Question about Cobra 148 GTL 120-Channels Base CB Radio
Saturn workman b-100
SWR is way too high using b-100 in attic with 148 gtl.This is a no ground plain antenna with bracket screwed into a wooden truss.Is there any way to tune the antenna as I thought no tune was needed.
I just bought this antenna and i saw that swr was off the scale so i was thinking and thought of trying a ground on the bracket of the antenna and when i did that the swr's were totally flat. When i did that i called my buddy and told him to let me know what the signal was with this antenna and he said it was like 91/2 pounds for signal and that was with it in my bedroom. so i would just put a ground wire on the bracket andyou would be good.
Posted on Jan 18, 2009
    Brigadier General:
  • 6,966 Answers
I read through the specifications of this antenna and you were right in posting "no ground plane, no tune". Still, there are only three (3) possible reasons why the SWR would be high:
1. Cable/connector - loose, cold solder or improperly terminated;
2. Antenna - tuning and/or ground plane; and
3. Radio has been highly modified or defect in final stage.
Corrective procedures would call for:
a. verify that the coaxial cable is properly connected to the PL-259 connectors. You may need to use a continuity tester (or a DVM) to do so. Pls pay particular attention to the braided shield/grounding, they should be real tight/soldered good to the casing of the connector. Of course the cable should be 50ohms RG8 or 58 with thick shielding.
b. as stated the antenna doesn't need to be tuned then there's nothing that can be done since there is no provision for such, however, even if the specs says no ground plane needed, there is something you can try. Install a ground plane. this could be done by attaching 2 lengths of big gauge ordinary wire to both sides of the metal bracket of the antenna. They have to be 8' 7" ~ 9' long. It may help you further to install a grounding strap again from the metal bracket to any grounded metal portions of your house such as the plumbing.
c. radio problem would be unlikely if it is still stock.
Hope that this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Feb 07, 2008
    New Friend:
Remember keep everything in lengths of 3 for good swrs
Posted on Feb 07, 2013
Spend 20 dollars more and get a 12 foot stick
Posted on Nov 08, 2008
Hello everybody,try to use a 28 metres of coaxila cable rg58 and cut it untill the swr go down.I do that and the srw of my antenna is 1:1,2 on 27.285MHz till 27.585MHz.
73 and good luck
rick
Posted on Feb 02, 2009
I had this same problem; I was using RG-8 with homemade connectors. My SWR was off the chart. I picked up 50' of RG-58 from Radio shack and the SWR needle hardly moved. So I guess I have to get better at soldering RG-8 connectors.
Thanks for the tip, its much appreicated.
Posted on Sep 30, 2008
I am having a problem with mt cb. I used all new coax, antenna, antenna stud and mount. New mic and radio. The problem is I hook up the swr meter, keyed and the meter swung hard right. I have changed
ok, you have a high SWR.. this is what you can do.. you're gonna need to check the Radio's coax connection to see if it's loose on the Radio itself.. you're gonna have to open the Radio cover on the speaker side.. now go look at the connections on the pc board itself and see if there is a possible broke connection.. one is pcb ground, and one for the center. also, you might want to get a phillips head screw driver and gently tighten all the screws on the pc board. becareful going in there.. after this said and done, check the antenna connector itself to see if it's loose. if so, then you're gonna have to a pair of pliers to turn the nut on the inside while you use wrench to hold it in place on the outside.. now you're ready to test the radio.. don't put the cover on just yet until you see the results. set up your SWR Meter to the Radio and then set up the dummy load and do a SWR Test. if the reading is good, then the Radio is all set.. now for the Antenna.. you said that it's all new, but regardless you need to test it too.. check both ends of the cable and do a condinuity test.. get a ohm meter that has an audio sound. this will help you.. set the meter to ohms/conditnuity.. then short out the probes to get a ZERO reading/audio sound.. now take one end of the of the cable and put the probes on the connector.. one probe for the outter ground shell and the other probe to the center pin connection. if you see a ZERO reading or an audio sound, that means you have a short in the cable.. another way is to do it end to end.. put one probe on one end of the cable, and the other probe on the other end.. test the ground side first.. if you get a sound or a ZERO reading, that means you may have a short in the cable itself and may requier to remove the connectors.. some cases you might have to replace them.. remember to calibrate your meter when testing let me know how it goes.. I'll continue to help you.. you can contact me on Facebook.. https://www.facebook.com/pages/ANR-Communications-Repair/136358796473669?ref=bookmarks Good Luck..
