Question about Zenith DVB312 DVD Player
Zenith DVB312 --need to change from progressive scan to interlaced scan---lost manual
    Genius:
  • Zenith Master
  • 1,550 Answers
Try this first turn on the dvd then check the disc tray it´s empty now push the stop button for about 10 seconds good luck
Posted on Jan 09, 2010
Testimonial: "Thanks for this concise answer--THANX!"
SOURCE:
My DVD has no picture but has sounds ,on my sony bravia tv i have done every thing but still there is no picture
Please check if the DVD players progressive scan is enabled. If it is disable it. You will get instruction in the last chapter of the owners manual under troubleshooting. Or find out how to do a factory reset, because all DVD players come with progressive scan disabled from the factory.
Jul 14, 2011 | Zenith DVB312 DVD Player
Stuck on progressive scan
This is a common issue with this brand of player. While the unit is on, and without any discs inserted, press and hold STOP button on the front panel (not the remote) for 10 seconds, then release. This should turn the progressive scan function off and revert the video output of the player back to normal interlace.
Zenith, Samsung, Magnavox, and Goldstar DVD players are notorious for progressive scan headaches, but it's easy to correct.
Apr 16, 2011 | Zenith Televison & Video
HOW DO I GET MY DVD OFF PROGRESSIVE SCAN
You do either of the following; refer to your instruction manual (if you still have it) and look for general output settings to turn off progressive scan, or you can try something much simpler.
On the front of the unit, without a disc inserted, and the drive selected as DVD, press and hold STOP button for 10 seconds (on the unit, not the remote), then release. This may revert progressive scan back to normal interlace for your TV, and thus turn progressive off.
This trick works for Goldstar, Samsung, some LG, Magnavox, and Zenith DVD players. Give it a try before referring to the manual.
Apr 13, 2011 | JVC DR-MV150B DVD Recorder/VCR
Hi, I've a small problem cocerning this dv-363 player. I accidentally set it to 'progressive'. Now I cannot undo. I tried holding the buttons on remote and on machine itself, still not working, can you...
Progressive Scan is a menu option relating to video output of this player. Assuming you have the original DVD remote, this should be easy.
* From the user manual (pages 50-51 of the pdf document):
About progressive scan video
Compared to interlace video, progressive
scan video effectively doubles the scanning
rate of the picture, resulting in a very stable,
flicker-free image. Progressive scan video is
available only from the component video
output.
If you connect a TV that is not compatible
with a progressive scan signal and switch
the player to progressive, you will not be
able to see any picture at all. In this case,
switch everything off and reconnect using
the supplied video cable (see Easy
connections on page 14), then switch
back to Interlace. Switch the player to
standby then, using the front panel
controls, press STANDBY/ON while
pressing 'back to Interlace.
Hold these 2 buttons together for about 10-15 seconds or so, but only while the player is in standby mode. *
If you have lost the manual, you may be able to download the user guide (as an adobe reader (pdf) document) from:
http://www.retrevo.com/support/Pioneer-DV-363-K-DVD-Players-manual/id/385bh937/t/2/
(it will ask you for an email address prior to downloading - use a blank address if possible and enter the security code in the fields then save the document)
If the above suggestion does not switch it back to interlace, you will need a TV with progressive scan function to enable you to access the player's on-screen menu and in 'Initial Settings' 'Video Output' 'Component Out' section, select 'Interlace'. and press OK from remote as required.
Either way, it should NOT require a workshop service, and is simple enough to do at consumer level with the right TV type.
Mar 05, 2011 | Pioneer DV-363 DVD Player
I want to set up my dav-fr10w to 'interlace' option so i can play the dvd's on my tv, but it's set to 'progressive' right now and the instruction manual doesn't give the specific information to change it....
To cancel Progressive scan output or to change output to interlace signal format, follow these steps..
1- Select DVD by pressing Function button on unit.
2- While holding down |<< (review) button, press Function button on unit.
This will change output signal to interlace/ composite video output from yellow pin/ S-Video.
Hope this info will help you.
Thanks.
Feb 05, 2010 | Sony DAV-FR10W System
DVD recorder: Changed the settings, now
we could go through the setting like, you can see the monitor. using the remote do the following steps:
Step 1. press set up button.
Step 2. press down arrow once. ( playback)
Step 3. press OK.
Step 4. press down arrow once. (video (selection))
Step 5. press OK. (progressive scan)
Step 6. press OK, again.
Step 7. press down arrow once. (progressive scan off)
Step 8. press OK
you have now turned progressive scan off.
Dec 19, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Progressive scan
This happened to me & I finally found a manual online that I could download.
Here's what the manual says:
"If you set Progressive Scan to On in error, you must reset the unit.
1) Remove any disc from the unit and close the disc tray. See that "NO DISC" is displayed on the display window.
2) Press STOP and hold it for five seconds before releasing it. The video output will be restored to the standard setting and a picture will once again be visible on a conventional analog TV or monitor."
Glad I could help because this problem is very annoying!
Sep 27, 2007 | Zenith ZHX-313 System
How do I reset this ilo dvdr05
To reset to user defaults for mu1 with no video: 1. turn on dvd with no disc 2. press "setup" 3. press "down arrow" 3 times 4. press "enter" 5. press "down arrow" 9 times 6. press "enter" More than likely you changed from interlaced scan to progressive scan. If your tv does not sopport progressive scan there will be no video. The default setting is interlaced scan.
Dec 07, 2006 | iLO DVDR05 DVD Recorder
No picture but has sound
Hi If your t.v.has built-in blue screen when there is no signal, then the DVD may have been accidentally switched to progressive scan mode, or defaults to that setting if new. If your T.V. is not capable of displaying in progressive scan mode, you will just get a blue screen. If you have an older tv, without blue screen, then connect it to that, and if you get a black and white split screen when you turn on the DVD, then progressive scan is the problem. Check the manual for the DVD player for the procedure to get out of that mode, and it should then work. If you still have no video, and you are using the yellow composite video jack on the back of your DVD player, then it must be brought in for service. Good Luck!
Aug 14, 2006 | Zenith DVB312 DVD Player
Zenith DVB312 DVD Player Logo
254 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
