Question about Magic Chef MCBR440 Compact Refrigerator
Magic chef bar fridge
The fridge is only 3 yrs old. It doesn't work now. it doesn't make any noise as though it is trying to work. Everything looks brand new, but it doesn't work. there is power to the outlet that it is plugged in to
  • Anonymous Mar 03, 2008
    two years old, compressor stopped running, and it gets real hot to the touch(the compressor that it)
  • Anonymous Mar 09, 2009
    Same issue. Compressor gets warm but fridge/freezer are not cold.
Have the same problem with my 3 year old bar fridge. I could hear a clicking sound like it was trying to come on. Unplugged it and bought a new one. I figure the cost to repair a $100 bar fridge may not be worth it. They will charge you to come out and then charge you for the parts. For a little over $100 I bought a new one.
On the new fridge, the freezer gets colder than the fridge part..but luckily for me, it is still under warranty (Manufacturer's). I'll call for a look see-who knows maybe that guy can tell me what's wrong with the other one, too. ;-)
Posted on Jul 21, 2008
What could be the problem with my Magic Chef mini fridge model number MCBR465S. It comes on when I plug it in but not cool at all, and the compressor hot, could I trouble shoot and how,freon? Thx
If the compressor is actually running and there is no refrigeration, I would suggest it has a gas leak and that's why it isn't cooling. Depending on what type of refrigerant is in it, it may not be worth repairing as its only a small bar fridge? Check the rating plate to see if its R12 (Older fridges) or R134A . If the unit is less than 5 years old, it may be operating on R32 or R600 (Butane refrigerant gases) If its only a couple of years old, it may still be under Manufacturer warranty. Most fridges carry a 2 year warranty on everything and up to 5 years parts warranty on what is known as the "Sealed system"
Apr 19, 2015 | Magic Chef Refrigerators
Magic chef 10 cu fridge makes ticking noise but works fine
Some times refrigerators make a noise that sounds like a tick. It could be caused from the refrigerant flowing through the lines. This usually happens when the refrigerator first starts up and goes away after a few minutes. the other possibility is a fan motor blade taping the shroud from time to time. The refrigerant issue is not something that can be fixed. The fan blade issue could be fixed by moving the fan blade back or froward on the shaft a slight amount. If you have a 10 cu ft refrigerator it may not have a fan.
Apr 05, 2014 | Magic Chef Refrigerators
Freezer works, fridge is not cooling
please switch off your refrigerator for at least 8 hrs. than again switch it on. if your problem is not cured than it is sure that your refrigerant is not circulating well....... please visit your service authority
May 14, 2009 | Magic Chef CTB1821AR Top Freezer...
Magic Chef Mini-Fridge not Working, Model # MCBR360S
Unplug and look for the thermostat control. Try jumping the thermostat wires together. If it runs then replace the thermostat. Also feel the compressor to see if running, they run very silently. Thanks, Sea Breeze
Apr 27, 2009 | Magic Chef MCBR440 Compact Refrigerator
Ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wwt
Dec 30, 2008 | Magic Chef 31000 Gas Kitchen Range
MAGIC CHEF 5 YRS OLD WONT AGITATE
Ours started doing the very same thing. I took the top off and found that a mouse had chewed a hole in the vacuum tube. I replaced it with a 3/16" ID small engine gas line hose I bought at local implement dealer. Works like a charm.
tjn
Jul 23, 2008 | Magic Chef CAV2000AWW Top Load Washer
Fridge won't run
hi brenda,
can u hear a humming sound as if it is trying to start then it would stop after a clicking sound?
if it does then it is your compressor trying to start but can not do it.
you could either have a problem in your starting relay of overload protector of the compressor or the compressor itself is the defective part and it needs to be replaced.
i hope i was able to help.
pls rate me
tnx
drcool
Jul 21, 2008 | Magic Chef MCBR440 Compact Refrigerator
Re: Magic Chef
If the compressor is running but the fridge is not cooling, the gas may have leaked out of the system or the compressor is inefficient. The only way to know for sure is to connect a set of gauges to the system. You will need to call in a Refrigeration Mechanic.
Nov 03, 2007 | Magic Chef MCBR440 Compact Refrigerator
Magic Chef MCBR440 Compact Refrigerator Logo
652 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