Aug 27, 2014 | Cobra 29 LTD CB Radio
Cobra 1000 gtl modulation/swr meter vr adjustment
you are not matching it correctly. get hold of a friend that knows how to match it and see if he will help you.
Mar 18, 2013 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 GTL, Firestik II 2' tunable tip, Firestik K 74 lip trunk mount. I can't get a good match. SWR is in the red.
did you try sand paper. where the mount meets the metal you should sand off the paint to get a good ground. If that doesn't work try a longer antenna.
Jan 30, 2013 | Firestik K-74 Trunk Lip Antenna Mount
Having prob with modulation on am
Several questions. 1) do you have it connected to antenna with good coax?2) did you check your match on the radio with an SWR meter? What kind of match do you have,is it below 3.0? If it is that high get down to around 1.5 - 2.0 and others should be able to hear you.
Sep 13, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
I there got a cobra 148gtl-dx and was wondering what the best smallest outdoor antenna is many thanks
There is no "best smallest" Base antenna. You can get a workman saturn B base antenna, it is small and black, but they do not work so great.
the best bang for your buck is an antron 99 base antenna. Unfortunately it is 18 feet long when put together. But if you spray paint it a dark color, and put it up in a tree you will hardly notice it.
When it comes to base radio's, smaller is not better, and you cannot get a best.
Antron 99 is the smalles antenna that will fall into a near best category.
But the saturn B will still work if you absolutely need small. you can find a bunch on ebay cheap.
Jul 31, 2011 | Cobra 148 GTL 120-Channels Base CB Radio
Have a cobra 148 gtl cb/ssb. It is brand new. I hvae it hooked up and have tuned the antenna using the swr meter on the cb. I habe channel 1 and channel 40 metting at about 1.6 swr. I have what appears to...
Hi, my name is John. Welcome to FixYa. Check your antenna, you need to set it with a real SWR meter, pick one up at any near-by CB shack $10.00. Thanks for choosing Fixya...John
Jul 22, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
I just installed a Stryker 490HP in my big truck, the most power I seem to be able too pull is around 30-35 watts from 125 before I get some serious feedback when I key up? Rookie
RF feedback into the radio most likely from bad SWR or poor ground counterpoise at the antenna. Change out antenna to something more capable of use with this radio. Maybe a 102 stainless steel whip or Wilson 1000 or K40 type.
Feb 02, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
Have not used my cobra for some time ...sine someone need my K40 antennae more than me. Just put it back in service with a new magnet mount 36 inch - can send and receive in USB and LSB ....can here in the...
Center the antenna on the vehicle, then check the SWR on channel 1 and channel 40.
with the switch in CAL position, key radio and use the swr/cal knob to set the meter so the needle is just touching the end of the red area on the right-hand side of the meter.
Once calibrated, unkey and switch the switch to SWR and key up again. The lower the reading, the better. If the SWR is Higher on 40, the antenna needs to be shorter.. if its higher on 1, then the antenna needs to be longer.
if it dont transmit period on AM, then there's an internal glitch :)
Jan 24, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
About a cobra 150 gtl dx
Look into the Workman Saturn B100 antenna. It's what I would use.
Apr 17, 2009 | Cobra 150 GTL DX Base CB Radio
148 gtl
It would seem that you posted twice. Here is the link to your other post.
If I may add to Mechanic688, sharcnet, chiaflub67 and Nitrotrike's postings (with their indulgence), below is a copy of my reply to the other post....
"I read through the specifications of this antenna and you were right in posting "no ground plane, no tune". Still, there are only three (3) possible reasons why the SWR would be high:
b. as stated, the antenna doesn't need to be tuned then there's nothing that can be done since there is no provision for such, however, even if the specs says no ground plane needed, there is something you can try. Install a ground plane. this could be done by attaching 2 lengths of big gauge ordinary wire to both sides of the metal bracket of the antenna. They have to be 8' 7" ~ 9' long. It may help you further to install a grounding strap again from the metal bracket to any grounded metal portions of your house such as the plumbing.
c. radio problem would be unlikely if it is still stock."
Regards all.
Jan 31, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 GTL 120-Channels Base CB Radio Logo
3,566 people viewed this question
Top Cobra Radio Communications Experts
Steve
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
