Question about RCA 32V420T 32" TV
Upgrading i would like to know if i will have to upgrade my system when the airwaves change from analog to dtv , as i did not get an owners manual with my auction purchased tv? i am only using old antenna, uhf_ vhf..thank you
    Sergeant:
  • 395 Answers
The answer to your question is yes if you are using an antenna you will need the set top box. the link to the user manual is here http://157.254.235.130/public/16532540e.pdf
Posted on Feb 07, 2008
How do I watch normal tv on my audiosonic television ?
That depends upon which source your "normal" TV is connected. If you have a cable box using a coax cable, then you will either select the DTV source if the cable box uses digital output or a digital over-the-air antenna, and ATV source if the box is using analog signals or if you are using an analog over-the-airwaves antenna. If you are using a cable box but have an HDMI cable connecting it to the set, then you need to choose HDMI1 or 2 as appropriate. If you have a box that uses the red-black-yellow RCA cables, then select the AV input. Remember that for ATV and DTV inputs from a cable box, you usually have to tune the set to either channel 3 or 4 and use the box to change the channels.
Jan 05, 2016 | Televison & Video
How do I change my service from analog to H D?
Most LCD tv's built in the last 4 years are HD compatible. Most cheaper brands tv's are 720 HD and some are full HD 1080 a little more money. Since their is no more analog broadcast as June 2009 all tv's manufactured around 2006 started incorperating the digital tuner (DTV) along with the analog so that the tv would still receive analog broadcast while the digital transistion was ongoing. All tv's with a Cathode Ray Tube (glass picture tube) are not HD compatible. First you will have 1 or 2 ports on the tv ethier on the side panel or rear panel of the set. They a marked HDMI 1 HDMI 2 or HDMI A HDMI B. If you have these ports your set is Hd Compatible. You may also need to upgrade your cable or satelllite equipment and subscribe to a HD package to be able to get HD service. You will need a HDMI cable to connect your cable or satellite receiver to the HDMI port on you tv. Call your local cable or satellite provider for options to upgrade to HD. Most over the air broadcast stations depending on your area transmit some stations in HD free of charge. A good quality outdoor antenna works best to give you stable signal. You may need to change the settings of the tv as some sets default to the 480i this is the standard digital signal.
Sep 10, 2014 | Televison & Video
My luxor flatscreen tv. Dtv option has been removed ive lost dtv anyone know how to get my dtv back on my tv ?????
factory reset in main menu/system.settings, if you are connected to the internet try software firmware upgrade also. ....but factory reset and new set up should do the trick.
Aug 08, 2014 | Televison & Video
NO CHANNELS
What specific model of JVC multi-system TV do you have? What is the signal source?
The majority of the JVC multi-system TVs that I've researched only have analog tuners (NTSC, PAL). The AV-29LX is an example of the older JVC TVs. Since most over-the-air signals are digital, you will need a digital-to-analog OTA signal converter to watch any signal from an aerial TV. If you have a cable system that has upgraded to digital cable, you will need a cable box.
Converter boxes are harder to find but there are a few remaining. Here's one for the US: http://www.amazon.com/Magnavox-DTV-Digital-Analog-Converter/dp/B0013ZKZGU .
I wish that I had better news for you.
(A few low-power stations still broadcast in the analog format. However, you have to be really close to the station or have an outdoor antenna to have a chance at receiving the signal.)
Mar 30, 2014 | JVC 29" Flat Screen Multisystem TV
Does my curtis mathes tronics tv model CM19011 made in June 2000 have a digital tuner as needed to currently view tv over the airwaves?
No,all CRT tube tvs don't have digital tuner inside.They're analog tvs.Must buy the converter box,and hook it up to get the free DTV airwave signal.Trust me,i help an elderly person hook up this exact this tv model with a converter box.Try buy the RCA model converter box,it matches with this tv model very well.
May 15, 2010 | Curtis-Mathis CM19011 TV
I get no stations on my tv
Use an Antenna that Provides Good Reception of All Channels
  • Most existing antennas used by consumers will provide good reception of DTV signals. (Before making any changes, try your existing antenna first to see of it allows you to receive all the stations you normally watch.)
  • For watching DTV signals, you will need an antenna that provides good reception of both VHF signals (channels 2-13) and UHF signals (channels 14-51) to reliably receive all of the digital signals broadcast in your area.
  • Many antennas are designed only for reception of either VHF or UHF signals (but not both). For example, the commonly used “rabbit ears” indoor antenna is only suitable for receiving VHF signals. To receive UHF signals, an indoor antenna should also include a wire loop or other feature for reception in that band.
  • The reception capabilities of TV antennas also vary considerably, so be sure to talk to retail consultants and look at information on the packaging and/or the Internet to make sure that any new antenna you may choose provides good reception of both VHF and UHF channels. In addition, if you use an indoor antenna and receive signals on VHF channels, you may need to use an antenna with amplification.
  • Many antennas currently being sold as “HDTV Antennas,” perform best at receiving UHF signals; some of these models state that they provide reception of signals on channels 7-13 but actually perform less well receiving those channels. If you obtain one of these antennas, be sure it provides good reception of all the VHF channels as well as the UHF channels.
  • To check for the DTV signals that are available at your location, use the DTV Reception Maps available at www.fcc.gov/mb/engineering/maps.
