sticking (high voltage level when
the relay switches to OFF).
Current leakage from motor or from wiring; Main PCB faulty;
Rapid reading last alarms:
Press the START/PAUSE button and the nearest option button simultaneously (4 and 6) for at least 2 seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
zwh 6140 p-dd5v0vxzvbk4xzho0hm3qdol-4-0.jpgDado
Mar 01, 2017 | Zanussi Washing Machines
Why does my camera not capture any picture? Whichever mode I use, it does not capture any picture regardless of how many times I click the button.
Flash flicker is the camera trying to get enough light to focus, It occurs when you press the shutter release part of the way down.
Try the same thing outside, ensure you press the shutter real ease all the way down. If it still does not fire, switch the lens to manual focus (sliding switch on the side of the lens, move from A to M) If the camera shoot then, the camera is struggling to auto focus.
Feb 23, 2015 | Canon EOS 1100D / Rebel T3 Digital Camera
I have the same problem that is listed above with my 1/2 horse power belt drive garage door opener. The lights on the sensors are both green and the alignment works, the overhead light will turn on if the...
Sounds like you have a couple problems. The opener is in the lock mode which is the reason the remotes will not work. Press and hold for 3 seconds the button on the wall control that has the icon of a padlock on it. This will unlock the opener and your remotes will work. If when you try to close the door the main light flashes 10 times when the door reverses to the open position it is a door sensor problem. One of the small lights on the sensor may be flickering ever so slightly. Tweak them a bit and try. If this isn't the case and the main light is not flashing you can try increasing the down force just a tad. This control is on the rear of the motor unit near where all those white wires go. Increase this just a bit and try. If this doesn't work you most likely have a bad RPM sensor board which is a small printed circuit board just in front of the motor. It will cause this problem.
Dec 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
My tv won't turn on anymore. The power light and the opc light blink twice at the same time and then the opc blinks once and it keeps doing that. Please help!
Hi
Make sure the AC cord is not loose or disconnected. Check to ensure the cord is firmly plugged into the outlet at one end, and firmly connected to your television at the other end. The AC cord connects to the television about midway across the back of the set, near the bottom of the back panel. The hole for the AC connection is shaped like a figure eight. Try powering up the TV with the cords firmly connected.
Check the "Main Power" to ensure it is on. Locate the button on the top of the television among the "Volume" and "Channel" buttons. Press the button to switch the television on. If the "Main Power" button is off the remote will not turn on the television. Wait to see if pressing "Main Power" will activate the TV.
Press "TV Power" on the remote control to power up the TV from stand-by mode. If the power light on the front of the television glows red when you press "TV Power" on the remote, press the "Main Power" button on top of the television to remove the TV from stand-by. If the TV is accidentally in stand-by mode it may not come on when pressing certain buttons.
Check the circuit board. If your set still won't turn on and you hear a clicking noise when you plug it in, you most likely have a defective circuit board.
Oct 23, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Craftsman 53918 - 3/4 hp, belt drive garage door opener. Wall unit says safety sensors misaligned. Replaced them as suggested by manual, no fix. Does not appear to be any power from where you plug...
The main light flashing 10 times is the sign of a door sensor problem. Check to see if the small light on each sensors is lit and not flickering. If you cannot get both lights to come on your sensors or the wiring to them is bad.
Sep 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman 1/2 hp garage door opener will go up fine with the push of any button but it starts then stops when I try to push the button for it to go down. It acts like there is something in front of the...
If the main light flashes 10 times when the door stops it is a door sensor problem. Make sure the small light on each one is lit and not flickering. If the main light doesn't flash you have either a bad IR sensor which is a small printed circuit board just in front of the motor or you need to increase the down force which is a control on the rear of the motor unit.
May 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chain removed or on - eyes aligned and both eye lights on - button starts cyclemotor runs short while and then reverese - no limits have been reached - even removed the ''middle limit arm'' and still...
If the main light flashes 10 times when the door reverses it is a door sensor problem. Make sure neither light on the sensors is flickering ever so slightly. Sometimes hard to see. If the main light doesn't flash 10 times then it is probably the RPM sensor board. This is a small printed circuit board just in front of the motor. It's job is to reverse the door when it runs into something on the way down but it will give this problem when it goes bad.
Feb 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
My garage door opens fine but will not close unless I press down the button on the wall. The sensor lights are solid and I unplugged it for a minute and I'm still having the same problem.
If your main light flashes 10 times and the door reverses to the open position when you use your remote it is a door sensor problem. It is sometimes very hard to see if one of the sensor lights is flickering.
If the main light does not flash then you can try increasing the down force just a little. This control is on the rear of the motor unit near where all those white wires go.
Check the small LED near the smart/learn button. If it is flashing a code of 5 blinks then a pause and 5 blinks it is the RPM sensor. This is a small printed circuit board just in front of the motor.
Jan 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
The track only goes down about a foot then goes back up a foot and stops
If the main light flashes 10 times when the door reverses you have a door sensor problem. Make sure one of them hasn't been bumped and that they are pointed at one another. Each one has a small light that should be lit and not flickering. Both lights will only be on if they are properly aligned. If the main light is not flashing then you probably have a problem with the RPM sensor which is a small printed circuit board just in front of the motor. Usually when this is bad the small LED near all those white wires will be flashing 5 times then pausing and repeating.
Aug 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Hotpoint Aquarius WF000 Front Load Washer Logo
88 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
