Question about HP OfficeJet 6110 All-In-One InkJet Printer
Unable to print
Keep getting message to...Press Enter to align catridges.......however after doing so the same message comes up....
? How do I fix this.
  • Anonymous Feb 08, 2008
    caanot align catridge
I waht to dowload hp offcejet6110 to my com
Posted on Feb 08, 2008
I have a dell V505w red all in one printer. Keep getting a message alignment problem. Please remove tape from cartridge or check troubleshooting. There is no tape on cartridge.
print a test page, then place the printed test page on the scanner glass and press the scan button to align the catridges and see how it goes when you try to print again.
Nov 15, 2010 | Office Equipment & Supplies
Cannot photocopy document
hi...
the colour catridge has nothing to do with the black and white print out if it is a text document. please check you have placed the black catridge propely and in correct positon. and try printing out the pages
Jul 15, 2010 | HP PSC 2210 All-In-One InkJet Printer
Press enter to align cartridges message comes into the window of my HP combo machine and won't change. I reset the cartridges in their holders, turned machine off/on, no go. The machine still prints out...
You should load paper and press enter to align, The message will keep coming back until you let it do alignment or press enter and option buttons at the same time.
Jul 24, 2009 | HP PSC 2210 All-In-One InkJet Printer
Error message after replacing the black cartridge
You must replace both ink carts to get an alignment.
Dec 29, 2008 | HP PSC 2210 All-In-One InkJet Printer
Keep getting message Press Enter to Align Cartridges
after each alignment you press enter key or start key not cancel key,
Dec 12, 2008 | HP PSC 2175 All-In-One InkJet Printer
Cartridges wont align
Could be one of two things....
1 - as the person has already posted, you may have bad cartridges...when the machine does an alignment it looks for specific marks on the paper...ie..green check marks before each line etc...if the correct marks are not there you will get an alignment failure...if the green check marks are there etc then you have a different problem...
2- spot sensor on the side of carriage is not working...this is the little blue/green light that comes on during alignment. Its what reads the markings on paper so if the markings are correctly there and you still get this error then the spot sensor needs to be replaced. Simple fix that u can do. We sell the spot sensor for $15
Inkworks
866-381-0541
Nov 04, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Align cartridges error
This means one of the cartridges is defective, they cant align if they cant print.  What i did to fix this problem is insert 2 working cartridges and get it to align properly, even if they are low on ink, then lift the cover and the cartridges will move to the center.  When this happens pull the power cable out, then insert the full non functioning cartridge. Plug the power cable back in.  I tried this with a color cartridge, the color cartridge was non functioning but i was able to print in black.
Basically you align the cartridges and then swap them so the printer thinks they are still aligned.
The color still doesnt work and it is probably a defective color cartridge.
Sep 04, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
Printer cartridge alignment
You can also bypass the alignment. When the message for alignment displays on the display => Press Setup and Options (or Copy Options ) simaltanious.The last known alignment is used when the alignment is bypassed.
Sep 04, 2008 | HP PSC 2175 All-In-One InkJet Printer
Alignment message
to fix this problem place this alignment sheet on the scanner glass as if u were copying somthing n just press the scan button .the power light will blink few times n then stop.which means alignment is complete n u hve fixed ur problem. rate this solution as fixya n encourage us to solve more n more problem in future. thanks bye
May 23, 2008 | HP PSC 1410 All-In-One InkJet Printer
HP OfficeJet K60 Printer
you can bypass when asked and use last good settings by..Press and hold the Enter button, and then press Menu
This problem is caused by incorrect alignment page print out caused by faulty cartridges, ideal fix is replacement of all ink carts
HP have a webpage dedicated to this...h10025.www1.hp.com
Also get on your gloves get out your vac and suck on the carts till a little ink comes out, make sure colour cart releases all 3 colours then reinstall, can get messy.
Oct 19, 2007 | Office Equipment & Supplies
HP OfficeJet 6110 All-In-One InkJet Printer Logo
32 people viewed this question
Ben Johnson