Check Your Connections
  • Check that your digital-to-analog converter box or digital television is connected properly. Make sure your antenna is connected to the antenna input of your digital-to-analog converter box or digital television. If using a digital-to-analog converter box, also ensure that the antenna output of your converter box is connected to the antenna input of your analog TV. Refer to the owner’s manuals of your components if you are unsure of the proper connections.
  • Ensure that your components are plugged in and have their power turned on.
  • If you have a digital-to-analog converter box, tune your analog TV to channel 3. You should see a set-up menu or picture displayed on your TV screen. If you do not see a set-up menu or picture, tune your TV to channel 4. If you still do not see a set-up menu or picture, recheck your connections.
Perform a Channel Scan
  • Digital-to-analog converter boxes and digital televisions have a button, usually on the remote control, that is labeled “set-up” or “menu” or some similar term. Press that button to access the set-up menu. Using the directional arrow buttons on your remote, scroll to the option that allows you to perform a “channel scan.” The channel scan will automatically search for digital broadcast channels that are available in your area. Consult the owner’s manual of your digital-to-analog converter box or digital television for detailed instructions on how to perform a channel scan for your device.
  • Once the channel scan is complete, you will be able to tune to the digital channels received by your antenna. You should perform a channel scan periodically to check whether additional digital channels have become available.
Adjust Your Antenna
  • Small adjustments to your antenna can make a big difference in the number of digital channels you can receive. If you have an indoor antenna, try elevating it and moving it closer to an exterior wall of your home. After adjusting your antenna, perform another channel scan to see if your reception is improved.
  • While adjusting your antenna, it may be helpful to access the “signal strength meter” on your digital-to-analog converter box or digital television to determine whether your adjustments are improving the signals’ strength. The signal strength meter is usually accessed through the menu feature on your remote control. Refer to the owner’s manual of your device for detailed instructions on how to access its signal strength meter. Remember to do another channel scan after you have adjusted your antenna.
  • Television stations broadcasting in digital use both the VHF band (channels 2-13) and UHF band (channels 14-51). Many indoor antennas use “rabbit ears” for the VHF band and a “loop” or “bow-tie” antenna for the UHF band. Make sure you are using an antenna that covers both the VHF and UHF bands and have connected it properly.
If You are Still Having Difficulty:
  • Until June 12, 2009, some stations will be operating at reduced power levels. If you are not receiving certain digital TV stations, this does not necessarily mean there is a problem with your antenna or digital-to-analog converter box or digital television. Check with the TV station to find out whether they are planning changes that will improve reception.
  • When an analog TV signal is weak or receives interference, static, snow, and distortion will often appear on the screen. Digital broadcasting will provide a clear picture; however, if the signal falls below a certain minimum strength, the picture can disappear. This “cliff effect” means that if you watch analog TV stations that have static and distortion, you may have to adjust or upgrade your antenna system.
  • Simple indoor antennas provide minimal performance that may not be suitable for your location. If you are unable to obtain satisfactory DTV reception with your current indoor antenna, you may wish to obtain an indoor antenna that includes features for better reception of UHF signals, as well as VHF, and/or an amplifier to boost the received signal (often referred to as an active indoor antenna).
  • Generally, an outdoor antenna will get better reception than an indoor antenna. However, the performance of outdoor antennas can degrade over time due to exposure to the weather. If you are having problems, check for loose or corroded wiring, broken antenna elements and that the antenna is pointed in the right direction.
  • Try to keep the length of wire between your antenna and digital-to-analog converter box or digital television as short as possible for best reception.
  • “Splitters” that are used to connect a single antenna to multiple digital-to-analog converter boxes or digital televisions reduce the amount of signal available to each device. If you are having problems, check whether reception is improved without the splitter. In some cases an “active” splitter that includes an amplifier can solve the problem.
  • If you are near a station’s broadcast tower, reception of that station, as well as other stations, can be impeded by strong signal “overload.” Consider using an “attenuator” or removing amplifiers to improve your reception.
  • If you decide to replace or upgrade your indoor or outdoor antenna, many types are available from electronics retail stores at a variety of prices. Websites such as www.antennaweb.org provide information on the locations of broadcast towers and the types of outdoor antennas appropriate for the stations you wish to receive. If you need assistance with upgrading your antenna system, check with a local antenna retailer or antenna installer.
Hope it may helps:
Regards:
VOTIT
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
No DTV on my 2006 Polaroid FLM-2632 model 2700?????
Try going into your menu and putting the input to Antenna, then reprogram, let me know!
Feb 18, 2009 | Polaroid FLM-2632 Television
Have a problem
Currently, your switch box likely has several inputs, which as you said are occupied by your DVD Player, XBOX, and your television source. The output of the switch is then fed to your TV.
What you will need to do is insert the DTV converter box BEFORE the switch box. If you have an analog antenna on your TV (rabbit ears) you will need to put the converter box between your antenna and the switch box (the cables, not the box itself) so that your wiring goes like this:
Antenna ---- converter box ---- Switch box
XBOX ---------------------------------switch box
DVD -----------------------------------switch box
And the switch box still goes to the TV. However, you do not NEED to use the converter box until February of 2009.
Jun 11, 2008 | Insignia Digital-to-Analog Converter for...
Upgrades
The DTV converter is only required if you use an external antenna. If you have cable or satelite, nothing will change. There are no other options.
Dan
May 23, 2008 | GE 25GT240 25" TV
RCA 32V420T 32" TV Logo
50 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
